      12-31-2015, 03:54 PM   #23
Tightt
Tightt's Avatar
66
Drives: 2016 X5M/2024 M3 X-Comp
Originally Posted by TrakBch View Post
The ECS 15mm spacers did not clear the flange. It looks like your would need 18mm to clear the front wheel hub and seat flat.
The spacer would need to be milled another 2-3mm or someone needs to make a spacer that does not taper in the bore.
Damn....I was hoping the ECS ones would work.
      03-13-2016, 10:56 PM   #24
elisiX
elisiX's Avatar
Australia
687
Drives: '20 X3M Competition
Reading up on spacers and i'm a little confused.
With the stock 612M wheels, can you use the H&R 15/20 spacer set?
If not, what specifically should someone buy?
2020 BMW X3M Competition ///M - ALPINE WHITE / SAKHIR ORANGE
Past: 18' BMW M3CS | 18' BMW X5M | '17 BMW M3 Competition | '16 Mercedes GLC250 | '16 BMW X5M | '15 BMW X5 M50d | '14 Audi SQ5
      03-13-2016, 11:01 PM   #25
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
The hub on the F85/86 is deeper than other BMWs. This means you'll need 20mm to clear the lip of the hub.
      03-13-2016, 11:11 PM   #26
elisiX
elisiX's Avatar
Australia
687
Has anyone fitted sub 20mm on the front and not had issues?
Also, has anyone fitted 20mm on the front and can share pictures?
This is with stock 612M wheels.
      03-13-2016, 11:45 PM   #27
20mm would be too much for the front.
I do suggest 5mm front and 15mm rear.
I have done F15 with F85 21" wheels with that spacer setup. The customer love it very much.
SPRING Sale!! 04/01 - 04/15 - Code: "SPRING2024"
      03-13-2016, 11:58 PM   #28
JNoSol
JNoSol's Avatar
I thought you tested and 15mm isn't enough to clear the hub?
      03-14-2016, 05:04 AM   #29
elisiX
elisiX's Avatar
Australia
687
So confusing lol.
All I want to know is, what's the ideal front/rear spacer setup for stock wheels.
      03-14-2016, 11:46 AM   #30
robbys3m3
Drives: M3's
I'm running 5/12.5. In a perfect world I think I'd like 10 front, 15 rear, but overall I'm happy
2020 M2 CS, 2018 M3 CS, 2016 M4 GTS, 2013 M3 LRP, 2011 1M, 2011 M3 GTRS3, 2004 M3, 2002 M3, 2000 M Coupe, 2002 M5, 1997 M3, 1988 M3, 2022 STO, 2020 Urus, 2022 TRX, 2022 392, 2021 SVJ, 2018 Performante, 2013 Gallardo 550-2, 2012 Gallardo STS, 2018 R8 RWS, 2012 R8, 2017 G550 4X4^2, 2015 GT3, 2015 Continental GT3R, 1971 Bronco
      03-14-2016, 12:10 PM   #31
JNoSol
JNoSol's Avatar
Good to know. Glad they fit.
      03-14-2016, 05:52 PM   #32
15mm would not clear the hub shoulder height. So either 5, which doesn't have the hub extension or anything thicker than 15mm.
10mm would also fit, but that doesn't leave you enough hub shoulder where the wheel is actually sit on.
With the power and weight the car, I wouldn't trust 5mm to rest the weight on.
Thanks to BMW to change the hub assembly on mid 2014.
The earlier production of F15 allows you to run 15mm on the front.
      03-28-2016, 11:24 AM   #33
Ryngo
Drives: 2016 F85 X5///M, DG
Originally Posted by elisiX View Post
So confusing lol.
ElisiX - you ever figure this mystery out specific to the 612M stock 21" wheels?
      03-28-2016, 05:59 PM   #34
elisiX
elisiX's Avatar
Australia
687
No, I still don't think i've got a straight answer lol
Reading a number of different posts, it sounds like you can only do exactly 5 on the front and anywhere from 12.5-20 on the rear.
      04-01-2016, 09:51 AM   #35
Alan l.
Alan l.'s Avatar
5417
From what i've gathered for the front you need at least a 18mm spacer to clear the hub lip on the car. The rear you can run whatever size you want depending on your wheel setup.
Alan
      04-01-2016, 12:59 PM   #36
Alan
Let me correct that if you don't mind.
The rear you can run 5mm, 15mm and up. Because the hub height is a little less than 15mm, so if you run 10mm, you will have a problem where the wheel doesn't sit properly on the hub.
Here what I will do. I will order 10mm and test it and see how much hub left where the wheel can sit properly.
Please note that the car is quite heavy where I won't feel safe with the wheel just sitting 2-3mm on the hub.
      04-01-2016, 01:02 PM   #37
Alan l.
Alan l.'s Avatar
5417
Has it been confirmed that 15mm works up front? I am pretty sure people tried 15 and its still not enough to clear.
And yes 5mm does work up front as well since the spacer doesn't have its own hub lip. I ran this on my X5 but took it off because it caused vibrations at higher speeds and 5mm is barely even noticeable.
Alan
      04-01-2016, 02:24 PM   #38
Alan
15mm only work on the early production F15 X5 front hub. I believe 07/14 is the cut off.
      04-04-2016, 09:15 PM   #39
Ryngo
Did the 10mm spacer work on the front or were you only left with 2-3mms as you suspected?
      04-04-2016, 09:17 PM   #40
I am on vacation until next week.
I will update once I get back.
      04-04-2016, 09:43 PM   #41
Ryngo
. Thanks for the invite.
      04-04-2016, 09:49 PM   #42
Haha. It is for my kids spring break.
Well, here is the data from previous measurement.
The hub height of the MY07/14 is 15mm+, so if you put 10mm, you have 5mm+ left.
But then, there is a bevel on the backing of the wheel. That usually about 2mm.
So that will leave you about 3mm hub height surface. Do you feel safe? I wouldn't.
      04-04-2016, 09:56 PM   #43
Ryngo
No way Jose. Nevermundo. Carry on. Tell Mickey I said hi!
      07-29-2016, 02:08 PM   #44
elm3
///M Fan
elm3's Avatar
Drives: '09 E92 M3 IB/'17 f85 X5M LBB
2017 BMW / X5M  [9.00]
2009 E92 M3  [10.00]
2004 Yamaha R1  [10.00]
I hate to bring this post from the dead, but what can we use as spacers on front and rear on the stock 612 21" on a 2017 X5M? Or are we left on having to purchase aftermarket wheels then? Does anyone have an answer to this, without going all loopy, just straight answer, front = --mm and rear = --mm
Thank you.
Eric
'09 E92 ///M3 Interlagos Blue,6MT,Silver Novillo Leather,CF Trim,Premium Package,Technology Package,Cold Weather Package,Premium Sound,19"Wheels,Moonroof-Toy/'17 X5M, Long Beach Blue, Executive Package,Technology Package, Lighting Package, Driver Assist, Full Mughello Red Interior, 21" wheels-Toy/'14 535i with M Sport and 19" wheels-Daily
center bore, f85, wheel spacer, x5m
Search this Thread:
Advanced Search
