      07-22-2016, 11:02 AM   #1
14F10MFive
Drives: F85 & F95 X5M
2016 X5M Running BMS JB4!
Hi guys! I just want to give a shoutout to Terry from BMS for working together on getting the JB4 on my vehicle and running. I truly have to say the tune opened up the beast!
In the video the ///M is running on Map 2 with pump 93
Enjoy
https://youtu.be/6AC1MfJ-bYA
Best,
Joe Cicareli.
      07-22-2016, 11:10 AM   #2
Ehloo
Drives: 15 x5 m
Love to hear more about this. Saw a X5m on insta that was running jb4 so knew it could be done. Maybe the same car
What all needed to happen to make this work
      07-22-2016, 05:33 PM   #3
R0ut3r
R0ut3r's Avatar
125
Drives: 2020 Lamborghini Urus, 2021 Fe
Would really like to know more as I have a racechip on my shelf which I haven't installed yet and would prefer JB4. I trust BMS more (and It! clears codes if I put down pipes).
___________________________________________
Current: 2021 Lamborghini Urus, 2021 Ferrari F8 Tributo Spider, 2019 X3, 2022 M4C Cab
Past: 2009 e92 335XI, 2012 e92 M3, 2014 335XI, 2016 X6M, 2019 M5, 2013 Ferrari California, 2017 Ferrari California T, 2020 X4MC, 2020 Porsche C4S Cab (992)
Montreal, Canada
      07-23-2016, 03:46 AM   #4
LBBX5M
71
Drives: X5M F85 Akra, RaceChip
Can you share the link to the product please?
      07-23-2016, 09:55 AM   #5
Dan725
Drives: 2016 BMW X5M (F85)
This appears to be it:
http://www.burgertuning.com/jb4_pnp_...nce_tuner.html
      07-23-2016, 11:00 PM   #6
R0ut3r
R0ut3r's Avatar
125
It's actually this one:
http://burgertuning.com/s63tu_m5_m6_bmw_jb4.html
But do we know if the M5/M6 harness will work and if the difference in transmissions between our trucks and these cars cause problems?
      07-24-2016, 01:17 AM   #7
LBBX5M
71
These kits look intense.... Dinan and disregarding my concerns about RaceChip, looks much easier to install and take them off before service.
      07-24-2016, 08:20 PM   #8
14F10MFive
Yes it will work. I can assure you it will work for your trans too. It doesn't change trans settings, so no need to worry, at least for now. Theres no back-end flashes for trans, boost, etc..
Specify in your order that its for an F85/86 X5/6M.
      07-24-2016, 08:21 PM   #9
14F10MFive
I believe that it is the best product out, as of now.
      07-24-2016, 11:04 PM   #10
Alan l.
Alan l.'s Avatar
5437
I am just curious why you think the JB4 is better than the other piggybacks out there now?
Is there actual customer dyno posted yet?
Alan
FSociety3812.50
      07-25-2016, 03:42 PM   #11
14F10MFive
Alan
I don't think so, but I can ask Matt. PM me your cell #.
F85Matt217.00
      07-26-2016, 10:13 AM   #12
LBBX5M
71
Looking at the install guide, I personally feel a demo video is much needed.http://burgertuning.com/s63tu_m5_m6_bmw_jb4.html
delviacv2111.50
      07-29-2016, 12:55 PM   #13
14F10MFive
It is. It took about 2 hrs to install. One of the plugs is very difficult. So worth the time though. Its incredible how quick this truck is now! Very happy with the outcome.
      07-29-2016, 10:35 PM   #14
Ehloo
Drives: 15 x5 m
Do you know how many connections. I installed my race chip myself and pretty self explanatory but one connection was hard to get too. Thinking I could install myself
Did you run the BCm also
      08-01-2016, 09:31 AM   #15
14F10MFive
Yes i did! I have noticed it helping out tremendously. I loose less than 1 psi of boost when the car is shifting from one gear to next... I think the trans has a lot to do with it as well.
      08-01-2016, 09:50 AM   #16
m3driv3r
23
Drives: 2016 X5M
dkhm31881.50
      08-01-2016, 09:59 AM   #17
m3driv3r
23
Drives: 2016 X5M
What is the Insta Name
      08-01-2016, 09:59 AM   #18
Ridicule23
Drives: F80 M3
Originally Posted by m3driv3r
Hey guys sorry for the late reply. I just posted my 1/4 mile run on the Sydney thread.
The kit is relatively easy to install if you know what you are doing
There are 4 connections and 2 stray wires.
2 plugs for tmap under the intercoolers (any piggy back on the market uses these two plugs, it allows for 3psi over stock)
2 plugs for electronic wastegates and BCM (required for 20+ psi applications)
One ground for BCM, and one plug for OBD wedge for canbus.
Changing maps can not be done on the BC Button like every other jb4 but in time we'll figure that out. Boost on fuel gauge is live tested and working for me for months. I daily the car in map 2 (22psi) and yes have dyno'd the car. It is north of 620whp but for sake time I won't post numbers as we're still playing with it.
Map 7 can be run with 100+ octane @ 25psi
Car is a rocket now, have videos against e55s, e63, gtrs. She holds her own. If anyone wants to pm me I'm more than happy to provide install instructions (without removing intercooler like needed for m5) as well as answer any questions. Been running it 3 months and 8000 miles so far so good!
Install for a new timer is roughly 2 hours. I can have it in or out in 30 minutes so once you do it once you'll realize the simplicity!
do I have to get the bcm module & obdii port ($1050)or can I just get the ($450) which is recommended
      08-01-2016, 10:27 AM   #19
m3driv3r
23
Drives: 2016 X5M
      08-01-2016, 12:33 PM   #20
R0ut3r
R0ut3r's Avatar
125
Ordered JB4 with BCM
I have a racechip for sale now. Never installed!
Montreal, Canada
      08-01-2016, 03:53 PM   #21
m3driv3r
23
Drives: 2016 X5M
You're going to enjoy. Pm me and I can help walk through. Once you remove airbox and cross member the tmap are easily reachable. As well as the two wastegate. I suggest finding a long skinny hooked screwdriver to pick and lift the furthest wastegate plug, will save you from removing. I will redo mine tomorrow and take detailed pics for anyone needing assistance!
      08-02-2016, 08:45 AM   #22
onfireX5
Drives: F90M5,F85X5M
JB4 can make impressive power. Only concern I would have is Drivetrain breakage once you go over 3-4 psi increase. Holding that much power at our weight can be tough on parts.
