10-10-2016, 09:05 PM | #1 |
Rep 11,136
21" wheel/tire question...
Just bought some Style 375s for the X5 that my wife drives. I realize tire choices are quite slim. Do I go for RFT P Zeros or Michelin PSS tires, which aren't RFT?
How many miles is everyone getting out of their sets? And for those not running RFT, do you just carry a spare with you? I have a two year old, so would hate to leave my wife stranded somewhere if I put on non-RFTs. |
10-10-2016, 10:38 PM | #2 |
Rep 18,712
No offense to all RFT believer, but for me, I will go non RFT.
Both RFT and Non RFT are will do fine to drive with puncture. The only difference, with Non RFT, it will deflate. But even before you are running out of air or fully deflated, the TPMS will warn you. 90% of the time with Non RFT, when you got nailed, you can always just drive off to the nearest gas station or tire shop to get it plugged. Just don't pull out the nail or screw, and the tire pressure will hold up pretty good. If no nearest tire shop around, you can just add more air until the next stop. Even so you are on RFT, by the time it is low on air, you can only drive so far at 55mph and I believe, you can't re-use the tire anymore. Lastly, both RFT and Non RFT will not do any good on sidewall tear or puncture. In this case, the only option will only be spare tire or tow truck.
P111569.00 |
10-10-2016, 10:39 PM | #3 |
Rep 18,712
Oh, and Non RFT in general will give you better ride.
P111569.00 |
10-10-2016, 10:45 PM | #4 |
Rep 11,136
10-10-2016, 11:06 PM | #5 | |
Rep 18,712
The lower the number, the faster it will be worn out.
10-11-2016, 08:42 AM | #10 |
Rep 11,136
10-11-2016, 08:56 AM | #11 | |
Rep 18,712
If you want to last longer, get the all season tires. I believe the summer / sport tires on the 20" are rated at high 200's or low 300's. The all season tires in general is rated at 400's, which should last you about a minimum of 35k miles.
10-11-2016, 11:37 AM | #12 | |
Rep 509
RFTs are horrible for the X5 M. The car was not intended to be driven on RFTs. RFTs disrupt the handling characteristics of the car. I would not recommend. It seems lots of users are getting great wear out of their Michelin PSSs. It's a great tire. Highly recommended. |
10-11-2016, 11:47 AM | #14 | |
Rep 11,136
The spare you're referring to, is that the standard spare tucked away under the floorboard of the boot/trunk? |
10-11-2016, 11:53 AM | #15 |
Rep 509
Yes. That's the one.
10-19-2016, 04:37 AM | #17 |
Rep 193
im using the Michelin pilot super sports on the x5m , any one have any experience switching to the pirellis . any noticeable differences? i need a new set so worth getting some opinions
10-19-2016, 07:50 AM | #19 |
Rep 11,136
10-19-2016, 12:49 PM | #20 | |
Rep 509
The Pirellis are harder and noisier. The main flaw, in my view, is that the tires do not give the level of control found in the Michelin. Stated differently, the Pirellis do not allow the same precision steering as compared to the Michelins. Driving with the Michelins tracked true to the direction of the steering wheel. The Pirellis feel as though you are perpetually hydroplaning. You have a tendency to drift even on dry and smooth pavement. I am informed that this is a characteristic of the RF tire. I do not recommend. The Michelins are exceptional. FWIW, my SA told me that the Dunlop RF tires (in 21") are even worse and wear quicker than the Pirellis. |
