11-02-2014, 09:18 AM | #23 |
Rep 18,715
@opasha, i'll use the same route as @mysticblue explanation, except I use one of the cigarette plug on the behind of center console. I don't use the Powermagic thing, because I've read somewhere that it may damage the SD card.
I'll take some pictures next week and explain the whole thing.
11-02-2014, 10:07 AM | #24 | |
Rep 3,990
@MysticBlue, thank you for that detailed info, buddy. Much appreciated.
11-17-2014, 01:52 PM | #25 | |
Rep 450
For the passenger footwell fusebox you need a mini one as it only contains mini blade fuses, the rear fusebox has both normal size and mini blade fuses in it. |
12-08-2014, 06:14 AM | #26 |
Rep 500
Can anyone recommend a switched power circuit in the front fusebox? I'm getting ready to install my Laser Interceptor and am planning where to get power from. I already have my V1 tapped in to the rear view mirror circuit, so I'm looking for a different power source.
12-08-2014, 07:28 AM | #27 | |
Rep 3,990
12-08-2014, 08:31 AM | #28 | |
Rep 500
12-09-2014, 06:41 PM | #29 |
Rep 500
OK, so I found out that fuse #42 (for the UGDO and PDC) in the front fusebox is switched power and shuts down immediately when you turn the car off.
12-09-2014, 06:44 PM | #30 | |
Rep 450
12-09-2014, 06:52 PM | #31 |
Rep 450
Where do BMW hide that fusebox, I've found the BDC fusebox containing fuses 1 thru 14 behind the side panel in the passenger footwell on a RHD F15 but I'd much prefer to run my camera from a switched supply rather than a permanent one as my F15 complains about excessive battery drain if I don't drive it for a day and leave the camera connected.
12-09-2014, 06:54 PM | #32 | |
Rep 3,990
Rheingold ISTA/D .
12-09-2014, 07:23 PM | #33 | |
Rep 500
12-10-2014, 05:18 PM | #34 | |
Rep 450
12-10-2014, 11:19 PM | #35 |
Rep 1,746
Interestingly, this thread lacks pictures that it desperately needs.
I am only saying this because I have been dying to get one of those piggy backs that @NPickles linked so I can wire my dashcam to it (if I can't get power from behind the mirror.. that reminds me, I have to visit that thread to see what happened there..)
12-11-2014, 08:21 AM | #36 | |
Rep 500
Disconnect the cable that goes to the light by pulling the connector straight out. Then look up and you'll see the fusebox. You can see my piggyback fusetap in the picture.
12-11-2014, 10:34 AM | #37 |
Rep 450
12-11-2014, 11:06 AM | #38 | |
Rep 1,746
Thanks, I just opened that area (was so glad that it didn't use screws like the panel on E70) to run my dashcam behind the center console and out into the ciglighter port. Where did you place your interceptor? Somewhere up high or by the center console? Just curious because I wanted to know how you ran the wire. Also, I am very interested to hear about your rearview tap, you are strictly getting power from there, right? Nothing else? I know there are some couplers back there, but I am not comfortable splicing into the existing wires, if there was an easy way to just add a piggyback just like fuse box that would be great. I am trying to do this because I am worried that my current cord might interfere with side airbags since I am going around the A pillar to go down.
12-11-2014, 01:20 PM | #39 | |
Rep 500
If you do decide to run a wire down the A-pillar I wouldn't worry about the airbags. They'll just knock the cable out with the A-pillar cover. You might get whipped by the cable, but that's about it.
12-11-2014, 01:51 PM | #40 |
Rep 3,990
12-11-2014, 02:36 PM | #41 | |
Rep 1,746
That cord looks like just a power cord with stripped end. It's a great option if you don't want to mutilate your existing one, and of course it helps when you get an aftermarket one with correct polarity. My dashcam uses MiniUSB so I guess I can do the same with one of my old mini USB's lying around. I am not very technical, so this may sound like a dumb question , does the voltage supplied by this fuse & fusetap same as the cigarette lighter port? So anything that is plugged to lighter port can be stripped to bare wires and tapped to same switched fuse regardless of the amp it draws?
05-28-2015, 02:29 AM | #42 |
Rep 5
Thanks for this wonderful thread. Mine is also RHD. After struggling in finding the front fuse box (I even opened the area for the BDC unit on the left side), this thread helped me find my front fuse box finally, though it's not as easy as the LHD model because I had to use both T20 and T25 screw drivers to remove the bottom cover under the steering wheel.
05-31-2015, 09:17 PM | #43 |
Rep 5
Here are some pictures for uncovering the right hand drive model's front fuse box. This thread did help me locating it - not easy as it needs to remove three T25 screws under the steering wheel plastic cover (not the twisted plastic buttons under the glove box on the left hand drive model).
06-01-2015, 05:35 PM | #44 |
Rep 450
Finally, someone found the other front fusebox in the RHD model.
Why is it BMW makes it so hard for us RH drivers compared to the LH drivers in the US |
