02-10-2023, 02:37 PM | #1 |
Rep 48
Badge sizes X6M 2018
Featured on BIMMERPOST.com Haven't received my new/old X6M yet, but would like to order up some blacked out badges for the hood and trunk. Could one of you out there confirm if they are 74 or 82mm(or both)? Thanks, Regards, Sean |
02-10-2023, 04:16 PM | #2 |
Rep 7,359
Shop for them using their correct 11 digit BMW part nbr...it will cut down on the possibility of ordering the wrong part. Just add "black" to the search description along with BMW xx xx x xxx xxx (where x=the actual part nbrs).
Here's a direct link to the part database where you can get the 11 digit part nbrs for both the front Roundel (#1) and the rear Roundel (#2) for the f85 X5. dont forget to order new grommets (#3), too. Once you've used them...they aren't as good for a 2nd or 3rd mounting...think of them as if they were condoms:
02-10-2023, 11:56 PM | #3 | |
Rep 48
Thanks, I have actually tried that somewhat, but the problem is that a lot of the returned results then go on to specify 74 and 82mm. Thanks for the tip on the grommets. |
02-11-2023, 08:51 AM | #4 |
F15 daddymobile
2330
Rep 3,496
IND?
