      08-09-2017, 01:48 PM   #1
Tditchmondx5
Tditchmondx5's Avatar
Drives: Bmw x5
Painting exhaust tips black??
I have a white 2015 x5 m package and wanted to get the exhaust tips painted black. Wondering if anyone that has done that has pictures?? And What shops would anyone recommend to get that done in the Vancouver bc, lower mainland area??
      08-09-2017, 07:36 PM   #2
Dirty Cash
USAF Retired
Dirty Cash's Avatar
Drives: F15.50i
It's one of the simplest DIY's you can do.
Get some VHT paint, masking tape and some good masking paper (or newspaper) and go to town.
***Rubber gloves and a well ventaliated area while painting should go without saying, but...***
Of course, having the exhaust tips pulled and prepped/painted is probably the way to go if you know how or want to get that deep. But, it can be done with careful masking and application of several light coats until you achieve the look you want.
Appreciate 5
d_v_o_1111.00
1230vani651.00
DuSh2113.50
deutsch1003940.50
      08-09-2017, 08:57 PM   #3
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Nice!
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      08-09-2017, 11:58 PM   #4
clemsonee
clemsonee's Avatar
Drives: 2015 BMW X35d
Did you do any other prep work besides masking such as using a brake cleaner to remove soot or sand the pipe at all or just start spraying once you had a clean surface?
      08-10-2017, 07:49 AM   #5
Dirty Cash
USAF Retired
Dirty Cash's Avatar
Drives: F15.50i
I didn't do any prep work outside of making sure the tips were clean (just washed the X as normal and made sure the tips were dry inside and out). Since the VHT contains a primer, I skipped any sanding of the surface (mine were in decent condition).
      08-10-2017, 07:51 AM   #6
Kzang
Kzang's Avatar
3239
Drives: 2015 X5 35i Msport SG
Many have done a DIY on the exhaust tips myself included using VHT engine enamel spray paint 4 coats ( about 10 minutes wait time for each coat to dry ) and 3 coats of VHT clear coat.
Since I have the MPE exhaust, I was able to remove the tips for painting and I did sand the surface on my tips and wiped it clean with rubbing alcohol.
Appreciate 5
FamilyMan142.50
Jenya B144.00
DuSh2113.50
deutsch1003940.50
DMM26.00
      01-17-2018, 01:16 PM   #7
E30toF30
Drives: 2016 528i Executive Edition
This looks fantastic.
Did you use the gloss black engine enamel and then the gloss clear on top? Or did you do the flat black enamel then the gloss clear?
Looking at the different options here:
https://www.amazon.com/dp/B000CPCRE0...ing=UTF8&psc=1
Thanks!!
      01-17-2018, 01:23 PM   #8
MN2///M
MN2///M's Avatar
Drives: very fast!
Taking the tips to a powder coat shop would be another option; might hold up better in the long run.
2003 BMW 330i
2016 BMW M4 - ED May 2016, PCD Aug 2016
2017 X5 xDrive35i - PCD Jan2017
      01-17-2018, 01:25 PM   #9
Kzang
Kzang's Avatar
3239
Thanks!!
Thanks and yes, I used the gloss black VHT Engine Enamel and then Gloss Clear on top. I sanded the chrome surface and did 4 coats of the black gloss with about 10 min dry time in between coats and then applied 4 coats of Clear coat of the same brand.
One tip is to spray lightly at first and move the spray can fairly quickly so that you aren't over spraying certain spots. smooth consistent movements is key for a nice paint job.
      01-17-2018, 01:46 PM   #10
CeeTeeX5
It would definitely hold up better but those of us with stock exhausts do not have tips that can be removed without sawing them off of the muffler. Which is why those that do not have the MPE are spraying them while still on the car.
Kzang3238.50
      01-22-2018, 08:47 AM   #11
anon1000
Drives: bmw
I removed the bumber, way easier that way, and you get a better finish.
      01-22-2018, 11:59 AM   #12
CeeTeeX5
How difficult is removing the bumper? Have a DIY guide?
      01-22-2018, 01:19 PM   #13
Wtfitzvi
Wtfitzvi's Avatar
Drives: ...
Can the exhaust tips be removed easily? Or is it very labor intensive?
CURRENT: 97 E36 | 15 Huracan 610-4 | 18 F80 Competition | 22 F95 Competition | 24 G80 Competition | 23 Escalade | 24 Civic Type R
      01-22-2018, 01:58 PM   #14
Kzang
Kzang's Avatar
3239
Only if they are M Performance exhaust. Otherwise you would have to cut them off or remove the whole muffler system.. Or just remove the rear bumper.
      08-02-2018, 12:30 PM   #15
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Anyone experience the issue of the paint drying grey. Only does it on my driver side.
'06 C55 AMG (sold)
      08-02-2018, 01:37 PM   #16
aracka
Drives: 2015 X5 X50i
man thats odd...which paint did you use?
2015 X5 5.0 | Space Gray | Driver's Assistance + | Luxury Pkg | Executive Pkg | Lighting Pkg | ACC | DHP | Nightvision | Multi-Contour
      08-02-2018, 02:27 PM   #17
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Some things can't be explained. I would grab a can of different brand of black paint, but it's easy for me to say when your car is disassembled.
      08-02-2018, 03:07 PM   #18
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
I ended up just putting a clear coat on and then a few more black layers and that seemed to fix it.
Then this happened.
Fuk my face.
'06 C55 AMG (sold)
Russmov1328.00
      08-02-2018, 03:31 PM   #19
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Then this happened.
Fuk my face.
Last step is always the hardest. I'm sure you were thrilled
2016 BMW X4 xDrive 28i-Sold
2014 Lincoln MKX-Sold
      08-02-2018, 03:32 PM   #20
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Oh man. You even took the bumper off to do the job properly. Hang in there man.
      08-02-2018, 05:08 PM   #21
Localbrew
Localbrew's Avatar
145
Drives: 2015 X5
Well that's not as bad as my morning...nevertheless I spoke to the body shop and they will paint my exhaust tips black when they have it all apart. Good news is she accepted fault and insurance is already on board with the claim etc. So my guess is it will be in the shop next week...Oh and now the fun part is I get to figure out how they calculate diminished value because mine was accident free.
Russmov1328.00
      08-02-2018, 05:11 PM   #22
tkelley86
tkelley86's Avatar
252
Drives: 2021 X7 M50i
Shyttttt! Time for an M rear bumper?!
Maverik2594140.00
