10-12-2017, 07:23 PM | #1 |
Rep 4,532
Tested the X5M Air Filter on the Flowbench
Almost gave in to mod temptation and bought a Dinan. Looks killer but they would not give me any info other than the Dinan Lid/Filters + Dinan Muffler + Dinan Stage 2 Tuning added 23 engine HP at 5000 rpm and added 14 engine HP at peak. I just wanted the dyno on Dinan Lid/Filters only. Never received it. Still love Dinan since I use their DME on the wife's 35 and it works great, but I want numbers.
So I bought a 50i air filter to destroy and took my M filter off to test. The 50i air filter has the exact same dimension at the M inlet...more on that later....a few pics.. |
10-12-2017, 07:28 PM | #2 |
Rep 4,532
You can see from the above pics (some turned sideways for some reason) the inlet of the 50i = M inlet. M filter has a larger filter media on the front section and it really helps airflow !
The control orifice is the oval inlet. THAT is what I wanted to test. Does not matter what you do for a filter after that point if the inlet is maxed out. So I tested the stock 50i, the M and then cut the 50i down to the inlet and flow tested the inlet....a few more pics... Last edited by onfireX5; 10-12-2017 at 07:54 PM.. |
Ibiza3611.50 |
10-12-2017, 07:45 PM | #3 |
Rep 4,532
(pics keep posting sideways...sorry).
On to the results: H20 50i M CUT 1.5 137 153 180 6.0 267 312 345 12.0 381 451 487 So for a 50i, a cheap upgrade with a nice flow increase is the M Filters. If you totally REMOVE the M filter from the M Airbox, you will pick up 30-36cfm per filter (2 filters in the airbox). I see that K&N and BMC have replacement filters, but they are based on the smaller front media of the 50i filter. Will fit, but doubtful the higher flowing media will make up for the loss in filter area. The jury is still out on Dinan. If the filter is awesome, you have a chance to increase up to 30ish cfm per filter . A nice , cheaper alternative would be an aftermarket filter based on the M design. M did a GREAT job on this design. Not much left on the table. Ben, find us an aftermarket filter with the larger M front section ! Last edited by onfireX5; 10-12-2017 at 07:56 PM.. |
10-12-2017, 08:02 PM | #4 |
Rep 4,532
BMC and K & N replacement filters. What a shame they are based on the smaller front sized 50i filter. M filter will fit a 50i box (I installed a set) and would have been the perfect base to use for both the 50i and M. Bummer.
10-13-2017, 07:37 AM | #7 |
Self-Deprecating Narcissist
7266
Rep 6,561
I had the BMC filters on my 50i M-Sport, now on the X5M I have the Dinan intake with tune. If I may help your research in some way please let me know.
http://f15.bimmerpost.com/forums/sho...5&postcount=34
10-13-2017, 08:21 AM | #8 |
Rep 4,532
Cool offer. Thanks. I might buy a Dinan since it should add the last 30ish cfm to the flow. I’ll put it in the flow bench if I get one. Still on the fence. A cool , stealth upgrade would be the filters only on the M frame but I have a feeling no one makes that. K&N and BMC missed the mark.
iconoclast7265.50 |
10-13-2017, 12:27 PM | #9 |
Rep 4,532
Fell off the fence and bought a Dinan to test from Ben at RGSport.
RGSport is by far my favorite BMW vendor ! Will report flow bench results Tuesday night after it arrives. |
4
10-13-2017, 01:48 PM | #10 |
Rep 18,713
onfireX5 , Greatly appreciate the support for my business and the community.
Looking forward on the result.
iconoclast7265.50 Ibiza3611.50 |
10-16-2017, 07:04 AM | #11 | |
///M
133
Rep 184
Drives: M8C/Taycan Turbo/Roadster 2.0
I was REALLY impressed with the size of the filters compared to stock when I swapped out my intake for the Dinan. Hope your testing backs it up! |
10-16-2017, 07:47 AM | #12 |
7266
Rep 6,561
Even if the filters alone do not increase air flow substantially the engine note and the sound of the turbos spooling is worth it alone however paired with a tune it's a no-brainer and a must-have (IMO).
11-05-2017, 11:09 PM | #13 | |
Rep 184
Any updates??
2016 X5M
JB4, DME Tune, Full Custom Fab Worx Exhaust w/ Straight Pipes and Cutouts, KW V3, 22" BC Forged Wheels, Brembo BBK on all 4 corners |
11-06-2017, 06:28 AM | #14 |
///M
133
Rep 184
01-10-2018, 09:53 PM | #16 |
Rep 4,532
Yes it will.
kimsta4.50 iconoclast7265.50 |
01-12-2018, 08:51 AM | #17 | |
Rep 18,713
But, the CF cover may not. Dinan says the S63tu engine sits lower than the N63tu.
01-13-2018, 08:28 AM | #22 |
Rep 4,532
