12-20-2017, 08:01 PM | #1 |
Rep 471
Could I trouble someone with a 2014 X5 to take a picture of their rear, middle headrest (picture taken from the drivers side, rear door entry would sync up with the angle I have) please? Also, can you confirm the operation of the headrest is as follows: To raise, just lift up ... to lower you push in the little button near the shaft of the headrest.
In a "situation" with my dealership that frankly I don't have the strength to explain right now after a frustrating few days with the dealership. Thanks in advance. |
12-20-2017, 10:50 PM | #2 |
Rep 7,160
Lol this sound awesome. Wish I could help. Home in FL while X5 back in VA.
12-21-2017, 02:56 AM | #3 |
Rep 783
Does the rear central head rest go up. Don't seem to be able to shift it
Old Wheels - X5M50d in Carbon Black
New Wheels - X7M50d in Phytonic Blue |
12-21-2017, 07:31 AM | #4 | |
Rep 471
So I'm trying to obtain a picture of someones that works properly and in the correct orientation. Here is a picture of mine. Last edited by Florida-X3; 12-21-2017 at 07:57 AM.. |
12-21-2017, 10:25 AM | #5 |
Rep 1,181
Stupid app. Having probs posting s pic.
However, it does look like yours is on backward. Just look at how the headrest protrudes forward beyond the plane of the back seat. If it were to be turned around, it would be relatively flush like the outboard headrest. As for removing it... it just takes A LOT of force. Installing it backwards would not prevent it from being moved. The two posts are solid/smooth and there are only two notches at the very bottom that snap/lock into place when fully depressed. If it were installed backwards, the release button just wouldn't snap since there are no notches to mate with. Sooooo, just try again to remove it yourself. You'll get it off. You could use something like the handle of tool as a wedge/pry bar. Protect the leather with a towel or something.
12-21-2017, 10:27 AM | #7 | |
Rep 471
12-21-2017, 11:49 AM | #9 |
Rep 471
12-21-2017, 12:56 PM | #11 |
Rep 2,700
Very interesting thread! Why? Because just two days ago i wanted to pull it out and could not, also the service advisor could not, so i tried to do it on a showroom car as well also without success. Was told by service advisor that probably only a mechanic could do it with tools but he wasnt sure. Also the thing you click in on the right hand side does click in but i could not locate one for the other side (metal bar). I gave up in the end. Tried to do it on a 6gt in the showroom and ot worked right away.... EDIT: found the other click on the left bar but still could not do it.
12-21-2017, 01:02 PM | #12 | |
Rep 1,181
Trick is to wedge your finger underneath enough to push the button and raise the headrest just enough to get past the detent. Then use both hands to equally push up (vs only one side/post). Like I said earlier, it took a lot of force. The headrest went flying off into the rear of the car, actually.
1230vani651.00 |
12-21-2017, 01:15 PM | #13 |
Rep 865
Here's another picture. I also could not get it to raise though....will see if what my dealer says the next time I'm over by them.
2003 BMW 330i
2016 BMW M4 - ED May 2016, PCD Aug 2016 2017 X5 xDrive35i - PCD Jan2017 |
retx117.00 |
12-21-2017, 01:28 PM | #14 |
Rep 471
Well if it operates like the left and right ones you should not have to do anything to raise it, just pull it up. You push the recessed button to remove it or go down.
I just got a call from the Service Manager and he was very apologetic about the whole thing, they didn't rotate the tires either (white grease pen comes in handy for that). He offered to have a driver come to my house, leave a loaner and take my X5 back to the shop (about 40 minutes away and crazy traffic areas) and then return it. While I appreciated the effort I didn't want some stooge tech beating my vehicle. So I will be taking it back next week, was told to ask for him and they will streamline it through. I'll post an update here after it's taken care of to report just how that stupid headrest is supposed to work. |
12-21-2017, 02:02 PM | #15 |
Rep 865
Left and right outer ones are easy to raise; according to the manual:
"The center head restraint cannot be adjusted in elevation" Guess the manual is the answer to all things....go figure.
2003 BMW 330i
12-21-2017, 02:14 PM | #16 | |
Rep 471
1230vani651.00 |
12-21-2017, 02:57 PM | #17 |
Rep 1,066
Drives: 2015 X5 50i M Sport
Definitely backward. The stitching lines aren't even aligned with the other headrests.
2019 Cayenne Turbo
12-21-2017, 04:03 PM | #18 |
Rep 783
No mine is definitely on the right way round but what ever I do I cannot raise the bloody thing What is the point when you have someone sitting in the rear middle seat! Another BMW flaw on an £85k vehicle
12-21-2017, 04:13 PM | #20 |
Rep 471
Welcome to the club! Interesting, so far I don't think that anyone who has it installed correctly can raise it.
12-21-2017, 04:18 PM | #21 |
Rep 783
At my age getting anything to raise is the highlight of my day!?!?
12-21-2017, 05:45 PM | #22 | |
Rep 1,181
Like I said prior and as the manual shows, you can raise it for removal. With the amount of force needed to remove it this morning, I'm sure if I left it raised a bit, the headrest would not go back down on it's own. Car is not with me ATM, but will check the posts on the outboard headrests tonight to confirm differences, if any, from the middle one. Edit: confirmed that the outer headrests have multiple notches/detents in the posts and slide up/down easily; the center headrest posts must be a tad bit thicker in diameter, hence why it doesn't raise very easily
