01-09-2018, 08:55 AM | #1 |
Rep 41
2017 X5 Navigation stopped working
Hi,
Any1 experienced an issue when all of the sudden the navigation won't turn on? No error message of any sort... I see the "Navigation" icon in the menu, but when i press it, nothing happens. The map/nav button don't do anything. We had a pretty bad, freezing week here in Philly.. im talking -2F at night... could it be that the hard drive failed? Please let me know if you experienced something like this. Thanks |
01-09-2018, 12:06 PM | #2 | |
Rep 177
01-09-2018, 12:09 PM | #3 | |
Registered Member
661
Rep 608
01-09-2018, 12:14 PM | #4 |
Master of my own domain!!
152
Rep 1,050
We had an issue with our X5 navigation turning off at random times for no reason. BMW fixed it and mentioned there was a service bulletin out on it. You will lose all coding.
01-09-2018, 12:31 PM | #5 |
Rep 41
01-09-2018, 12:33 PM | #7 |
Rep 41
And this is what I am trying to avoid... don't feel like re-coding everything afterwards and I hope that dealer won't give me crap for having any codes done. Technically they shouldn't be able to see it in the first place, right?
01-09-2018, 02:31 PM | #10 |
Rep 41
01-09-2018, 02:42 PM | #11 | |
Registered Member
661
Rep 608
01-09-2018, 03:32 PM | #12 | |
Rep 41
01-09-2018, 03:58 PM | #13 | |
Registered Member
661
Rep 608
The freeze was likely due to whatever crap the local full service gas station was adding to the washer fluid tank when my wife would stop for a fuel up, because why would they actually use the good stuff when they can save themselves a little money by using the cheapest stuff. |
01-11-2018, 06:32 AM | #14 |
Rep 43
Drives: 2017 X5 35i
I had a similar issue with my 2017 X5. I rebooted the system by pushing in the volume bottom for about 20secs. After reboot, everything worked as normal.
Give it a try |
1230vani637.00 |
01-18-2018, 09:59 AM | #15 |
Rep 2
Hey alik, did you end up fixing the problem? My dad's X5 had the exact same issue that started about a week ago. I'm not sure what happened, but out of the blue both the navigation and siriusxm radio stopped working. It also got really cold here in Canada, -25 C or so.
I tried resetting by holding the power button, but didn't resolve it. Next step is of course taking to the dealership but was hoping for a quick fix. |
01-18-2018, 11:20 PM | #16 |
Rep 9
There is an anti-theft feature that gets activated erroneously (by no fault of yours). As a result, you can't click on Navigation, as well as Satellite radio (if equipped). The dealership can have it reactivated. They'll probably program the car to the latest software level too.
07-21-2018, 09:02 AM | #17 | |
Rep 53
Drives: M6 Coupe, X7. I3
Garage List 2021 BMW X7 [0.00]
2017 M6 Coupe [0.00] 2017 X5 M50D [0.00] 2012 BMW M3 [0.00] 2009 X5 XDrive35D [0.00] 20047 Z4 SE Sport R ... [5.00] 2008 335i M Sport C ... [0.00] |
_
07-21-2018, 09:05 AM | #18 | ||
Rep 41
04-26-2022, 02:57 AM | #19 |
Rep 1
Hi,
First, sorry in advance for my english, I'll try do do my best (I am french). And sorry for posting in an old thread... I have got exactly the same issue on my X6 F16 since a few days. And it is quite annoying because I have to sell the car next saturday. Yes, cars have a soul... Mine knows I will sell it so "she" 's starting to piss me off. I tried several things to fix the issue : - roll-back on an update I did some time ago : still not OK - new update : still not OK - iDrive reset : still not OK - unplug the battery for half an hour : still not OK - check the GPS fuse : the fuse is OK I know the GPS is working because when I configure the split screen to the position view, it displays the GPS coordinates. But as soon as I configure the nav view, the right side of the screen keeps black. So I'd like to know if anyone has other idea I could try before bringing the car to the dealer. Indeed, my dealer has no time to check the car before next saturday... and I would not like to cancel the selling ! Thanks in advance for your help... |
06-02-2023, 04:21 PM | #20 |
Rep 5
Had the same issue with the navigation and satellite radio not functioning all of a sudden after 5 years running fine.
For history: It did reboot automatically a couple of times in the past week and then the screen went dark one day. After a few drive cycles it came back on but the nav and SiriusXM satellite was not working. Shows on the menu but just isn’t there. (Navigation is greyed out and satellite menu shows up but nothing happens when you select it just a blank menu). I rebooted several times (and yes you can reboot while the car is on and even when you’re not in accessory mode, car turned on). I checked the battery in the trunk. All looked good, put it on a trickle charge but was fully charged within minutes. I checked the split screen and did see coordinates and position so knew the gps was working. I updated the software (.bin file) to the latest revision (thru usb and bmw website) and that didn’t solve it. I then repatched with a carplay mod .bin file I had from years ago and it magically started worked again. Just tossing this post in here in case others have the same problem in the future. Worth a try! Will repost if something changes but if not consider it worked….! |
