01-15-2018, 06:20 PM | #1 |
Rep 1,180
22x9 and 22x10.5 Tire Sizes
Hi All,
Bit on the Vossen sale and ordered a set of wheels but now I'm struggling to figure out what the right tires sizes should be. I was thinking of running 285/35s all the way around but now am thinking 285s will be too wide for the 9" front wheels. Anyone running a 285 on 9" wheels? The other option I am thinking is 265/35 Front and 295/30 Rear. The only issue is that the Front will be about 1% larger than the Rear...will this cause any major issues with xDrive? Any other thoughts on available tire sizes that will work? I don't really want to go any narrower than 265 up front if possible. TIA! |
01-15-2018, 06:43 PM | #2 | |
1027
Rep 24,709
Drives: BMW E39 M5, F10 M5, F80 M3
-Steve@N4SM |
01-15-2018, 06:45 PM | #3 | |
Rep 1,180
01-15-2018, 07:21 PM | #4 |
1027
Rep 24,709
01-15-2018, 07:49 PM | #5 | |
Rep 2,388
1% bigger front tires are no issue |
01-15-2018, 07:57 PM | #6 |
1027
Rep 24,709
01-15-2018, 08:04 PM | #7 |
Rep 2,388
01-16-2018, 12:52 PM | #8 |
Rep 1,180
Found some staggered tires in the following sizes:
265/35/22 FR 295/30/22 RR OR 275/35/22 FR 315/30/22 RR Will a 275/35/22 stick out too far on a 22x9 front with 15 offset?? Can't seem to get a clear answer from the calculators. Wheel specs: 22x9 ET15 FR 22x10.5 ET20 RR |
01-16-2018, 02:51 PM | #9 | |
Rep 2,388
Your setup (275/35/22 on 9 inch wide rim with 15 offset) will be about 8mm (1/3 inch) more sticking out (mostly due to your rim offset) compared to above stock size setup. If you have fender flares - that's not going to be an issue at all Last edited by DuSh; 01-16-2018 at 05:31 PM.. |
01-16-2018, 11:15 PM | #10 | |
Rep 1,180
Just trying to convince myself it'll be ok and I won't have tires poking out from the fenders. Thanks |
01-16-2018, 11:30 PM | #11 | |
Rep 2,388
However, keep in mind stock 21 inch wheels with 285/35/21 are not even close to be sticking out if you have fender flares. People use spacers to get them flash |
CeeTeeX5936.00 |
01-16-2018, 11:38 PM | #12 | |
Rep 1,180
http://f15.bimmerpost.com/forums/sho...=923595&page=5 |
01-16-2018, 11:40 PM | #13 |
Rep 2,388
This is what i mean: on this pic you can see x5m (same wheel fitment exactly as x5) with stock 21 oem bmw wheels 285/35/21 front and 325/30/21 rears - you can see that with fender flares they look recessed - not even close to been sticking out. That's why people put spacers to at least get them flash. So in your case - it will be similar as to having 12mm spacer - just ideal IMHO, but if you are looking for stock looks - then yes, maybe go with something less aggressive
01-16-2018, 11:42 PM | #14 | |
Rep 1,180
DuSh2113.50 |
