01-20-2018, 08:08 AM | #1 |
Rep 35
Verde Empire
Anyone have experience with these?
VERDE® - EMPIRE Matte Graphite (20" x 10", +42 Offset, 5x120.65 Bolt Pattern, 74.1mm Hub) more details on - https://www.carid.com/cart.php |
01-20-2018, 08:09 AM | #2 |
Rep 35
01-20-2018, 05:24 PM | #3 | |
Rep 982
01-20-2018, 06:46 PM | #5 |
Rep 2,388
This is their ebay store: https://www.ebay.com/itm/Verde-Empir....c100011.m1850
It's a usual average quality wheel. It will fit. Weighs 36.1lbs - which is not bad for a 20'' rim. Check their warranty and go for it if you like design and color P.S. 42mm offset is 5mm closer to brake calipers compared to stock 37mm offset - but it will fit without issues - there's more clearance than 5mm |
01-20-2018, 08:33 PM | #6 |
Rep 35
01-20-2018, 08:34 PM | #7 |
Rep 35
Sorry for the previous bad links.
01-20-2018, 08:51 PM | #8 |
Rep 2,388
Just one more thing to keep in mind, tho I'm sure it's going to be fine: rims with tiny thin spokes like in that Verde Empire - they look good, but we have 5300lbs vehicle and depending on your local roads may break, since they are usually not really rated for such heavy cars. It's rare, but it happens, so make sure they have 50i in their supported vehicle lineup and that they have structural warranty
01-21-2018, 09:14 AM | #9 |
Rep 35
So...
Since the offset is 5mm off should I correct that with a spacer? |
01-21-2018, 09:55 AM | #11 |
Rep 35
P1et
No sir on the oem...prefer this style of wheel that BMW does not offer. I think they will look great on my space gray 50i You and I will have to differ on their aesthetic value. |
01-21-2018, 09:59 AM | #12 |
Rep 35
01-21-2018, 10:39 AM | #13 |
Rep 1,180
Check out VMR or Avant Garde. Similar in design and a lot of bmw drivers running them. I think Avant Garde are low gravity cast so should he stronger than your standard cast wheels.
01-21-2018, 01:07 PM | #14 | |
Rep 2,388
Many of us here run 5mm/15mm (front/rear) spacers from rg33 just to make it look flash (or more aggressive than stock recessed look), but we are staggered and have fender flares IMHO - I would not rush buying something until you are 100% sure you want that look - easy to buy, but very hard to sell if you quickly realize you didn't like the looks. I would start by checking photos of a setup you like mounted on the x5 and then adjust a bit with spacers if you want a bit more aggressive look 20 inch rim is a nice choice - cheaper tires and wheels weigh less (not sure if it's important for you - dynamics). However, if I was to redo it - I would go for 21 or 22 with lightweight forged rims - expensive, but you do it once and do it right imho |
fosterelli236.50 |
01-21-2018, 06:29 PM | #15 |
Rep 35
Wow like the VMR V710.
Who is a good wheel tire vendor? |
01-21-2018, 10:28 PM | #16 |
Rep 979
I had VMR 710 on my m3 for winter wheels, my friend is now running them on 335 for winter rims. The are good quality and have held up for many years now Of winter driving.
They are a good choice.
01-21-2018, 10:40 PM | #17 |
Rep 1,180
02-13-2018, 09:24 AM | #18 |
Rep 35
What do you think?
02-27-2018, 10:48 AM | #19 |
Rep 445
Drives: 2018 X3 M40i
Location: Milky Way, Earth, North America, Arizona more specifically.
02-27-2018, 10:53 AM | #20 |
Rep 5,066
Looks hot! but I think you should of gotten 22" or even 21".
Those looks really small in proportion to the car.
