      11-04-2019, 10:53 AM   #793
pennsiveguy
pennsiveguy's Avatar
Drives: F15 xDrive50i M-sport
Originally Posted by bmrmadness View Post
This is my first entry and need some help.
Since I bought the car (2016 X5 3.0) new it pulls quite a bit during lane changes. I took it back for 2 wheel alignments and the pulling lessened but was still there. I wrote this off to the poor quality OEM tires which only lasted 35k km. Have since changed the summer tires and the new tires still pull.
Changed to my winter tires a few weeks ago and the pulling was so dramatic that I took it in last week for a wheel alignment. It was out of alignment and now has improved significantly but not gone away.
The dealer has also now informed me of a significant likelihood of transfer case failure due to the different sizes of winter tires on the car. My winter tires are 255 50 19 but last year had a tire shop put 2 new 255 55 19 replacement winter tires on the back due to a nail hole. This was the only size they had in stock. I assumed they would work fine.
Checking the tire diameters I now see that the 55 is 1 inch larger in diameter for a 3.4% difference.
Question - is this an acceptable tolerance for the transfer case or do I need to change the tires to make them the same? Is this affecting the handling of the vehicle and the pulling or is the pulling something else.
Always, always, always have all 4 tires of equal circumference. Any difference (okay, any non-trivial difference) is too much. This is part of what you signed up for when you bought an AWD vehicle. The car wants all 4 wheels to be going the same speed. If that's not happening, the car is going to try to make it happen and will potentially wear out or destroy some of its components in the process of doing so. It could very likely be the source of your pulling.
      11-09-2019, 05:20 AM   #794
DJM911
United Kingdom
Drives: BMW F15 30D M Sport
Just bought an F15 30D, and noticed when I stop the car and put it in P there is a knocking sound. Can only be heard when outside the car. Any ideas? Thanks
2014 BMW X5 30D M Sport 7 Seater - Silver (Current)
2014 BMW 640D M Sport Coupe - White (Current)
2016 VW Golf R DSG 5 Door - Red (Current)
2011 BMW 330D M Sport Touring Auto - Silver Grey (Previous)
2011 BMW X5 30D M Sport Silver Grey (Previous)
      11-09-2019, 06:00 AM   #795
A-4WD
Long Time Bimmer Fan
Drives: 2014 X5 35i
Engage the parking brake before putting the tranny in P, that should do it. This way, the parking brake bears more of the load of the vehicle rather than the transmission. It's cheaper to replace a worn out parking brake.
2014 X5 XDrive 35i - Current
2010 X5 XDrive 4.8iS - Traded
1990 325iS - Sold
1985 318i - RIP
      11-09-2019, 12:12 PM   #796
dds007
dds007's Avatar
Drives: F95, F97, F85, F82
Charging malfunction warning came up and it ended up being the alternator needed replacing. No explanations as to why. Just out of warranty too. 😔
      11-09-2019, 06:18 PM   #797
KingBiscuit
KingBiscuit
Drives: '15 BMW X5x35i/'14 Lexus EX350
New owner with q
New owner here, got my X5 two days ago.
First I'm not sure if I've got a xLine or a Luxury Line. I don't have a sport steering wheel if that helps. Watched videos but not sure about that or certain packages I may have. 18" rims...
Noticed after I got home that exhaust is only coming out of the drivers side. Must have been like that for a while. The tip has a good bit of carbon on it and the passengers side is as clean as a whistle.
Any help would be appreciated!
      11-09-2019, 06:39 PM   #798
splitsensetam
Drives: 2011 535i xdrive
Completely normal with exhaust coming out of the drivers side only. The passenger side only opens up above 60mph
      11-09-2019, 07:00 PM   #799
S777UJA
S777UJA's Avatar
England
9
Drives: BMW X5
Originally Posted by S1OOORR View Post
Although I Just Took Delivery On 4/7/2014 I Been Reading The Forum And Came Across Some Owners Posting There Issues With There F15 Shortly After Taking Delivery, Within The First Couple Hundred Of Miles. I Just Wanted To Start A Thread About F15 With Issues. Im Sure Most People Wont Have A Issue For The Life Of The Ownership Of The Vehicle But Just Though People Can Post And Share Some Of The Problems They Are Experiencing With The F15 Now In This Thread. So If You Care To Share Your Faults With Your F15 Please Do So.
Hi, today I got this tyre pressure warning so I checked the tyre pressure and the rear left was low. I inflated it and made sure all of the tyres are at the correct pressure.
Now when I try to reset this, it just doesn't give me the option to do so. Even with the engine or ignition on. Anyone now why and also could this be resolved with a software update at home?
      11-09-2019, 07:06 PM   #800
KingBiscuit
KingBiscuit
alarm queation
Is there anyway to control the sensitivity of the alarm? People park next to me and close their door and the thing goes off.
      11-09-2019, 07:23 PM   #801
KingBiscuit
KingBiscuit
Wow, thanks! I was worried. Any idea why it's like that?
      11-10-2019, 11:03 AM   #802
djrabbi
djrabbi's Avatar
Drives: G05 M50i
My gas tank falls short of a gallon or two as the lines in the dash is one notch from full... probably a fuel sensor going bad 😩
      11-10-2019, 12:03 PM   #803
MK2018
MK2018's Avatar
231
Drives: 2018 X5 xDrive35i
I have exactly the same, never to the top
Current
2018 F15 M sport x35i
Past
2017 GMC Sierra Denali
2017 GMC Yukon Denali
2016 GMC Yukon SLT
2015 GMC Sierra All Terrain
      11-13-2019, 11:41 AM   #804
droseatwork
Drives: 2013 X1
My office never connects to texts or emails. 2014 X5 50i
      11-14-2019, 10:16 PM   #805
Oilfun
Oilfun's Avatar
Drives: 2018 X5d
Camera system malfunction while driving, error popped up and went away. Dealer checked it out and found no issues; besides the stored fault....
      11-18-2019, 09:40 PM   #806
junmei li
Drives: bmw m2
So, is the BMW not suitable for purchase?
      11-22-2019, 01:52 PM   #807
sajmani
#LetRideBeYourLife
Drives: BMW X5 50i
USB Connectivity
Since the time I got mine, the USB connection has been going bonkers. I have asked the dealer to fix it. They showed me a new part installed it. I have bought several brand new original iPhone cables and still it sucks. Never able to connect the iPhone with USB. So finally I got a 12V charger and use bluetooth. But sometimes, it comes off of bluetooth connection while I am in the call. And starts playing music and after 30 seconds goes back to call. Weird.
Apart from that no issue with my xDrive50i M Sport. Hell of a SUV.
      11-22-2019, 04:10 PM   #808
KingBiscuit
KingBiscuit
I recently purchased a used X5. Nothing I plug into the USB drive is recognized... phone, junk drive, etc. A solution would be nice...
And what is this? Something for my phone missing a part or what...
      11-22-2019, 06:44 PM   #809
mrfochon
Drives: X5 F15 M package
Attachment 2184995
Looking at the tears on the cord in the picture I m not surprised.
Did you try with another cord ?
      11-23-2019, 06:04 AM   #810
A-4WD
Drives: 2014 X5 35i
Attachment 2184995
A lot of X5 have that USB problem including mine. Dealer apparently checked it and found nothing wrong. I'm like did the tech try plugging something into it lol? I just use the power socket with an adaptor now. Apparently it's some head unit that needs to be replaced but I don't see that as being reason enough to allow a stranger to potentially have to remove my centre console for a USB problem when I can use the adaptor instead. I'm on iOS so my phone connects automatically soon as I get in so I only use the adaptor to charge my phone or vape battery lolz.
You may as well remove the phone cradle. It doesn't fit anything larger than iPhone 4 or maybe 5. There are instructions on here how to do remove it. I did mine in like 20 mins. You'll really appreciate not having that cradle in the way.
1990 325iS - Sold
1985 318i - RIP
      11-23-2019, 06:10 AM   #811
A-4WD
Drives: 2014 X5 35i
How about an exterior pic? We'll know if it's Xline or Luxline in seconds then...
1990 325iS - Sold
1985 318i - RIP
      11-23-2019, 09:33 AM   #812
KingBiscuit
KingBiscuit
The phone cradle isn't attached at all, I'll just get it out of the way.
I can't update my software with out putting it on a USB junk drive is my understanding. My phone is connected through Bluetooth. Map updates are another issue, if I figured out the steps to do that I've seen it another post what good would it do with a USB drive that doesn't work...
      11-23-2019, 09:43 AM   #813
KingBiscuit
KingBiscuit
I've gotten the most complete breakdown I could find and still have questions about the options on the car. Seems to have a majority of the options except a few. Seems strange it's lacking a few basic upgrades like lane assist and more than the lowest of the 3 grades of stereo system.
Hear are a few pictures.Name:  BMWFront.jpg
      11-24-2019, 12:43 PM   #814
ems328i
Drives: '14 35i (F15) '14 M135i (F21)
It opens up over a certain rpm rather than a speed, it's supposed to make it quieter at lower revs according to BMW, as it's more a refined car than a sports car. The M Sport exhaust does not have this valve and hence a rortier, louder noise.
Eibach Pro Kit & Lowering Links, RC GTS Black
2014 M135i 3dr
