      12-25-2014, 11:23 PM   #1
Dash52
Drives: 2017 740i Xdrive
Exhaust uneven
So, not sure if I've just never noticed this on other cars I've had with dual pipes, if this is normal to the X5, or if there is actually something wrong, but I noticed last week, when the weather turned cold, that I was only seeing steam out of my driver's side exhaust. When I felt the flow from each, the flow from the driver's side was much stronger than the passenger side. I can barely feel anything out of the passenger side at idle.
      12-25-2014, 11:48 PM   #2
JDoc
Drives: 2015 X5 35i
This is normal with the factory exhaust on the x5. There is a valve on the passenger side that is only open when the engine reaches higher rpm (~4k).
      12-26-2014, 12:29 AM   #3
patrobX5
Drives: 2020 Volvo XC90 T8
Does this also apply to 50i? Kind of weird I guess, don't have that on our current X5 V8.
      12-26-2014, 12:33 AM   #4
JDoc
Drives: 2015 X5 35i
I don't think the 50i or the 35d has that valve. It is only on the 35i afaik.
      12-26-2014, 12:34 AM   #5
No valves in the 5.0 I believe.
      12-26-2014, 09:02 AM   #6
Roundown
Drives: BMW
Google "golf tee mod". What you're seeing is a feature, not a bug, of the N55 set up.
      12-26-2014, 10:02 AM   #7
Dash52
That was an interesting thread, thanks. Has anyone done this simple modification on an F15? Any downside? It bothers me on cool mornings that the right side exhaust looks fake.
      12-26-2014, 10:14 AM   #8
I did remove the spring on mine and leave the flap open.
Not much improvement though.
      12-26-2014, 03:36 PM   #9
Dash52
2015 is not vacuum actuated. The golf tee mod is not applicable. The flapper is electronically controlled.
      02-02-2015, 12:36 PM   #10
Dash52
r33:
How difficult was it to remove the spring? And now that the valve is open do you get even exhaust out of both sides? Thanks
      02-02-2015, 10:15 PM   #11
r33:
I will take the picture tomorrow. I got fellow member dropped by for some mods today.
      02-02-2015, 10:44 PM   #12
Dash52
Thanks...all this cold weather vapor makes it so obvious only one side is open. It looks silly.
      02-02-2015, 10:56 PM   #13
retx
Drives: '18 F15 40e
Be honest to you. Most of ppl have not yet discovered this uneven thing. It is easier for those outsiders to catch their eyes.
      02-03-2015, 07:03 AM   #14
Dash52
I agree, but if you live where it's been really cold, you can see the one sided vapor even in the rear view camera when backing up. It makes the other side look fake.
      02-03-2015, 09:26 AM   #15
opasha
opasha's Avatar
1329
Drives: 2014 BMW X5 50i
Agreed, this is a very silly design. My V6 FX35 with 285hp has a dual exhaust (and an amazing exhaust sound). Why can't BMW implement the same? The only thing I can think of is to save gas .
      02-03-2015, 09:38 AM   #16
Dash52
From the research I have done the flap in the passenger side pipe is called the Active Exhaust System Actuator (AESA). The consensus is that it is mostly for noise control and opens above 4000 rpm and/or at elevated exhaust temps.
      02-03-2015, 09:39 AM   #17
opasha
opasha's Avatar
1329
Thanks for the info, bud. I honestly think "noise control" is pointless considering that the F15 cabin is so insulated/sound proof. If the 35d and 50i don't have issues with noise, what excuse is there for the 35i? Makes no sense to me.
      02-03-2015, 07:38 PM   #18
ydchoe
Drives: BMW X5 F15
@r33 Were you able to take the pictures yet? I am also interested in this. Thanks.
      02-03-2015, 08:38 PM   #19
42pilot
42pilot's Avatar
591
Drives: 2014 X5 35d MSport
This could be like the EXUP exhaust system on Yamaha bikes. Opening up this valve, if this is what it is (EXUP), could actually hurt performance. The principle is to close up or reduce the exhaust size to alter the exhaust pulses (from each cylinder) to make the engine more efficient at idle, off-idle, low and mid power acceleration - yep, increase back-pressure. I owned the FJ1000 Yamaha and quickly removed the system. I also quickly lost low and mid range power in favor of top end. Buying the header was a waste of money because I actually lost drivability and on the track, I lost low-end torque coming out of corners. My first real-world lesson that bigger wasn't better.
You might want to reconsider altering the functionality of this feature, if this is what is designed for. Google (Yamaha) EXUP exhausts for more technical info.
      02-03-2015, 09:47 PM   #20
I'm terribly sorry. I am short 1 guy at the office. Been swamped with work.
      02-04-2015, 12:36 AM   #21
oshiri
Drives: F15 X5 30d
as 42pilot said, if you open up the other one, it will reduce back pressure on the exhaust system. this may cause it to feel more sluggish and less powerful in the lower rev range. this is particularly applicable to turbo'd cars.
its for the same reason that ricers, when they modify their hondas to have louder exhausts by replacing the exhaust system with pipes of wider diametre, lose power and torque despite improved flow.
im not sure how restrictive the stock exhaust is on the 35i and how much of a difference opening that valve would make on the performanec of the 35i, but i dont think its worth it. could also risk having exhaust drone since the resonance at the lower revs will change from what the stock mufflers were designed to be compatible with.
      02-04-2015, 02:28 AM   #22
cenix
cenix's Avatar
Drives: E90 M3 ZCP
I would guess it is for back pressure and sound control, but a lot of manufacturers like Porsche do this too.
