02-23-2015, 03:22 PM | #1 |
Rep 8
2015 X6 (F16) Standard 20" Wheels vs 19" Help
I have been searching the threads and have seen people say that the mixed tires only mean that they are a different size? So does that mean the mixed tires are also all seasons?
I have the two options below without extra charge when building my car. 20" V Spoke Style 597 with mixed tires 19" Y Spoke Style 595 with all-season tires I personally like the look of the 20" more but I think the all seasons are more beneficial for my needs. I just want to know if the 20's come with the same type of all seasons as the 19's. Thanks! |
02-23-2015, 03:56 PM | #2 | |
Rep 666
If you want 20" wheels with all-season tires, you have to get non-RFTs after delivery. I would prefer to have all-seasons, but after 13y of X5/6s with 18s/19s, I wanted 20" wheels more than all-season tires. I guess I'll see how the performance tires work out. I think that my issue will probably be more a tread-life thing than a cold-weather traction thing. |
02-24-2015, 08:02 AM | #3 |
Rep 746
Apparently, you are in Toronto - makes things very simple due to the snow. Either 19" setup, 20" setup with all season tires which you would have to buy and switch, or a separate winter setup. You would be surprised how economic some used OEM sets of X5/X6 wheels go for that could be used as winters. But the 20" will turn your X into a slip and slide without the correct tires.
02-24-2015, 08:08 AM | #4 |
Rep 441
Drives: BMW M135i & 911 GTS
My X6 came with the standard 20" off-set wheels and performance tyres and they are rubbish in ice or snow. I therefore bought BMW OEM 20' off-set wheels and snow and ice tyres (expensive). I could have got 19" OEMs, but they look too small. I did have some old 18" wheels and snow tyres from my E70 X5, but they would not fit over the M perforamnce disc brake (385mm).
02-24-2015, 08:11 AM | #5 |
Rep 746
Quick question on trying to fit the 18s on, what was the issue the caliper size? Do you have a 35i or 50i, is there a difference in the brakes between the two?
02-24-2015, 08:41 AM | #6 | |
Rep 18,715
If you upgrade to the M Performance brake kit or other big brake kit, 20" is the minimum size.
02-24-2015, 09:00 AM | #7 |
Rep 746
OK perfect, just to clarify, the xDrive35i US with just the M sport will suffice with an 18? I dont see anywhere the brakes are upgraded on the spec list.
Thanks |
Tags |
2015, 2015 x6, all season tires, mixed tires, x6 f16 |
