      04-08-2017, 09:01 PM   #1
eggyacid
eggyacid's Avatar
Drives: BMW X5 F15
Few things for comfort access?
Sorry for so many Qs
2014 X5
I thought comfort access, I can set the driver seat to push back upon exit and up once in the seat? Is this a setting? Not seeing it
On reverse... I saw someone's passenger mirror will tilt down, mine won't and can't find it in the manual, it this another coding thing?
Jeff
Current Ride
- 2016 Toyota RAV4 Hybrid
- 2014 X5 xDrive35 M
- 2013 ML-350 (Gone)
- 2012 Audi Q7 TDI (Gone)
      04-08-2017, 09:11 PM   #2
boyce89976
Drives: 2014 X5 5.0 M Sport
I'm not sure about the seat moving back and forth automatically. But the passenger rear view mirror will move down in reverse if you have the selector switch on the mirror adjustment set to the right (passenger) mirror.
      04-08-2017, 09:26 PM   #3
ttomczak
ttomczak's Avatar
Drives: 2015 X5 3.5 M-Sport
Actually the switch needs to be set to the left (on the drivers mirror position) for the tilt to work.
2015 F15 X5 3.5i M-Sport SG
Past Rides:
2001 E39 Dinan 5 - 2006 E63 M6 - 2007 335i E93 -
2007 X5 E70 4.8i - 2010 X5 E70 3.0i
2016 428ix M-Sport Gran Coupe - 2014 E71 X6M
      04-08-2017, 09:32 PM   #4
artem123
artem123's Avatar
250
Drives: G30
It is EXACTLY opposite to this^^. Selector should be moved to the left.
      04-08-2017, 09:58 PM   #5
Dataready
Dataready's Avatar
Drives: 2023 X5
2014 X5
Comfort access has nothing to do with the seat position. Comfort access is little radio frequency chip in the car fob (key) that will Lock/Unlock the car when you touch the door handle while the key is in your pocket. And once unlocked the seat memory saved to the Fob will do the seat memory based on what is saved as follows. Seat position is controlled by the memory setting 1 or 2 (two buttons on the left lower side of the driver seat) based on the position you desire of the seat, mirror, steering wheel position and a bunch of other things including heater/AC setting , radio volume, HUD position etc...
You can then save the memory setting to a usb drive. Upon turning the car engine off, the only thing that will be changed by the memory function is the steering wheel position, if it was low it will be pushed up to give more room for driver exit. No seat will be pushed back. Hope that was of some help.
      04-08-2017, 10:39 PM   #6
Enrico 35d
Drives: 2014 x5 35d
yup, only the steering column will tilt up when exiting. Seat won't move.
      04-08-2017, 10:42 PM   #7
TheUltimateDrivingManiac
Freude am Fahren.
Drives: F15 X5 xDrive35i
It's possible to code.
Freude am Fahren.
