      08-21-2018, 06:45 AM   #1
mrfochon
Drives: X5 F15 M package
Mirror Tilt on Reverse
Guys,
My left mirror stopped tilting on reverse. Also it seems the right one will tilt only if the mirror selection position button is set to right.
Any help is appreciated.
Thank you
      08-21-2018, 07:25 AM   #2
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Originally Posted by mrfochon View Post
Guys,
Thank you
That's interesting, mine only has right mirror tilt function. It also will only tilt when button is pushed to the right.
Sounds like perhaps a motor went out, or possibly a bad connection.
2016 BMW X4 xDrive 28i-Sold
2014 Lincoln MKX-Sold
      08-21-2018, 07:45 AM   #3
mrfochon
This morning Tuesday of right mirror worked with button selection on left.
      08-21-2018, 07:59 AM   #4
CatalinP
Drives: BMW X5 F15 2014 3.0xd
That's normal, as per the owner's manual...
mrfochon211.00
      08-21-2018, 08:48 AM   #5
mrfochon
Is was always tilting both mirrors. Are you saying it is not supposed to ?
      08-21-2018, 09:29 AM   #6
MrTookies
MrTookies's Avatar
I think you are mistaking, only the right mirror will tilt when in reverse. Never seen a BMW that can tilt the left (by itself when in reverse that is).
For it to work you will need to select the left mirror and leave the button in left position. Once you place it in the right position this function will not work, as the car "thinks" you want to adjust it manually at that time.
You can also find this in the Owners Manual as mentioned by CatalinP
CatalinP589.50
mrfochon211.00
      08-21-2018, 09:34 AM   #7
mpowered5
mpowered5's Avatar
433
Drives: E34 M5
This^
2015 X5 35d M sport
2017 340i M sport
1991 M5
1988 M5
      08-21-2018, 01:11 PM   #8
MrTookies
MrTookies's Avatar
Originally Posted by mpowered5 View Post
This^
      08-21-2018, 01:15 PM   #9
mrfochon
Though I was 100% sure both mirror were tilting.. but the button thing is misbehaving. Once in right once on left.
      08-21-2018, 02:59 PM   #10
Rox335i
Drives: 14' 335i, 17' X6 35i
Probably just a mistake and the left mirror never tilts. If your on a RHD vehicle it will tilt the left mirror. But all the BMW's I've driven never tilted the left mirror.
      08-22-2018, 11:52 PM   #11
gqgambler
gqgambler's Avatar
Drives: Fast & Furious
New or used? Only ask because I think you can code for the left mirror to go down on other cars, not sure of the f15 though - but check and see if its on the European specs. Typical behavior on American sold cars is that only the right mirror tilts down when in reverse to help you avoid curbing the rims. The mirror control switch usually needs to be in the center or to the left as in the case with BMWs.
      08-23-2018, 11:44 AM   #12
M302_imola
M302_imola's Avatar
843
Correct! My E46 M3 was the same way. The right mirror tilting down is to help with parallel parking.
MrTookies457.50
      08-23-2018, 01:43 PM   #13
chumbedi
Drives: BMW X5e40 (F15)
Left mirror only tilts, if your model is right hand drive.
Right mirror only tilts, if your model is left hand drive.
(And of course; if your model supports MIRROR TILTING and the button is in correct position re tilting while reversing)
