12-15-2020, 11:14 PM | #1 |
Rep 1,780
Covid19: Do I need to do regular maintenace even if I didnt drive it?
I've driven my F15 about 1500 miles this entire year, if that. I got a notification today in the connecteddrive app to schedule an appointment to change my brake fluid and engine oil. So do I need to?
12-15-2020, 11:23 PM | #2 |
Rep 2,525
Brake fluid is definitely a must, it is hygroscopic so you need to change it no matter you drive it or not. Oil is my opinion is a bit more questionable but I would change it.
12-16-2020, 08:09 AM | #3 |
122
Rep 359
My wife's 2015 x5 is due for an oil change this month, it was driven less than 1000 miles this year since the last oil service. Have decided to change it regardless, don't want to risk a warranty issue and be told that maintenance wasn't performed at recommend intervals.
12-16-2020, 09:02 AM | #4 |
Rep 979
BMW recommends an oil change once a year regardless of mileage
The Libertine1237.00 |
12-16-2020, 09:02 AM | #5 | |
Rep 1,780
12-16-2020, 09:13 AM | #6 |
147
Rep 334
thereef5101169.00 |
12-16-2020, 09:51 AM | #7 | |
Rep 7,570
BMW recommends (as mentioned already) 2-3 years for brake fluid due to its hygroscopicity. And BMW "recommends" 10K-12K or 1 yr oil changes (which ever comes first). So do you want follow those recommendations...or take another route? Neither of those fluids are based on mileage or mileage alone...but are time based as well.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-16-2020 at 11:12 AM.. |
12-16-2020, 10:16 AM | #8 | |
Rep 1,780
12-16-2020, 10:28 AM | #9 | |
147
Rep 334
Lots of discussion on summer cars that are put away for the winter, oil change before sitting or after sitting? The consensus is do it before as you don't want to leave your dirty oil sitting in your engine. That being said, I think you'd be okay to keep it as is until you foresee your driving situation changing. Changing the oil to just let it sit there again for who knows how long seems like it will probably just put you right back in the same spot. Depends if you wanna spend the money or not. N55 or N63TU engine? Then again, I change my own oil so and do it at 10K KM intervals as I feel that the factory 12, 15K KM is a bit high. So take that for what it is. Hahah. |
thereef5101169.00 |
12-16-2020, 11:25 AM | #10 |
Rep 7,570
Just an FYI to remember that BMW changed the OIL SERVICE interval to 10K miles or 12 months starting with the 2014 model year (July 2013 production date). My 2013 f06 6 series had a 1/2013 build date and when I brought it in for its initial PPI...they asked if I wanted to change the interval from its original 15k miles to the updated 10k miles...and I said yes.
But I also recognize the the topic of "oil" can be a dicey subject. The owners know their cars and situations better than the "collective". In cases like the OP's...the decision to hold off on an oil change until later may work for them if the car is going to be parked (still) for long periods of time. Going a few months longer on the "time" interval (in my opinion) is not as bad as going long on the "mileage" interval...especially since the car isn't being driven....thus minimal wear issues on the engine's internals. Good luck with whatever decision you make.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-16-2020 at 11:31 AM.. |
12-16-2020, 11:33 AM | #11 | |
Rep 1,780
I don't expect to go back to regular use of my f15 until June/July of this year. its the 35i 6 cylinder engine. So, should I change the oil now or wait till closer to then to do it? |
12-20-2020, 10:40 AM | #12 |
Rep 1,222
thereef5101169.00 |
12-20-2020, 07:22 PM | #13 | ||
Rep 10,312
12-21-2020, 02:57 AM | #14 |
Rep 1,780
12-21-2020, 03:08 AM | #15 | |
Rep 10,312
12-22-2020, 01:39 AM | #16 |
Rep 1,780
what would you consider a 'short trip'? currently, I have no place to go, so I take it to the grocery store about 3 miles away one way. so 6 miles a week, or thereabouts. What would be considered an appropriate driving distance/week to stress the engine and the ancillary components appropriately?
12-22-2020, 11:02 AM | #17 | |
122
Rep 359
thereef5101169.00 |
12-22-2020, 03:46 PM | #18 | |
Rep 1,222
thereef5101169.00 |
