      04-08-2016, 09:27 AM   #1
Blackhawks
Blackhawks's Avatar
Drives: 2015 X5 x35i
Condensation in headlight housings
Anybody else getting condensation in their headlight housings? I just noticed it this morning and was wondering if it's a broader issue...
BimmerTy195.50
      04-08-2016, 09:40 AM   #2
aw305
aw305's Avatar
Drives: F97 X3MC Alpine White
I haven't had any in my truck
      04-08-2016, 09:46 AM   #3
stewy604
stewy604's Avatar
290
I had condensation and water issues with my RR tail lamp assembly, but nothing on the headlights. I would say if it doesn't clear within a day or two, have your dealer replace.
2007 Suzuki GSX-R 750
      04-08-2016, 09:54 AM   #4
Blackhawks
Blackhawks's Avatar
Response from my CA: "This time of year with any rain and humidity, there is some small amount of condensation. The headlights get so hot, they should burn off the condensation. There are small vent holes for the housing because they do get hot. They would overheat if there wasn't. If there is always excessive condensation, it should be covered by warranty."
      04-08-2016, 01:52 PM   #5
Diper
Diper's Avatar
Netherlands
47
Drives: BMW X5 F15 3.0d
This is normal behavior. I live in humid and wet region. Nothing to worry about.
      04-08-2016, 02:26 PM   #6
artem123
artem123's Avatar
252
Drives: G30
Not sure how it is normal. Go to dealer, which, as i can assume, is located in the same area as your car, and ask them to show how many cars on a lot have the same wet from inside headlight. I bet, there will be none. Ask them "why is it only your car has it?"
      04-09-2016, 04:45 AM   #7
pragueX5
pragueX5's Avatar
Czech_Republic
157
Drives: 2021 X5 M 40d mildhybrid
had this on all my cars for the very first few weeks.
guess its the residue vappur from all the manufacturing process
ocasionaloy I get this on rapid weather condition change in combination with car wash = rapid temperature and humidity change, but its away in few hours
seems like your case, only rain instrad of car wash and warm sunny evening I suppose with car parked on the sun?
simply => air condensation. the light is not vacuumed
if persist, faulty light Iam afraid
      04-09-2016, 12:36 PM   #8
alphaod
alphaod's Avatar
I always though condensation warranted replacement. At least it was on every other car I've owned.
      04-09-2016, 08:00 PM   #9
artem123
artem123's Avatar
252
Drives: G30
^^Exactly! +100
      04-09-2016, 09:51 PM   #10
turboawd
1642
Drives: 2015 X5 35i
the headlights are not sealed. they have little vents to allow air to expand and contract.
the air vents out as the light heats up. then when you park, the light cools off and air is drawn in.
you may just have excess humidity inside, for whatever reason.
on a dry day, pop the hood, and remove the covers on the back of the headlights, and blow a hair dryer in there for a bit, to get rid of the moist air.
      04-10-2016, 12:51 AM   #11
F15GorDe
F15GorDe's Avatar
Drives: F15d, F10
+1^^^
No condensation here, yet. Will apply above technique if I find it.
      04-10-2016, 01:22 PM   #12
alphaod
alphaod's Avatar
Here's the thing. The vents are for the electronics to let out heat. It is so designed so air can pass through, but in no way should water get in there. They are not there to let water evaporate. There is a barrier between the front and rear parts of the headlight. Water should not be able to get in. Any dealer that says otherwise is ignorant. If there is condensation in the housing, it's from a leaky seal. Leaky seal is a defect therefore warrants a replacement headlight assembly. If condensation was normal you'd see it on all cars, but you don't.
      04-10-2016, 05:03 PM   #13
turboawd
1642
Drives: 2015 X5 35i
it there is actual water droplets inside the lense, then you have issues. but if its just a little fog, then its normal. i've seen it on my x5 too once.
and if you look at the pic, its freezing rain on the outside, so the moisture/humidity inside the light is condensing on the cold lense.
      04-10-2016, 09:28 PM   #14
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7266
water collection and pooling is warrantied. condensation is not.
      12-03-2018, 05:12 PM   #15
BimmerTy
///M
BimmerTy's Avatar
Drives: 2015 F15 X5 50i M Sport
Reviving this thread...
Is this seriously normal? Just noticed the driver's side headlight has condensation when I left work this afternoon. Passenger side is fine. It rained over the weekend and was dry and in the 50s today.
2015 F15 X5 xDrive50i - M Sport - Space Grey Metallic - 21" 612M - Accelera Iota ST68's - Black Dakota - Leather Dash - Poplar Wood - Ceramic - Shawdowline - Anthracite - Adaptive M - Full LED - Executive - DA+ - Surround - HUD - Enhanced BT - Soft Close - B&O - ACC Stop & Go - Multi Contour - 4 Zone Climate - Comfort Seats - Cold Weather - Muffler Delete - Akrapovic Tips - F85 Grille - 35% Tint - BMW All Weather Mats -- Missing DHP, NV, Active Steering, Rear Entertainment, & Cooled Seats
      12-03-2018, 08:10 PM   #16
lefty3292
Drives: 2023 X5 M50i
I had condensation in my E93 M3 headlight and it fried the ballast and all the internal electrical parts. Total nightmare and error codes galore.
Mine was out of warranty though...I hope yours is not!!
BimmerTy195.50
      12-04-2018, 04:10 PM   #17
MN2///M
MN2///M's Avatar
Drives: very fast!
There is a Technical Service Bullitin on this; B630516 appears to be the right number, but I can't find the full text. Dealer should be able to show you the TSB which should state at what stage the condensation is abnormal.
I knew I had seen this somewhere:
2003 BMW 330i
2016 BMW M4 - ED May 2016, PCD Aug 2016
2017 X5 xDrive35i - PCD Jan2017
BimmerTy195.50
      12-07-2018, 02:18 PM   #18
mp25
Drives: 14 x5
I got the same issue on my passenger side. There is a seal on the top to access the bulb assembly that was cracked and I glued it back together and it helped slightly. To dry it out I ususally leave it open after driving it so the heat helps the moisture evaporate up and out. Still get some condensation its really cold or rainy but not the big droplets like before.
BimmerTy195.50
