06-17-2015, 07:54 AM | #1 |
Rep 709
Adaptive M Suspension not showing in build
Hey guys... for those that have the Adaptive Suspension can you recall if it was displaying on the "Track Your BMW" website ? I've confirmed that it's on the build sheet that was submitted, but it's not displaying on the website.
The CA said that the website is useless because it causes more headaches and questions than anything... he told me that when i called him to ask why it's displaying as Carbon Black (changed online to Space Gray last night). Just curious to know if anybody remembers what their online page looked like... |
06-17-2015, 08:21 AM | #2 |
Rep 8,835
Yes that page isn't very accurate. Dealers use allocations that they originally had scheduled for your build so thats why it will show what the original build was set for initially and then switch over to your actual build later on. Even then I don't think it listed every option especially something that isn't a big package like the 2VF.
If you have your VIN# go to www.bmwvin.com to pull up your exact specs. Mine came up and it was 100% spot on listing every single detail. Alan
06-17-2015, 08:31 AM | #3 |
Rep 72
Yep, use bmwvin.com. I've been using that website, along with the build sheet PDF that's floating around, to find the BMW I wanted on a dealer lot.
It's pretty easy to use. look for either 2VF or 2VM Last edited by touchdown83; 06-17-2015 at 08:38 AM.. |
06-17-2015, 08:37 AM | #5 | |
Rep 709
Thanks for your help, guys. |
06-17-2015, 08:42 AM | #6 |
Rep 5,066
I know what you mean.. I went through the same process and panicked when I saw that the 2VF was not listed.. others here have went through the same thing as well. Don't worry about it
06-17-2015, 09:03 AM | #8 | |
Rep 709
Premium package - the guys on the forum own that as I was talked into it. Honestly, I found myself using the keyless entry, on my current car, more than I realized. |
06-17-2015, 10:05 AM | #9 |
Herr Oberst
244
Rep 531
06-17-2015, 10:06 AM | #10 | |
Herr Oberst
244
Rep 531
06-17-2015, 11:31 AM | #11 |
Rep 5,066
06-17-2015, 11:50 AM | #12 | |
Rep 1,363
06-17-2015, 01:06 PM | #13 | ||
Rep 709
I couldn't find specs on the amp, but it's probably crap. |
06-17-2015, 04:22 PM | #14 |
Rep 72
Right. I was in the away from my computer and couldn't remember which was Dynamic Handling Package and which was Adaptive Suspension. I just remembered that it's one or the other, you can't have both.
For the record, 2VF is the M Adaptive Suspension and 2VM is the Dynamic Handling Package Suspension, and they are mutually exclusive. |
06-17-2015, 04:51 PM | #15 | |
Rep 5,066
2VM = DDC 2VF = Adapative M Suspension ZDH = Dynamic Handling Package http://f15.bimmerpost.com/forums/sho...d.php?t=913797 |
06-17-2015, 05:12 PM | #16 | |
Rep 72
I was only referring to the suspensions, not the whole ZDH package. BMWVIN.com won't show you ZDH nor will it show 7SZ; you can only see the components of a package, not the package code itself. In order to determine if the Dynamic Handling Package is included on your build you can look for the suspensions: 2VM is the suspension that's included in the ZDH, unless you get Adaptive M Suspension, in which case you'd see 2VF. However, looking back on it, I should have said look for 2VP on BMWVIN.com... that is only available with Dynamic Handling Package. |
06-17-2015, 05:35 PM | #17 |
Rep 709
www.bmwvin.com had an exact match to my build sheet. I'm feeling much better. LOL
