      10-27-2018, 08:38 AM   #89
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Originally Posted by Bergen346 View Post
And bought my 15 CPO - notice the door seals are breaking apart.... fun stuff.
Ask your dealer to replace them. I would think if it's CPO they should have been able to spot this.
2016 BMW X4 xDrive 28i-Sold
2014 Lincoln MKX-Sold
      01-13-2019, 09:17 AM   #90
kendallc24
kendallc24's Avatar
31
Drives: '14 BMW F15 | '22 BMW G07
resurrecting this old post...
I've been doing a ton of searching, but can't find anything related to the actual removal of this particular door seal. I just purchased new ones to replace my torn seals on my MY2014 35i, but cannot figure out the best way to remove the seals from the door jamb.
I tried a hair dryer to heat the adhesive, but didn't seem to work well enough.
Any suggestions?
      01-13-2019, 10:07 AM   #91
mrfochon
Drives: X5 F15 M package
Did you watch this video
      01-13-2019, 10:37 AM   #92
kendallc24
kendallc24's Avatar
31
I did. However, it's a completely different type of seal.
      01-13-2019, 02:38 PM   #93
alphaod
alphaod's Avatar
Start from the top with a plastic pry tool. Lift it up and just pulling. To get rid of the adhesive, use the same pry tool to scrape it off. Should take no more than a few minutes to remove it. Installation I also started from the top. I peel away a little of the double-sided tape and I pressed it down bit by bit whilst removing the backing tape. Took me I think five minutes total.
Name:  IMG_4045 - Copy.jpg
2015 BMW X5 xDrive50i
BMW CCA 509766
Russmov1328.00
      01-14-2019, 06:05 PM   #94
kendallc24
kendallc24's Avatar
31
Thanks! I’ll give it a go, had to order some pry tools.
      03-03-2022, 09:02 AM   #95
nszzya
Drive Different
nszzya's Avatar
Drives: '16 F15 '17 F87
Attachment 1971321
Does the hook at the top of the seal cause any issues when prying it off? Thanks.
'17 F87 M2 DCT / '16 F15 X5 X35i / '09 E82 135i 6MT*
'10 E70 X5 35d* / '05 E60 M5 SMG* / '01 E53 X5 4.4i* / '76 2002* | '70 2002*
*Gone
      03-07-2022, 09:34 AM   #96
Qsilver7
Qsilver7's Avatar
If I understand you question correctly...no...the "hook" at the top of the replacement piece is overlapped by the gasket/seal that is adhered to the top section of the door...and both can be moved to accomodate the overlap. This part of the gasket/seal is pliable to accommodate the overlap...which also is overlapped similar to a roof shingle to keep water on the outside of the gasket.
If you look at alphaod's amended pic below...the top of the lower gasket gets tucked under the bottom of the upper gasket. Is this the "hook" you're referring to?
      03-07-2022, 12:01 PM   #97
nszzya
Drive Different
nszzya's Avatar
Thanks for your reply. By hook, I mean the upper part of the replacement part that loops over the top of the door edge. I've edited the photo indicating this.
*Gone
      03-08-2022, 03:48 AM   #98
afropelican
Drives: 2014 X5 F15 30D xDrive MSport
There is also a method to use dental floss to 'saw' through the adhesive similar to removing an emblem.
I used this method when replacing these seals rather than prying, once I got a big enough edge up from the bottom, I was then able to pull the seal off, as its actually made from plastic where it attaches to the door.
      03-11-2022, 10:02 AM   #99
Melosh
Drives: X5 F15_2017
Originally Posted by cafemosaic View Post
600 miles:
Thanks for all of the feedback guys...i am glad (and sorry) to see that this opportunity is not unique to my vehicle...I have also noticed that it is now happening regularly on the passenger side...the flimsy material is not rigid enough to hold its shape and the slight contour in the door panel causes the seal to flip almost inside out and stay...the soft close doors simply aggravate the problem by mashing the inverted seal in place making it even more likely to stay folded out. I usually dont notice until i hear the wind noise and look in the side mirror to see the seal flapping....Last night i had to stop on the interstate to circle the car and fold it inside the passenger door!
I stopped at my local BMW center in Charleston SC to show them and they were very surprised (and horrified). They assured me they would contact their local rep to find out if the factory is aware and if so what the proposed fix will be. Ill keep you posted but be on the lookout...
This may take awhile as only a couple have been delivered and i hear the allocations have dried up through march?
      03-01-2024, 12:17 PM   #100
1004ron
Drives: 2015 BMW X5 xDrive35i
Originally Posted by 2euro View Post
I just noticed on mine. It isn't as bad as the pictures on this thread. But I saw on mine it was ripped.
In case anyone else is having issues. I found the part at ECSTuning.
https://www.ecstuning.com/b-genuine-...e/51767318509/
Seems easy enough to install.
I'm needing this seal for my wife's 2015 X5 that we bought a couple of days ago.
That link shows "Note:This product is no longer available.".
Has this been superseded and if so what part number should I be looking for and where?
defect, door, gaskets, seals
