03-20-2019, 06:51 PM | #4731 |
Rep 599
Check your valves, if they are bendable rubber you don't have TPMS, you have FTM (flat tire monitoring). Not sure installing TPMS valves will do much as I wouldn't expect Canadian cars will have the sensor to read. Apparently more companies are going away from TPMS in favour of FTM. Cheaper to maintain, and cheaper to get extra wheels (as you don't need to spend hundreds on sensors).
03-20-2019, 06:53 PM | #4732 | |
Rep 1,343
03-24-2019, 12:51 PM | #4733 |
Rep 219
So, successfully VO and FDL coded AGHB, TJA to my 2015 F15. But, I am having trouble coding my newly installed trailer lighting module (AAG). I VO coded 3AC, but cannot code it to the module as the “Code” option is grayed out. Also, no CAFD file for FDL coding.
Is my PSdZData file too old? Something else I did wrong? Currently getting trailer hitch electrical/bulb fault. Any ideas? Should I post this question elsewhere Last edited by David3; 03-24-2019 at 01:05 PM.. |
03-25-2019, 06:44 PM | #4734 | |
Rep 8,364
03-25-2019, 11:32 PM | #4735 |
Rep 258
03-26-2019, 12:35 AM | #4737 | |
Rep 258
Why do you need the parking break on at every stop? If you push the brake pedal down hard the X5 will hold the brake even on a steep incline for a few seconds after you let go of the brake |
03-29-2019, 01:57 AM | #4739 |
Rep 41,020
Correct. Not possible.
03-29-2019, 03:32 AM | #4740 |
Rep 8,364
03-29-2019, 10:44 AM | #4741 |
Rep 2,517
03-30-2019, 01:20 AM | #4742 |
Rep 8,364
03-30-2019, 10:19 PM | #4743 |
Rep 43
hello, I would like to add new vo code to the new equipment. I have other wheels (styling 375 instead of 469) and BMW M Performance Interior moldings Carbon. Write the codes SZHEA and SZC4A (of course the middle 3 characters) with calculate FP is the error: "not all elements of the FA were found in FA2FP [72] system error" Earlier I added, for example, the S417A ROLLER SUN VISOR code, REAR DOOR which I did not have before and succeeded. does anyone have any idea why this is so?
03-30-2019, 10:44 PM | #4744 | |
Rep 8,364
03-31-2019, 01:33 AM | #4745 | ||
Rep 43
03-31-2019, 02:08 PM | #4746 |
Rep 8,364
03-31-2019, 09:30 PM | #4747 | |
Rep 43
03-31-2019, 09:31 PM | #4748 | |
Rep 43
03-31-2019, 10:01 PM | #4749 |
Rep 8,364
03-31-2019, 10:15 PM | #4750 | |
1152
Rep 2,426
2015 BMW X5 xDrive50i
BMW CCA 509766 |
04-01-2019, 12:09 AM | #4751 |
Rep 43
where can I find this file?
04-01-2019, 08:17 AM | #4752 |
Reads books at a 4th grade level; I'm an enabler
78
Rep 116
Drives: X5 35d, 335i Msport, X3, 325iX
Garage List 1993 BMW 525iT [0.00]
1989 BMW 325iX [0.00] 2015 BMW 335i M-Sport [0.00] 2007 BMW X3 M-Sport [0.00] 2015 BMW X5 [0.00] |
