03-21-2020, 09:20 PM | #1343 |
Rep 34
This is the what I found to disable interior motion semsor.
If the comfort entry and exit time is set to zero (this is what is used to automatically fold the mirrors when you lock via the fob or door handle with one touch) then the 2 consecutive presses of the lock button will not disable your interior motion sensor. I changed the time to more than 0 seconds and now I can double click my lock button to lock the car but disable the interior motion sensor. However, now I must long press or long touch on the handle to fold the mirrors. |
NYC_X5372.00 |
03-22-2020, 07:25 AM | #1344 | |
Rep 50
Thank you very much for this, I will code it later and test it. |
03-23-2020, 05:20 PM | #1345 |
Rep 50
OK set everything on 0.5, I had one set on 0. Now is working as it should.
Only minus is when I lock the car with the key I need to hold lock button for 0.5 sec so it will fold mirrors. Thank you. |
04-06-2020, 09:48 AM | #1348 |
Rep 530
Drives: 2020 BMW X5 MSport Arctic Grey
So - when you press the sport or sport + button the image of the car that appears looks like it is specific to mine...color, package and wheels.
I have converted mine to MSport with the M 21 wheels. Are there different versions of the car - or is the one I have just the generic one?
2020 BMW X5 M-Sport
2021 Audi Q7 Prestige 2016 Aston Martin Vantage V8 |
1230vani660.00 |
05-03-2020, 03:00 AM | #1349 |
Rep 3
Help
Hello all,
on the G series, it is possible to recode the counter and display 330 km / h: Instrument Cluster 3000 ... MPA_ENABLE ... Aktiv and I was wondering if it was possible to find a solution for the F series equipped with the Black Panel. Maybe you have a solution. Finally, it is possible for us to download the maps for our GPS, why can't we add radars to the POIs as it used to be possible on DVDs for vehicles with MK4 players? Thanks for your help. Friendship of France |
07-08-2020, 04:05 PM | #1351 | |
Rep 179
I did those coding but can't figure out how to use it |
07-08-2020, 05:35 PM | #1352 |
Rep 7,577
It’s done using EXPERT MODE. So be careful when you find the coding instructions (probably on one of the coding forums).
07-08-2020, 06:03 PM | #1353 |
Rep 61
07-08-2020, 06:04 PM | #1354 |
Rep 61
Anyone tried adding the B&O eq? Another thread said it can be done in BimmerCode in expert mode:
HU_NBT or HU_NBT2 > HMI 3000 > HIGH_END_AUDIO_MENUE = volle_insz Just not exactly sure where that is? |
07-08-2020, 09:23 PM | #1355 |
Rep 179
How do I get the video to play after I code it?
Is there something that needs to be done? |
07-09-2020, 01:00 AM | #1356 | |
Rep 32
I believe the car can play AVI, MKV, MPG, And some others up to 1080p. I've had hit or miss with the file format for the USB. I have 2x 128gb usb sticks formatted with exFAT and one is recognized by the HU (head unit) and the other isn't. Good luck and let me know if I can help. |
07-09-2020, 01:27 AM | #1357 | |
Rep 16
07-09-2020, 01:08 PM | #1358 | |
Rep 7,577
What media are you using to playback video....CD/DVD/USB? Are you using compatible media (this info is in your owners manual...and probably in the iDrive owners manual, too. Where in iDrive are you scrolling to to start the video?
07-13-2020, 09:07 AM | #1359 |
Rep 18
Hi Guys
Im looking help. How to turn off front side marker in LED Headlights in X5 F15 2014 All description is only for cars after 06/2015... LM_ID_LT04 ... is for cars after 06/2015. Thank you for help |
07-13-2020, 01:14 PM | #1360 | ||
Rep 179
Is there a certain way to do it with idrive? Thanks |
07-13-2020, 07:04 PM | #1361 |
Rep 11
Want to code 2TB in X5 35d - but no 205 in FA?
I've seen how you can code 2TB to get Sport+ in X5's. But when I pulled my FA it doesnt have 205 listed. What do I have then? Can I code 2TB?
08-07-2020, 02:11 PM | #1362 |
Rep 38
So you get errors with e-sys that you then have to use another app to clear? Been using Bimmercode for years & never had an error code after a change. I'd like to look into e-sys to see what other options I can code that Bimmercode doesn't do but ease of use & error-free (revert option) are top priorities.
08-07-2020, 11:17 PM | #1363 | |
Rep 7,165
08-07-2020, 11:35 PM | #1364 |
Rep 241
anyone having issues with the start animation? I changed it to 'M" logo and seemed to show up on first start up but subsequent startups go directly to the normal nav/ radio screen. note that I did disable the warning at startup so not sure if the combo causes this issue.
