11-02-2020, 06:37 AM | #1 |
Rep 1
Runflats swapped for all season tires
Just had 4 new all season 20s put in staggered array (Ft 275/40R20 106(V or >)
Rr 315/35R20 110(V or >) at F 36, R 41 psi) same size as the runflats. Week later low pressure sensor alert and all 4 low pressure (F now 30, R now 35) with one rear tire at 24psi. Wheels original no changes. What is the problem? |
11-02-2020, 12:29 PM | #3 | |
1640
Rep 2,995
NYBulldog1310.00 pennsiveguy3552.00 |
11-02-2020, 12:42 PM | #4 |
Rep 2,513
Happened to me many times when I lived in Tahoe. 80 in August vs 20 in November will do the trick, put some cold winter air to the proper pressure, reset TPMS and drive your car around the block. Problem solved.
11-02-2020, 01:56 PM | #5 |
Rep 1,062
Drives: F15 xDrive50i M-sport
That's happened to me, both at the tire shop and in my shop at home. Fill the tires with 70-degree air when the tires and rims are at 70 degrees, and then drive out into sub-freezing weather and watch the pressures and temps dive in the iDrive Tire Pressure Monitoring screen. In extreme -25 cold I've even had tires pull away from the beads and go totally flat.
11-02-2020, 11:34 PM | #6 |
Rep 1,354
Drives: 2022 X5 m50i
Just happened to me when I swapped the P Zeros with Vredestein all seasons. Like mentioned above, pumping in cold air when tires are cold does the trick.
2022 BMW X5 m50i
11-03-2020, 08:16 AM | #7 | |
Rep 287
Drives: 2020 M4
I would keep an eye on the one that dropped to 24 as that's a pretty big delta. |
