11-30-2014, 05:20 PM | #1 |
Rep 184
20" Wheel Shopping- offsets?
I posted my first thread (rant) the other day about my subtle disappointment with some of the aesthetic exterior changes from the E70 to my new F15. I have the standard trim on a Sophistico Gray. Now it's time to do something about it. I'm going to start with wheels- and I need some help finding direction in my search.
MUSTS- I want a NEARLY flush fit to the wheel well - maybe a thumb's width of complete fender coverage. I want the wheels to be 20". I want the wheels to have the ability to accept BMW center caps. I want to go with wider tires Wheels and tires $3k or less - don't need fancy forged BBS or HRE for my family hauler... QUESTIONS- What offsets will fill in the wheel wells on the standard trim x5? -keep in mind, I want 20's -- keep in mind, i don't have the m-sport extended fender flares. Square or staggered setup? I don't want to trip anything with the xdrive- i.e. dash error codes, dangerous blah blah - I know the m-sport is staggered, but perhaps it's coded for that... i figure a subtle stagger won't hurt anything. what brands are popular for the x5? same names as i associate with my m3? run flat- or not?? I'd prefer not, but what to do if wife gets a flat? fix-a-flat in the trunk? buy a donut? I'm sure some of this info is already in the forum somewhere, but i did a few searches and didn't see anything that caught my attention. thanks in advance for any help or suggestions! rob |
11-30-2014, 07:23 PM | #3 | |
Rep 184
12-04-2014, 02:44 PM | #6 |
Rep 525
i will say...on my msport
i used 30mm spacers on all corners, and even if i went aftermarket rims, i would stick with the spacing it had now. no more offest than whatever stock is plus 30mm..... you cant "Fill the Gap" to a thumbs width unless you lower, and even then, you would have to go lower then the aftermarket options available, or go with an up size like 22-24 inches of wheel..... see if you can find my posts with pictures to look at offset and wheel gap spacing with 30mm spacers added. if you took everything ive done so far, and dropped it on baggs, the spacing would be cose to perfect in my eyes.
12-04-2014, 02:46 PM | #7 |
Rep 525
12-04-2014, 07:01 PM | #8 | |
Rep 184
