      12-13-2016, 05:29 PM   #155
soulsea
soulsea's Avatar
Drives: 2019 M5 Comp
Originally Posted by r33_RGSport View Post
Yes, I do recommend 5mm front and 15mm rear.
The lug bolt thread for all the F chassis BMW is 14x1.25.
Thanks.
Are the any special member discounts or current promotions going on that a hypothetical new customer could take advantage of?
cars
      12-13-2016, 05:45 PM   #156
Thanks.
PM'ed you.
PM for Everyday DEALS!!
      12-19-2016, 03:17 PM   #157
Roundown
Drives: BMW
Thanks.
PM'ed you.
Could you PM me too? Looking for 5mm/15mm for an F85. Thx
      12-19-2016, 03:25 PM   #158
Thanks.
PM'ed you.
Your mailbox is full.
      12-19-2016, 05:25 PM   #159
Roundown
Drives: BMW
Fixed! Thanks
      12-28-2016, 09:16 PM   #160
Installsplus
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
Installsplus's Avatar
Drives: 2011 E92 M3 DCT/ESS 625 kit
To put this topic down to the root. I install a spacer to my X5 and took before and after pictures from all different angle.
Here are the specs:
15mm Front
20mm Rear
Enjoy and feel free to PM me for questions and inquiry.
Update: 15mm Front and 20mm Rear only fit on the F15 X5 before MY11/14 only!!!
For MY11/14 and after, 5mm Front and 15mm Rear is the recommended size.
Here is the picture on 5mm Front and 15mm Rear.
Hey Ben why can't u do 15-20 mm on 2015 and newer. Looking at spacers from ecs and noticed they have 18mm.
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625
2016 F15 X5 Msport 35i
      12-28-2016, 09:20 PM   #161
Here are the specs:
15mm Front
20mm Rear
BMW changed the front hub where is taller than the before version.
Where the 15mm doesn't clear it.
You can use the 18mm for the front, but it will stick out 3mm more than the 15mm.
      01-02-2017, 07:00 PM   #162
Installsplus
Here are the specs:
15mm Front
20mm Rear
I just went with 15 for the rear. Nothing in the front.
      01-06-2017, 03:18 PM   #163
Roundown
Drives: BMW
Thanks to Ben and a set of 15mm rear spacers, I am much happier with the stance on the OEM winter set for my F85.
Easy enough to install with the proper tools. Highly recommend picking up a wheel hanger (makes lining up the spacer and wheel much simpler), a torque-limiting socket (brakes torque at 75ft/lb) and a good torque wrench. Of course, you'll also need a breaker bar, BMW jack adapter, jack stands (if you want to be extra safe), anti-seize and a jack (my low-profile 2-ton jack seemed a little stressed under the weight of the F85... might be time to upgrade).
Tools...
Holly brakes...(makes sure to remember the anti-seize)!
Left side are the OEM 11.5x20 with 315 (width) Continental DWS06, Right side OEM 10.5x20 with 285 (width) Pirelli Scorpion Winter. Photo wasn't taken directly behind, so it's a bit skewed.
Finished product..
      01-06-2017, 03:41 PM   #164
Mexecutioner
Drives: 2015 X5 xDrive35i
Thanks for posting links to the tools you used.
      01-06-2017, 03:57 PM   #165
Roundown
Drives: BMW
No problem- it's taken me a few years to get the equipment and process right, but can now swap in <30min. I linked above to the tools that I've used. The wheel hanger is really key and cheap.
      01-07-2017, 12:55 PM   #166
Installsplus
My set up 15mm rear
Here is my set up no spacers in the front 15mm in the rear
hufington3120.50
      01-07-2017, 01:01 PM   #167
Looks imbalance IMHO.
The 5mm in the front will help.
      01-07-2017, 02:53 PM   #168
Installsplus
Would the 5mm really make a difference though? To bad can't do thicker.
      01-07-2017, 03:02 PM   #169
Installsplus
I have these laying around from my e92 will they work if I buy bolts from u?
      01-07-2017, 03:04 PM   #170
It will.
That E92, you need to check the center bore. Most likely won't fit.
      01-07-2017, 03:09 PM   #171
Installsplus
It will.
Worth a shot. Let u know what happens. Do u have 5mm in stock?
      01-07-2017, 03:10 PM   #172
It will.
Yes I do
      01-07-2017, 04:48 PM   #173
Installsplus
It will.
Yes I do
We'll looks like ur right they won't fit but I did discover that my hub in the front looks like it can accommodate any size spacers not sure how 2015 and newer looks. Correct me if I am wrong. If I can only do 5mm pls msg me a price with blk lugs. Thanks
      01-07-2017, 06:39 PM   #174
It will.
Yes I do
5mm or thicker than 15mm.
10mm, 12mm, or 13mm won't fit due to the hub centric clearance.
      01-08-2017, 07:34 AM   #175
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7266
For anyone installing spacers, keep in mind your park assist may curb your wheels because the wheel widths have changed. Park Assist on my vehicle gets in pretty tight to begin with and is basically parked as close to the curb as possible. I would be concerned adding 15mm and damaging the wheel.
      01-08-2017, 02:44 PM   #176
Good mention.
The whole time I have park assist feature in my 650GC, I almost never use it. 1 main reason, there are not that many parking condition where it require me to do parallel.
2nd reason, I never got it to work. It is not as easy as it seems.
3rd reason, whenever you are setting it up, the car behind you will not have the patience or give you enough clearance to do it. Because you need to pass the spot about a car length before the park assist able to detect the empty space.
In conclusion, it is a pain to use it. Not as easy as it seems.
