04-28-2019, 10:58 AM | #1 |
Rep 51
Do I need to bother re attaching this?
I noticed a scraping / rubbing noise coming from the front drivers side wheel. Had a poke around behind the disks and this was lose / catching and came off. I think it's part of the dust shield (or what're that bit of metal is behind the disks).[IMG][/IMG]
Do I need to get it re attached? Thanks M |
04-28-2019, 12:33 PM | #2 |
497
Rep 328
Will your truck work without them..yes. But you'll run the risk of generating a lot of brake dust in the wheel well and on your wheels. It's also designed to catch dirt, grime, sand, and salt. Wouldn't want any of that setting on my wheels.
04-28-2019, 08:08 PM | #5 |
<3 Flat Four
217
Rep 754
That heat shields not gonna stop ANY of the above mentioned from getting onto ur wheels. Ur wheels will get hit no matter what. All that heat shields gonna do is just that, shield suspension components from heat generated by the brakes, not gonna do anything for brake dusts as well... stop spewing out BS.
04-28-2019, 08:30 PM | #6 | |
497
Rep 328
04-29-2019, 01:10 AM | #7 |
<3 Flat Four
217
Rep 754
The rotors spin... so the centrifugal force will fling what ever is on the rotors out towards... u guessed it! The wheels... the rotors aren’t fully enfapsulated by the heat shields, so at most, it will prevent water splashes for the inboard side of the rotor, but even then, the outboard side is completely exposed.
04-29-2019, 01:59 AM | #8 |
Rep 51
04-29-2019, 02:03 AM | #9 | ||
Rep 51
04-29-2019, 12:19 PM | #10 |
Rep 660
Hey Markbebb - where did you pull that off the car? It does not look like a dust/splash shield to me - the shields on my X5 have an edged that is larger in diameter and follows the curvature of the rotor (think 3/4 of a moon). They are also attached view screws not rivets to the carrier.
On my old track car (E36 M3) I removed the dust shields to help dissipate heat along with attaching a fabricated cooling ducts - links the body to the brakes. In general, the dust/splash shields *help* to keep rain, rocks and other debris away from the rotor. They are not required per se, but aren't bad to keep in place for street cars. Based on the photo picture, I still think that came from somewhere other than the brakes. Last edited by Clifton; 04-29-2019 at 12:29 PM.. |
Markbebb38.00 |
04-29-2019, 01:03 PM | #11 | ||
Rep 51
04-30-2019, 07:22 AM | #12 | |
Rep 648
I would get it fixed or replaced. Only a $50 part, maybe twice as much in labor, if you can't do it yourself. Mfg Part # 34-11-6-857-978 |
Markbebb38.00 |
04-30-2019, 07:35 AM | #13 |
Rep 3
I had the same thing happen to my 2012 35d. Dealer wanted $275 to replace it. I purchased the shield from Sun Motors (where I order most of my BMW parts because of their pricing). It arrived in three days. It only took 45 minutes to replace; including getting my tools out and putting them away again. I only had to remove the wheel and the brake caliper. Don't know if your's is different but I suspect not. I sold that X5 for my new one in 2018 so don't have the receipt anymore but I recall the part was around $40.
04-30-2019, 07:51 AM | #14 | |
Rep 287
Drives: 2020 M4
Garage List 2020 BMW / F82 [0.00]
2016 BMW X5 35i [0.00] 2012 Porsche 991 C2S [0.00] 2013 Audi S8 [0.00] 2004 Ferrari Challe ... [0.00] |
All he needs to do is reattach the part.... which I assume is riveted together. Looking at the picture, it appears it could affect the air flow (based on the scoop and hole in the vicinity). Regardless, I'd put it back on to the backing/splash plate. I say that as I have a rivet tool and the ability to reattach the piece. Not sure I'd pay someone a hundred bucks to do it. If it's not something OP can do himself, I would give it to guy when he has the front brakes done as they will be there anyway. Last edited by andrewmr; 04-30-2019 at 07:57 AM.. |
04-30-2019, 05:45 PM | #15 | |
Rep 648
Good idea, he could try that first. Should work unless there is a reason rivets pulled out, and he might have to add washers to the backside to hold it in place, and it might still not seat correctly. I don't know the reason it broke, I can't see the other part, and personally in those cases I take the easy way out, and just replace the whole part. In my younger days, I would have tried to rivet it first! |
04-30-2019, 07:02 PM | #16 | |
Rep 287
Drives: 2020 M4
But we don't know the OP's situation, so I tried to give him a cheaper option. |
04-30-2019, 07:47 PM | #17 |
Rep 18,715
My suggestion, check if yours still there.
As far as I remember, the original dust shield doesn't looks like that. It may be road debris that happened to get stuck.
04-30-2019, 10:12 PM | #18 | |
Rep 648
New part might be the wrong side, since I had to mirror OP's piece, but shape looks correct. |
04-30-2019, 10:14 PM | #19 | ||
Rep 18,715
04-30-2019, 10:21 PM | #20 |
Rep 648
r33_RGSport12971.00 |
05-01-2019, 02:09 AM | #21 |
Rep 51
Thanks for all the replies folks. Its actually under BMW warranty so I could just take it back to them. The cars recently had new pads all round so maybe an over eager tech broke it or the rivets just rusted. Tbh I'll prob just leave it until breaks are due next time or I need a new tyre.
