      08-08-2022, 07:36 PM   #1
jp182
Drives: X5 35d
F15 X5 Trailer Lights Not Working...Partially
So I had a trailer mishap and my trailer wire with the 7 plug end got cut in half. I put a new end on but the lights only come on when i turn the headlights on. Any thoughts on what would be causing that as I can't remember if it always worked that way.
I checked the wires at the plug to make sure they are getting voltage.
      08-09-2022, 06:15 AM   #2
dr_greenthumb
Drives: 14' F15 X5 35i x
Trailer lights will only be on when the headlights are on or when it's dark, the break lights should function when the brakes are pressed.
      08-09-2022, 06:27 AM   #3
jp182
Drives: X5 35d
And they are not coming on and neither are the turn signals
      08-09-2022, 07:51 AM   #4
momoboy
Drives: F15 35i 2017
My advice would be to first test the connection at the hitch itself. You can get one of these as it works for both 4 pin and 7 pin:
https://www.amazon.com/Oyviny-Traile...xpY2s9dHJ1ZQ==
If all is good there then it's your trailer wiring. A quick test would be to put your hazards on. The tail lights on the trailer (or lights on the tester) should flash
f15, trailer lights
