      01-19-2023, 04:34 AM   #1
Jason73
Drives: 2022 X3 M40i
Bimmercode?
I have a 2017 35i. I am using Bimmercode to code a few items but I am locked out from being able to code under the Headinit portion. I have emailed Bimmercode twice with no response. Any suggestions on how to access. I do have Carplay installed if that helps.
Thanks
      01-19-2023, 10:25 AM   #2
_ObiJon
_ObiJon's Avatar
Drives: 2015 428i xDrive
This may help...? I had the same issue but was coding a few ECUs in one "session" and got an error on the head unit. I skipped it and continued on. I then disconnected bimmercode, started the car, shut it off and reconnected. It was then able to read/write to the head unit.
      01-19-2023, 12:15 PM   #3
Jason73
Thanks, however, I have tried multiple times and still can not get into the headunit portion. I sent Bimmercode another message, hopefully I will get a response this time.
      01-19-2023, 12:42 PM   #4
_ObiJon
_ObiJon's Avatar
Sorry I was of no help. It was odd when I encountered it also. But I'm curious what bimmercode says, please update when you hear more.
      01-19-2023, 01:29 PM   #5
Jason73
Will do
      01-19-2023, 07:33 PM   #6
heifetz17
heifetz17's Avatar
90
Drives: 2013 328xi
I’ve heard in another group that bimmercode locks you out if you have CarPlay. I don’t have first hand experience but that other group says you will need to use e-sys if you have CarPlay.
      01-20-2023, 10:15 AM   #7
Jason73
Bimmercode is coming out with a release that allows headunit access with Carplay.
      04-03-2023, 10:30 AM   #8
andyjeffries
Drives: F15 X5 xDrive30d M Sport
That will be great, I've got the Carplay from BMW (so not an unofficial patch or anything) and can't customise anything in that section from Bimmercode.
      04-05-2023, 08:32 AM   #9
destroy26
destroy26's Avatar
165
Drives: 2017 BMW X5 35i
Hey OP. Have you previously used a third party service to code anything (like fullscreen CarPlay) remotely? If so, that may be the reason why you cannot access the Head Unit sub-section via Bimmercode. If you're not the original owner of the car, then a previous owner may have done this.
