02-26-2023, 09:46 AM | #1 |
Rep 15
X5 2017 stuck in park
I drove over a snow bank, now my X5 is stuck in park. When I move the lever to drive or reverse, it will show D or R then pop right back into Park. What is under the car that can cause this. It is a 4 wheel drive.
02-26-2023, 07:46 PM | #2 |
Rep 1,019
Mechanically? Nothing. Electrically? Everything.
The only mechanical thing on the gearbox that is external, is the emergency Neutral lever. This will force the gearbox into neutral. The parking actuator and paw is all internal. Do you have a code reader, see if its throwing any codes. Also have a look under there, is there any visible damage/impact on the sump? |
02-27-2023, 09:00 AM | #3 |
Rep 15
I looked under the car, I couldn't see very well but didn't see anything that was messed up. Two thing I wondered.
If the neutral lever under the car got jacked up, would that keep the car in park? Also, if the trans reset would help. |
02-27-2023, 09:52 AM | #4 |
Rep 162
Did you get stuck on the snow bank? Did the wheels spin for a period of time? It can be anything from an overheated trans, a bad transmission valve or something else. Like the previous poster said is it throwing any codes? If not I would see if there are any "shadow" or pending codes using something like Bimmerlink or other code reader. That would at least give you some indication and the possibly of clearing a code and seeing what happens
02-27-2023, 11:15 AM | #5 |
Rep 15
Yes, it was stuck on a snow bank. So you are saying if a wheel did spin for a bit, it could lock the trans into park? I am not sure how long the wheels spun. Not more than maybe 10 seconds. After a few attempts I then noticed the P light was stuck on.
02-27-2023, 11:58 AM | #6 | |
Rep 7,484
Perhaps the snowbank incident did something to this screw.
02-27-2023, 01:54 PM | #8 | |
Rep 7,484
The forum member "coil" wrote:
BTW...which X5 do you have? The V8 or I6? Can't look up any additional diagrams not knowing what to look for. EDIT: see the images and text below in regard to the LEVER...again, perhaps the screw is intact and unaffected...but all the frozen snow may have still moved the lever:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 02-27-2023 at 02:21 PM.. |
02-27-2023, 05:23 PM | #9 |
Rep 162
Ok. So it was stuck on a snow bank and you spun the wheels. Was it "high centered" meaning it was stuck on something underneath or just lost traction and you just kept trying to get it off the bank? Are there any lights on your dash when it shifts back to park?
Could something have knocked the pawl underneath, possibly. Unless it was a chuck of ice or REALLY packed snow not likely. Is it stuck where it happened or did it move after that and then now it's an issue? You could have overheated the trans but it would have then cleared up once it cooled (or it least it should have). Could something have been damaged from the wheel spinning, possibly. The only other "safety" feature that would cause the transmission to go back to park is if it thinks a door is opened. I assume you might have checked that but it's worth a try to open and close each door. If you have no lights on the dash and no error codes being thrown I'm not sure where else to look |
02-27-2023, 06:02 PM | #10 |
Rep 474
Not to high jack the thread but say you loose battery power and can't get the vehicle in N so you screw that bolt in all the way to achieve N. What if you had the Parking break engaged? That's electronic too so there must be a way to release that as well?
02-27-2023, 06:13 PM | #11 | |
Rep 1,019
kodpkd , You could of had a bit of ice/debris move the lever up whilst under throttle and that could of messed up the parking lever internally. Without a code scanner ISTA/BimmerLink/carly/etc, your only option is to look under the car. The screw/lever is on the left hand side of the transmission. If the lever is in the down position and you can move it freely. Than you have other issues, and best bet is to take it to a good indy/stealer |
02-28-2023, 06:50 AM | #12 |
Rep 474
02-28-2023, 12:44 PM | #13 |
Rep 15
I do understand there is a lever on the side of the trans. It is used to put the trans into neutral. From what I have read, that's all it does. Nothing to do with PARK. My big question, does the trans have a safety mode that will force it to stay in park? Is there a fault code/lockout that can be reset with an OBD2 reader?
It was high centered on ice. I think the wheels were only spun for a little bit, until I noticed it was stuck in park. There are not any warning lights on the dash. Last edited by kodpkd; 02-28-2023 at 12:52 PM.. |
02-28-2023, 06:06 PM | #14 | |
Rep 1,019
If I'm not mistaken, that N paw is designed to be engaged whilst the gearbox is in P, not in D whilst trying to move. Maybe as you beached it whilst underpower, the N paw was actuated and that messed up the P mechanism. Now its permanently stuck in P? Or as the transmission pan is Plastic, when you beached it, you damaged mechatronic unit. Bottom line is, without a half decent code reader and/or sticking your head under there and looking at things more intently. There is no way to guess why its stuck in P. |
02-28-2023, 06:31 PM | #16 |
Rep 162
As others have said you need to see if there are any codes and/or get the car on the lift. You might have cracked the pan draining all the trans fluid or something else. Anything other than a code reader and putting on a lift you are just guessing.
02-28-2023, 06:34 PM | #17 |
Rep 15
The plastic trans pan cracked. Such a cheap way to save $10 on a BMW. I am surprised nobody knew when the trans loses oil the car wont come out of park whan you try to move it.
02-28-2023, 06:36 PM | #18 |
Rep 7,484
Ditto…i have a screen capture from the owners manual in my pic stash…see below.
Florida-X3263.00 |
02-28-2023, 06:42 PM | #19 | |
Rep 1,019
Best case, replace the pan, fill it with oil(properly) and its fine. *EDIT*, just hope that you instantly lost all oil pressure and you didn't suck any debris into the mechatronics or other parts. |
02-28-2023, 07:17 PM | #20 | |
Rep 162
If you are lucky, as previously stated, get the pan replaced, fill with fluid and pray. Lets hope something didn't overheat and get damaged anywhere as a result |
03-01-2023, 02:37 AM | #22 |
Rep 1,260
