10-18-2020, 08:30 PM | #1 |
Rep 893
Help with Transfer Case errors
Mileage of 49k on an 50xi. I have aftermarket staggered 21s. From what Ive read this could be an issue but at the same time, ive seen plenty of X5s with staggered 21s.
Recently started having vibrations/shuddering on acceleration while getting onto the highway. From my research on here I assumed it was the transfer case. About 2 weeks ago I did the fluid change myself and recalibrated with ISTA. The fluid was very dark/black. Since I changed fluid, the issue hasnt gone away. I also noticed sometimes in Park the car vibrates a little bit. I ran the fault codes with ISTA and this is what came up: CDA426 - No message (status, distribution, longitudinal torque, front axle, rear axle, 19.3.4) 102006 - Hot film air mass meter 2, air filter element 2, signal, coupling: Poor incoming flow 102004 - Hot film air mass meter 2, air filter element 2, signal: Poor incoming flow D016E4 - Message (distribution status, longitudinal moment, front axle, rear axle, 19.3.4) mis... 48068C - Transfer box: Temporary fault, temperature D358F8 - Signal (status distribution longitudinal moment front axle/rear axle, 19.3.4) invalid... ISTA shows all the 'longitudinal moment' and transfer box errors popped up at the exact same mileage. There have been NO error lights on the dash. Something else I noticed is ISTA is showing the errors happened at mileage of 79XXX...where does this number come from since I only have 49XXX on the odometer? Small update: in regards to the MAF sensor errors, I pulled both out and cleaned them, the passenger side one one looked to have a bit of oil residue on it. I also noticed the Crankcase Vent lines are cracked so looks like ill be giving the dealer a call this week to get those taken care of. See this thread: https://testing-public.carmd.com/Tsb...0B01%2012%2018 Last edited by vastano; 10-19-2020 at 09:25 AM.. |
10-18-2020, 10:08 PM | #3 |
Rep 2,518
Did you check it with ISTA before you changed the fluid in transfer case or after? May be there are 2 different issues going on, transfer case and MAF dirty/vent lines are cracked? Try to troubleshoot one at the time so you can better understand what is wrong. I hope your transfer case is not going out, but just in case there is a great thread about rebuilding it.
10-19-2020, 05:21 AM | #5 |
Rep 85
10-19-2020, 09:19 AM | #6 | ||
Rep 893
As far as a xfer case rebuild goes, i've never done any sort of trans/diff/xfer case work, but I have quite a bit of experience DIY-ing. In the thread he mentioned it was easy if you have xfer case rebuild experience, but it still seemed very simple. I checked the thread and the removal of the xfer case looks to be the toughest part of the rebuild. Can anyone chime in if theyve done the rebuild themselves? Here's the thread we're referring to: https://f15.bimmerpost.com/forums/sh....php?t=1721902 |
10-19-2020, 11:39 AM | #7 |
Rep 535
Get rid of the 21s until you rule out a transfer case issue. TC is very sensitive to uneven tires or wheels at the larger size. Unpopular opinion I know.
Vibration during park may be coils or plugs too. Hard to say.
Present: 2014 X5 50i
10-21-2020, 10:00 AM | #9 |
Rep 1,564
Had similar issues as you, problem was caused by running michelens up front and hankooks in back, cheap hankooks had different circumference even though it should have been same, some tire manufacturers just lie.
Pulling fuse on transfer case is easy way to test if it's causing issues, will force into 2wd mode. Besides calibration, ISTA also has a full diagnostic test built in for the transfer case. You have to manually add the transfer case as having problems and tell ISTA to build a test plan if you don't have any more codes. Don't rebuild your transfer case yet until you eliminate more variables. I am at 160k miles on orginal transfer case from previous gen (your transfer case is a updated version of the unit in mine). I was in similar boat as you about 30k miles ago when I almost spent money to rebuild mine before finding true cause. Even if you do all work yourself, your looking at close to a grand in parts and tools. Get new MAF's too, not worth it to take chances just on cleaning. They can make you chase your tail trying to find issues. |
10-21-2020, 01:36 PM | #10 |
Rep 535
Do you remember which fuse? Only things I have seen is to disconnect the transfer case physically by getting below the car.
10-22-2020, 12:17 PM | #11 | |
Rep 893
Ill see if I can find the diagnostic test in ISTA, hopefully that'll shed light on what the problem really is...if it is the xfer case. I was trying to hold off until 60k to do all the fluids & plugs but I may have to move that up to 50k for peace of mind. |
10-26-2020, 09:39 PM | #12 |
Rep 893
Small update. Put the OEM wheels on, checked the codes and it pointed to the MAF sensor again. I ordered 2 of those from FCP.
I also took the X5 to the dealer today and they replaced the cracked vent hoses. Long story short, I do still have the vibration issue . With the car having the oem wheels on, I’m hoping the MAFs are the issue. If not, plugs and coils with be next as preventative maintenance. |
11-08-2020, 07:15 AM | #13 |
Rep 893
I replaced the MAFs and car seems to be running smoother but still hesitates and jerks on acceleration.
Yesterday I got on it in sport mode and it bucked pretty hard and then an error popped up with Drivetrain Malfunction along with the car shaking when I came to a stop. I pulled over, turned the car off then restarted and no more shaking. I checked the codes when I got home and it pointed to a cylinder 7 misfire. I ordered plugs and coils so here’s hoping that’ll solve my issue. |
11-08-2020, 07:57 AM | #14 | |
Rep 110
11-08-2020, 12:00 PM | #15 |
Rep 893
Oh absolutely. I’m out of warranty and very vehicle savvy so I plan on doing all the work I need to on this. Based on the DIY thread it sounds like it only takes about an hour to change plugs and coils so no big deal especially if it fixes the issue.
11-16-2020, 08:09 AM | #17 |
Rep 893
11-16-2020, 08:10 AM | #18 |
Rep 1,665
Yah imma switch my coils and plugs again and see if mine stops... if not, imma make x5 RWD LOL
11-21-2020, 09:05 AM | #19 |
Rep 893
Well, I finally switched my plugs and coils and I’m happy to report NO MORE ISSUES! The X5 drives like it was meant to again. All 8 plugs were corroded pretty badly.
