05-07-2021, 02:30 PM | #23 |
Rep 297
Check under the hood where the cabin filters are. That area looks prime for collecting water. I would remove the filter housing and see if any drains there are clear.
06-14-2021, 08:23 PM | #24 | |
Rep 41
Here is what it looked like all the way around. Mark |
06-17-2021, 01:47 PM | #25 |
Rep 74
This sunroof draining issue was a pain in the ass, first the water backup corroded the FZD module connectors causing the car alarms to go off randomly. The car insurance covered the replacement of the module (~1k), but not the diagnosis of leak and fix. After it rained, the water used to get accumulated and leak inside through the overhead dome maplight
I took to a local shop and tried few things to clear the damn drain and still the front passenger side was 100% blocked. Finally, I took it to the dealer since several shops recommended that the dealer would be well equipped to fix this correctly. The 3rd party extended warranty which I have from carchex does not cover the leak. I have attached work they performed (hopefully, this helps out someone) and now it fully drains. I dare not open the sunroof again. |
The Libertine1237.00 |
06-17-2021, 06:37 PM | #26 | |
Rep 1,222
