      05-27-2017, 02:00 PM   #23
Originally Posted by MysticBlue View Post
I didn't say front was back or back was front. My point, we don't have rears because Americans would turn them on and leave them on. I have them but use them properly. I only use them when it's foggy. And my front fog lights work just fine as turning lights when the switch is in auto. They don't have to be "on" to work. And you are correct. They really aren't very good at being fog lights... they are too high up and too blue/white. So, I really don't use them for much of anything. I just let them be turning lights. And I'm plenty relaxed, thanks.
I've lived in the US for over a decade. I can count two hands the amount of times I've seen incorrect rear fog light usage.
      05-27-2017, 05:51 PM   #24
MysticBlue
That's because very very few manufacturers provide them to the US market. If they did, then we would see incorrect usage on a daily basis.
      05-27-2017, 11:11 PM   #25
SCA
SCA's Avatar
Drives: Multiple BMWs
As a child my parents solely owned Mercedes-Benz thru the 70s and up to the mid 80s. They all had rear fog lights.
      05-28-2017, 07:38 PM   #26
MysticBlue
And they still do in Europe, but not in the US anymore.
      06-01-2017, 07:40 PM   #27
jgb87
Drives: BMW F15 35d
Today I checked the wire harness from the vehicle to the xenon headlight and it is the same as the led headlight. Is the coding the only thing required to make them work or do the wire connections have to be moved around?
monkiboy534.50
      06-02-2017, 12:21 PM   #28
MN2///M
MN2///M's Avatar
Drives: very fast!
So I'm assuming you mean the connector to the headlight is the same. Have you obtained a wiring diagram to see if the wires actually go to the same place?
If the ECUs are the same, then my guess would be that the wires do, but I would confirm before plugging anything in. If all the hardware matches up, then it should just come down to programming. I would think that BMW would keep as much as they can the same as it simplifies production and support down the road with replacement parts.
This is all speculation of course.
You'll be the first as far as I know; you should do a DIY thread on it.
2003 BMW 330i
2016 BMW M4 - ED May 2016, PCD Aug 2016
2017 X5 xDrive35i - PCD Jan2017
      06-02-2017, 02:55 PM   #29
Flying Ace
Flying Ace's Avatar
4985
i didn't understand the benefits rear fog lights until I was in a rain storm on the highway and the Mini on front of me had them activated. The spray kicked up from the rear tires basically masked the taillights of the Mini. The lighting conditions were also quasi-dark and the color of the car matched the gray spray. The only thing that indicated where the car actually was those rear fogs.
I activate my rear fogs on my M3 when it's raining and foggy now.
P111572.00
      06-02-2017, 07:49 PM   #30
jgb87
Drives: BMW F15 35d
Does anyone have a wiring diagram for the headlight connector?
      09-11-2017, 01:01 PM   #31
monkiboy
Dominican Republic
535
Drives: '17 x5 3.5i w/MPPK & MPE
hope to see an update soon as i'm in the same boat with xenon to LED headlamps!
P111572.00
      09-25-2017, 12:51 AM   #32
monkiboy
Dominican Republic
535
any updates?
would the stalk be needed for auto high beam or perhaps can be coded on automatically ?
      10-23-2017, 01:46 PM   #33
monkiboy
Dominican Republic
535
since no one was able to provide the information on here I set out to accomplish and did so successfully. details in the build thread. photos will be loaded soon! definitely happy with the change and coded for euro and hba and anti-dazzle which is cool. http://f15.bimmerpost.com/forums/sho...php?p=22336774
