08-05-2014, 02:40 AM | #23 |
Guest
Rep n/a
Drives:
08-05-2014, 03:42 AM | #24 |
bmw x5 x25d
6
Rep 105
TPMS was indeed one of the upgrades of post April 1 production this year. Also, FYI, coasting is a standard setting controlled through the iDrive here in Belgium.
08-05-2014, 04:59 AM | #25 |
Rep 424
To code 'Tire Pressure and Temperature on Vehicle Status' Look in: "HU_NBT" "3001 RDC_DRUCK_TEMP" Change from: "druck" to: "druck_und_temperatur" Simples! - worth a try anyhow!
X5 F15 - gone after 5 months!
08-05-2014, 05:02 AM | #26 |
Rep 424
Thanks for that, interesting to see where in the world 'coasting / sailing' is enabled by default - the feature is working OK here though still can't find the parameter to pass the 'distance coasted' data to the coasting odometer...
08-05-2014, 05:19 AM | #27 | |
Guest
Rep n/a
Drives:
What's the sailing settings? Thanks |
08-05-2014, 05:37 AM | #28 |
Rep 424
Coding Work Sheet Updated
08-05-2014, 06:01 AM | #29 | |
Rep 3,990
08-05-2014, 06:18 AM | #30 |
Rep 424
Hi, parameters are for LED package only. I put notes in the first column though they're maybe not descriptive enough! If you need more info let me know.
08-05-2014, 06:58 AM | #31 |
Rep 3,990
Thank you for clarifying . I was just curious. I figured it was related to the LED Lighting package by the descriptions you wrote regarding the high to low beam information.
08-05-2014, 07:43 AM | #32 | |
Rep 424
Also having both high ands low beam LED's used when flashing the headlights has to be a GOOD thing!
08-05-2014, 11:19 AM | #33 | |
Rep 450
08-05-2014, 05:05 PM | #34 | |
Rep 3,990
The flashing sounds convenient. Is this for the lights flashing when unlocking/locking your car or when you push the handle forward to flash the high beam? I'm just curious . Gotcha. I guess 5 is good when you're stuck in a tighter traffic situation and need a longer indication so that people know you're shifting over. I can see the safety convenience .
08-05-2014, 05:24 PM | #35 |
Rep 78
it might just be different customs in different countries. In Australia, I feel that if i changed lane and only gave 3 flashes of prior warning, it would be almost considered cutting people off.
08-15-2014, 04:17 PM | #36 |
Rep 17
My F15 was in for new steering column stalks(heated steering wheel issues) full recode of car done. I asked the stealers to code the mirrors and boot to close on one touch. Also asked them to activate the enhanced Bluetooth. Guess what? Nah, can't do that, our software won't allow us to!!! Anyone in fife area able to do the above without affecting warranty please? Cheers
08-15-2014, 04:25 PM | #37 | |
Rep 450
08-15-2014, 05:21 PM | #38 |
Rep 17
Heated steering packed in after 2 months...then the led lights in all doors and footwell lights went out. All to do with a control module attached to indicator/wiper stalks... Changed, recoded and all good! Had them change my dodgy fold out door seals as well and fix the rusty brake hubs/drums! My F15 was one of the first in UK and had a few issues, all sorted now and John Clark Tayside have been fab tbh...
08-15-2014, 05:51 PM | #39 | |
Rep 424
08-15-2014, 06:32 PM | #40 |
Rep 17
BMW will only fix them in first year(according to dealer) so yes, complain! Shouldn't happen on such an expensive luxury car. My wife's new 3GT has alloy hubs that won't rust...why they fitted crap to the X5? No one knows...
08-16-2014, 03:40 AM | #42 |
Rep 58
Please can you share what they say about the rusty brakes? I'm assuming they'll just say it's normal but it would be good to know if someone has actually had them fixed. I'm not really sure how they would fix them - replace them with parts that will in turn rust a few weeks later?
08-16-2014, 04:41 AM | #43 |
Rep 136
Be interesting to see if they notice or comment on the coding you have undertaken, good luck with getting the brakes sorted I agree should not happen on premium cars
08-16-2014, 06:11 AM | #44 | |
Rep 424
I did loads of coding on my F25 X3 and never received a single comment during the two years I had it, you'd think the errors generated when coding some modules would be recorded on the key-fob though they never mentioned it.
