      06-07-2017, 09:30 AM   #1
WCH
WCH's Avatar
Drives: '20 M8C convertible
Tire advice
I have the 21 in OEM wheels on Michelin PSS. I have to swap out the two right side tires due to damage/nail. They have about 5000 miles on them. Do I need to change all four tires?
      06-07-2017, 09:36 AM   #2
PatrickC23
PatrickC23's Avatar
2013 BMW ///M5  [0.00]
I think there is a newer, better version of PSS now I think. If so, I'd swap all 4 and sell your other 2 used ones.
2016 991.1 911 Carrera GTS
2016 F85 X5M - Carbon Black/Mugello Red
WCH347.00
      06-07-2017, 09:43 AM   #3
WCH
WCH's Avatar
Thanks. Doesn't look like the new PSS is available in the sizes for the 21 inch wheels yet.
Just wondering if the new tires will cause issues with the other older ones.
      06-07-2017, 12:01 PM   #4
Alpine300zhp
Drives: 24 M4 Comp RWD
The tires should be within 2/32nds of each other. Full tread is usually 10/32nds so you are fine if your other tires are around 8/32nds.
~ 24 M4 Comp
~ Prior BMW's - Too many to list here (27)
WCH347.00
      06-07-2017, 12:16 PM   #5
WCH
WCH's Avatar
Thanks!
      06-14-2017, 08:35 PM   #6
WCH
WCH's Avatar
So I ended up buying 4 new tires.
Two used but undamaged tires now up for sale:
http://f15.bimmerpost.com/forums/sho....php?t=1394235
      06-15-2017, 12:13 AM   #7
///MLOVER
Drives: Bmw m3
What tires did you end up buying?
      06-15-2017, 06:14 AM   #8
WCH
WCH's Avatar
Michelin Pilot Supersports. The new Pilots are not yet available in the 21" X5M size.
      08-14-2017, 12:31 PM   #9
rye_a
Drives: X5M
I know this goes back a couple of month, but based upon your post are the Michelin PSS not repairable for nails, etc, similar to the Pirelli P-Zeros? If so, are the PSS significantly preferred?
      08-16-2017, 09:28 AM   #10
WCH
WCH's Avatar
You can patch the tires if the nail is in the center. Has to be away from the sidewall.
