      05-14-2019, 07:51 PM   #1
Zorikos
Drives: 2014 x35i
Catless downpipe stinks!
Ok guys, I installed an ER catless downpipe and my eyes burn every time I drive the car! This is with the windows closed. I figured it would smell somewhat from the outside or If I had the windows open but this is bad.
I’ve owned other cars with no cats and it was never like this. I don’t understand how people are tolerating the smell when going this route.
I’m planning on putting back the stock converter, but was wondering if there might be something else to check that might be amplifying the condition?
      05-14-2019, 08:38 PM   #2
Some Asian Guy
Some Asian Guy's Avatar
Drives: 2015 BMW X5
You sure it's not leaking? Did you replace all gaskets? I've driven many catless cars and the smell has never been an issue for me.
      05-14-2019, 09:07 PM   #3
Zorikos
Drives: 2014 x35i
Leaking from where? There were no gaskets.
      05-14-2019, 09:14 PM   #4
Some Asian Guy
Drives: 2015 BMW X5
I went to the website to see what the downpipe looks like. I didn't see one for a F15 N55, which one did you order?
EDIT: I found it on a different website and looks like it doesn't need gaskets. My bad. But it does sound to me that you have a leak.
      05-15-2019, 10:57 AM   #5
You are having a leak somewhere.
Most likely is the installation.
Is it a brand new downpipe or used one?
      05-15-2019, 11:26 AM   #6
Does not sound healthy...
      05-15-2019, 02:50 PM   #7
Zorikos
Drives: 2014 x35i
The downpipe was brand new. I had difficulty installing it to the backside of the turbo...that v-flange was tough to access. After the installation when everything was buttoned back up I had the car idling on the lift and didn't see any leaks.
What's the best way to check for leaks?
      05-15-2019, 02:53 PM   #8
Zorikos
Drives: 2014 x35i
Yes for sure. I may be more sensitive compared to others, but with the hvac working I can smell it. With the hvac off and the windows down its fine unless the wind blows it in my direction.
      05-15-2019, 03:30 PM   #9
This would be a tough one to check for leaks.
You can do visual or sniffer (not sure if you can rent from AutoZone or PepBoys).
Your HVAC filter is on the passenger side right above the turbo.
So, if you have leak, it will get sucked in.
My guess is your V-Band or O2 sensors didn't get installed back properly.
      05-15-2019, 04:05 PM   #10
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
My guess is it just stinks.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      05-15-2019, 08:09 PM   #11
There is a pressed gasket that sits on the turbo.
May want to check that too.
      05-15-2019, 08:25 PM   #12
TOPEC
<3 Flat Four
Drives: 335is LM Blue
soap n water spray test lol. just spray the seams/joints/connections really well and see if it bubbles, unless u have a large gap where the soapy water wont seal and blow bubbles.
im just wondering if theres some kind of coating on the pipe that is getting burned off. i remember my mazda was horrible when new. when the engine heats up and burn off the coatings (rust prevention coatings/paraffin wax?), it smelled like burning engine oil along with stinging eyes, after a few thousand KMs though it was fine.
2011 335is Le Mans Blue
      05-15-2019, 10:20 PM   #13
turboawd
1636
Drives: 2015 X5 35i
Take a bike tube and clamp onto exhaust end. Pump exhaust with air. Listen for leaks.
Or if you do a visual inspection, you may see black marks where it leaks.
But even if you have no leaks, the exhaust coming out of the pipe will smell because you don't have cats.
r33_RGSport12971.00
      05-21-2019, 08:04 PM   #14
AECDY
299
Drives: BMW F15
Did you find the problem with the DP?
      05-21-2019, 09:53 PM   #15
spacegray_f15
Drives: 2014 N55 M sport
Would also be interested to see if you found a leak. I have the same issue, it smells like straight gas, I've had it on other cars before but never this bad. It also sounds a little raspy in low rpm but I smoke tested it and I couldn't find any leaks 🤷🏼*♂️
      05-21-2019, 10:40 PM   #16
Really? You too?
Is your AC set to circulate or fresh air?
      05-22-2019, 10:18 AM   #17
AECDY
299
Drives: BMW F15
Anyone else here has this installed that can chime in? I was getting ready to pull the trigger but now hesitant as I my kids ride in the car almost everyday.
      05-23-2019, 09:07 AM   #18
AECDY
299
Drives: BMW F15
Ben, have you install this on any other local customers? How are they doing with them?
r33_RGSport12971.00
      05-23-2019, 09:59 AM   #19
Had it in my F15 for 3 years and fine with it.
Installed locally and don't have issues with it.
Sold bunch of them across the US and internationally, this is the first complaint I've ever heard.
AECDY299.00
      05-23-2019, 01:16 PM   #20
AECDY
299
Drives: BMW F15
Thanks Ben.
r33_RGSport12971.00
