07-16-2019, 07:25 PM | #1 |
Rep 165
Oil Filter holder broken
hello everyone,
so I was doing my regular oil change on my f15 and when I was trying to take out the old oil filter the piece that holds it in place broke. when I looked at it. The teeth inside broke for some reason. this made the spring inside come out. I keep looking online for the part but I can't find it. Also does anyone know a better way to take out the old filter? every time I have to change it to a new one it becomes a problem because the filter always gets stuck. I posted a picture of the piece. thank you for your help. |
07-16-2019, 07:39 PM | #2 |
Rep 60
Drives: 2014 X5 X35i
Have you tried FCP Euro? They seem to have just about everything.
Steve
2014 X5 xDrive35i 1983 320i (many years ago, but it's good to be back in a BMW) |
07-16-2019, 07:52 PM | #3 |
<3 Flat Four
217
Rep 754
check here for P/N, this is for the N55, should be number 2
https://www.realoem.com/bmw/enUS/sho...diagId=11_4466
2011 335is Le Mans Blue
07-16-2019, 08:43 PM | #4 |
Rep 165
TOPEC , number 2 looks like the the cap. what I'm looking for is what's inside the cap. in the website you sent me it shows me the cap which can be seen from the outside when you open the hood. what i'm looking for goes inside the actual cap.
sdk8103, i'm going to check that website out. I didn't know if they were legit. thanks |
07-16-2019, 08:55 PM | #6 |
Rep 165
turboawd I have searched part number 2401643129 but that same piece doesn't come up at all. instead I get another cap with a similar piece attached to it. its a completely different set up from the one my Bmw came with since its two different pieces that are loose and not attached to each other.like the one they are showing me when I search for that part number.
07-16-2019, 09:11 PM | #8 |
Rep 165
turboawd I checked realoem, FCP, and I just check bmw of Atlanta since they have an online parts store and I haven't found anything yet. my last option would be to visit bmw of Manhattan which I don't want to since they like to add 50% more to their prices.
07-16-2019, 09:34 PM | #10 |
1636
Rep 2,995
Is this what you need? You have the 6 cylinder gas?
https://www.amazon.com/dp/B07N7V25SG..._jKOlDbD4GGBX3 |
07-17-2019, 11:45 AM | #13 |
<3 Flat Four
217
Rep 754
what u broke off (the stem part that holds the filter in place) is supposed to be attached to the cap no? so u order a new cap u get a new cap with the stem attached.
