      06-29-2023, 03:36 AM   #111
mianmehran
Drives: Bmw X6 F16
Originally Posted by MK2018 View Post
Yesterday I coded mine, I have changed parameters in 4 spots
ProfileCloseStopNode1PwmPlg, ProfileCloseStopNode2PwmPlg
ProfileCloseStopNode1PosPlg, ProfileCloseStopNode2PosPlg
It works very good on my 2018 X5
Thanks for Explanation
I coded Mine which is s x6 F16 2017 july
I use online decimal to hex calculator
I converted 85 insted of 160. The value came up 00x55
Its so smooth and soft close now. It can not be better than that.
Nor More Bang. Happy Days
      06-29-2023, 02:21 PM   #112
tfunk88
192
Drives: F15 X5 50i
Just did this with my 2016 F15. Ended up going with 18, 25, 40, then 58 for the rest. It’s perfect now, no bang at all, just a soft “off” to let me know it’s closed before the latching mechanism takes over!
      07-21-2023, 04:25 PM   #113
srg_va
Drives: E60
Just to keep this thread update:
Dig into CAFD of my F31 and found the lowest default value of 00 5A (which equals 90) for ProfileCloseStopNode1PwmPlg (HKFM2). Codded. Everything works without any slam.
Sharing below the list for supported values from CAFD which I found which will work for 100%. In my case i had 00 BE coded by default and that was noisy. When coding 00 0A as advised above (which is not in the list) the lid was not closing completely after the car slept and was restarted hence my advise would be to use either 00 5A or 00 64
00 5a wert005A
00 64 wert0064
00 82 wert0082
00 8c wert008C
00 aa wert00AA
00 b4 wert00B4
00 be wert00BE
      07-25-2023, 09:11 PM   #114
moeba2008
Drives: 2015 BMW xDrive35i
Originally Posted by sbrook02 View Post
Based on the above tips for 2017+ X5, here is where to find the coding locations in BimmerCode:
Tailgate Function Module > 3011 APPL_PLG_SPEED_PROFILE
Parameters to change are the byte values for closing power at different positions in movement. Reduce to slow down.
ProfileCloseStopNode1PwmPlg, ProfileCloseStopNode2PwmPlg, etc.
Make sure you change both Node1 and Node2 power values for best results (the Facebook tips only mention Node2 therefore it's not ideal. If you only want to change one then better to change Node1). A lower power will give you less slam. So if you are not happy with 00C8, pick a smaller byte value such as 00A0.
The following hex values in ascending order are provided by BMW:
000A, 00A0, 00BE, 00C8, 00FA, 017C, 0212, 0226
corresponding to decimal values of:
10, 160, 190, 200, 250, 380, 530, 550, respectively.
This worked for my 2018 F15. I programmed all 4 as well. First try,
The tailgate stopped short of closing!!! I reopened it then closed it again and it finally worked. Tested a second time for good measure and it was all good.
So happy. My 2015 x5 was much easier to code and I didn’t have to go into expert mode but I did have to go expert for my 2018 x5.
I love This forum. Thank you all so much!!
      11-07-2023, 02:50 PM   #115
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Not sure why this took me so long but I finally did this. Amazing satisfaction! Thank you to those that figured this out.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
