07-31-2015, 10:54 AM | #1695 |
Rep 16
Wifi hotspot dlna
I coded in wifi hotspot so I can stream video and audio to car over dlna server. Wifi menu comes up on connections. However when I click down to check the box 'Vehicle WiFi' nothing happens. What do I do?
07-31-2015, 10:58 AM | #1696 |
Rep 40,310
There is nothing to do. BMW removed WLAN functionality from NBT firmware shortly after NBT's debut in 2013. You can code it, but it will not work.
07-31-2015, 12:30 PM | #1697 |
Rep 16
07-31-2015, 12:34 PM | #1698 |
Rep 40,310
07-31-2015, 03:22 PM | #1699 |
Rep 578
08-05-2015, 09:59 PM | #1701 |
Rep 145
If I code turn signal on HUD, will that result in a new setting for HUD that I can turn on/off, or it will always be on and needs coding to turn off?
08-05-2015, 10:12 PM | #1702 |
170
Rep 386
08-05-2015, 10:18 PM | #1703 |
Rep 226
Can I have the latest psd files for a 2016 x5 35i? Do we need anything special to code? is the cheatsheet still valid? I know for awhile there were issues coding because they changed something. are we back to normal?
08-05-2015, 10:20 PM | #1704 |
Rep 40,310
PM sent.
08-06-2015, 04:16 PM | #1706 |
Rep 578
08-06-2015, 04:37 PM | #1707 |
Rep 40,310
He is in Chicago, going to Med School.
08-07-2015, 08:53 PM | #1708 |
Rep 258
I am getting my car serviced tomm. for the 10k service...pretty sure I will lose my coding that Omar did...can anyone tell me where I can pay to get my car coded again? Thanks!
08-07-2015, 10:11 PM | #1709 |
Rep 578
08-08-2015, 05:49 AM | #1711 |
Rep 258
08-08-2015, 02:45 PM | #1713 |
Rep 258
Can any one explain how the rearview camera while in drive works? As in, lets say I am driving on the highway and I press the rear view camera option button I am able to see it?
08-08-2015, 05:20 PM | #1714 |
Rep 196
Yes you can see the rear view for all of about 15secs before it turns off. You can also see the 360 view if you have it for the same amount of time. The front camera if you turn it on will stay on until you turn it off.
08-09-2015, 08:17 AM | #1715 |
Rep 258
08-09-2015, 09:22 AM | #1716 |
Rep 222
I have successfully joined the coding ranks... great thanks to Opasha, Shawnsheridan and everyone else on this lengthy thread I had a rocky start, as I had to uninstall and reinstall several times, as the launcher couldn't find E-sys ... I think my mistake was using the link from the installer rather than closing that and using the desktop link, but I finally got it working, and then ran several sessions with no error codes ever coming up! For some reason "unlock when STOP engine" isn't working, next time I go back in to code something else I will see if I screwed it up, or if I did it right. I was a little overcautious, and put off VO coding until next time, and only did FDL coding... yes I know that this means when I VO code VLD and 6NS I will have to recode the FDLs that are in those CPUs, but that's ok. This is what I've done so far, and everything I have l tested so far works great!:
In the next round:
This is my first coding of any car, and I'm not an IT/network wiz, so if you are thinking about doing it but are worried, I'd say go for it. Also, note that I have the OBD/Ethernet cable, but my laptop doesn't have an ethernet port, so I used a ethernet to USB3 adapter purchased for short money on Amazon. good luck! . Last edited by wearenh; 08-09-2015 at 02:19 PM.. |
