      04-14-2021, 10:55 AM   #1
jkwhar
Drives: F30 328i Xdrive | F15 x35i
Ticking noise while accelerating/load?
(I tried googling but found nothing lol). I have a '14 n55 with around 85k and realized theres a ticking noise while underload/accelerating that i noticed while driving with the window down and driving next to a wall/barrier so the sound bounces back to me.
It only happens when accelerating. The ticking doesn't happen if I rev'ed the engine while in neutral. It would also stop ticking when its switching gears. Its only when theres a load.
Anyone have any thoughts? TIA!
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD)
      04-14-2021, 11:06 AM   #2
scotty339
Drives: 2015 BMW X5 x35i M-Sport
Does it sound like this?
https://vimeo.com/464610908
      04-14-2021, 11:12 AM   #3
jkwhar
Its not. Its more like ticking/clicking cv axle. Its faint enough that I cant hear it if I'm not driving next to a wall/barrier for the sound to bounce back.
      04-14-2021, 11:18 AM   #4
scotty339
Try and get a video. Will help.
If you think its the CV, Id crawl underneath / put it up on stands / lift and rule that out.
      04-14-2021, 12:30 PM   #5
jkwhar
Were getting some rain this week so I'll try next time its sunny. Thanks!
      04-14-2021, 01:06 PM   #6
turboawd
1642
Drives: 2015 X5 35i
Could be exhaust leak
      04-15-2021, 12:16 AM   #7
Gkacmaz
Drives: BMW X5 50i
Sounds like the exact problem I had. Would only come under load/acceleration with no sound revving the engine in neutral. It was the drive Axle. When I checked I noticed lots of black grease everywhere. The rubber boot tore and debris and dirt got in the bearings and messed everything up, had to get a drive Axle and popped it in, done everything back to normal
      04-16-2021, 07:41 AM   #8
sergiyny
Drives: BMW X5 M Sport
I'm having the same issue. Could you please post a picture where should I be looking at to see the problem?
      04-16-2021, 07:55 AM   #9
sergiyny
What could possibly cause the ticking noise?
      04-16-2021, 09:14 AM   #10
Gkacmaz
Drives: BMW X5 50i
This is the drive Axle that goes into your wheel hub to spin the wheels (some call it Axle shaft output, CV Axle etc). Behind those black rubber boots are bearings. Over time the rubber loses it's elasticity and tears. When that happens dirt and debris gets inside the bearings and damaging them. That's where the clicking comes from, at least in my case. What you need to do is lay under the car and check the shaft that goes into the wheel, you have one in each wheel since it's all wheel drive, unless you have SDrive which is only rear. If your rubber boot is torn you should be able to see black grease around that area. If that is the case you need to replace your drive Axle
      04-16-2021, 09:23 AM   #11
sergiyny
Thank you! I'll be checking them this weekend.
      08-15-2021, 04:57 PM   #12
BeachsideF30
Drives: E90--> E92-->F30
Did anything ever come of this?
I'll post an update on mine as well. Tonight I did a test drive. The sound only comes on during low rpm load at low speed. It typically happens from 0-30/40mph under load not reaching high rpms. As I was driving around 15-20mph I would shift into N and give it about 2-3k worth of gas, no noise... Shift back into D give it the same 2-3k worth of gas and the noise is there. Parked in my driveway next to another car gave it some revs and nothing while in P. So it only happens while the engine is engaged with the transmission and the vehicle is under load. If it's not under load there is no noise moving or stationary. I got under the vehicle and checked the CV axle boots as mentioned above and both as clean and buttoned up. Very strange.
      08-17-2021, 08:11 PM   #13
BeachsideF30
Is anyone else having or had an issue with this?
      08-18-2021, 09:55 AM   #14
scotty339
Do a stall test.
Left foot on the brake. Vehicle in D. Rev to 3-4 K RPM, see if the sound happens while none of the running gear is moving.
Will help you eliminate certain components.
Post your findings back here. My bet is on your transfer case.
For me, I can replicate my sound while doing this very easily, as the tick tick tick on decel is apparent.
      08-18-2021, 12:13 PM   #15
BeachsideF30
Do a stall test.
Thank you, I'll give it a try tonight when the car is at home. It is an S drive so could it be the rear diff? Since I don't really have an x drive transfer case
      08-19-2021, 08:28 AM   #16
Eurogreek
Drives: BMW X5 3.5
I have an 18 3.5 doing the exact same noise. I’m calling it in today for a service call. I have 48k miles just under the 50k warranty limit. I definitely want to get it in there.
      08-19-2021, 12:35 PM   #17
BeachsideF30
Mines an 18 35i s drive with 35k miles it's going on Monday to the dealer so we'll see what they
      08-27-2021, 12:11 PM   #18
EED14X5
EED14X5's Avatar
Drives: 2014 BMW X5
Anyone learn anything about this issue? I just noticed my 35i doing this last night.
      08-27-2021, 05:31 PM   #19
Eurogreek
Drives: BMW X5 3.5
I have my appointment on Tuesday.
      08-27-2021, 07:18 PM   #20
BeachsideF30
I just picked mine up today…here was the response. They had it for 3 days
EED14X513.50
      08-27-2021, 08:06 PM   #21
Fknid
Australia
39
Drives: BMW 2014 X5 50i
Could be low speed pre-ignition (LSPI) which is becoming more apparent due to engineers pushing the boundaries on engine efficiency. My N63TU was doing this quite badly. I’ve changed oil to one that meets the SN Plus standard. I found a Shell 5w-30 that meets the SN Plus and LL-01 standards.
The engine noise has mostly gone and response at low rpm under power in Comfort mode is now ok.
      08-29-2021, 08:16 PM   #22
135iUSN
19 X5 1998 M Roadster
135iUSN's Avatar
64
Drives: 135i Alpine White / Terra
1998 BMW M Roadster  [0.00]
2009 135i  [0.00]
Odd, 3 days in the shop to tell you this is normal?
Sad day
'09 135i Dinan In BMW heaven 09.28.2022 - Stage 2/Alpine White w/Terracotta /High Gloss Black Trim/ZCW/ZPP/ZSP w/313's /CA/PDC/Steptronic/
