01-12-2021, 08:44 AM | #23 |
Rep 90
I loaded the stage 2 tune. A little snappier over stock. Not earth shattering but a nice improvement. The fact that I can tune the Launch Control is an awesome feature. Seems like it would be a great thing to have if you 1/4 your car. So far I think it's a nice upgrade for the money.
2016 X5M DGM BM3 Stage 1 91
RK Autowerks Intake & RW Carbon parts |
01-12-2021, 09:46 AM | #24 | |
Rep 199
excu6me on Instagram.
OEM X6M Build |
01-12-2021, 11:02 AM | #25 |
IG: @88jae88
1622
Rep 1,741
I meant to make a post about this but I've been extremely busy... just to make things simple... DO IT you won't regret it especially for you 1/4 mile junkies like myself..😎
IM POOR..
BadCompany84.50 |
01-12-2021, 11:43 AM | #26 |
Rep 90
Here's a screenshot. I haven't played around with it yet but here's what I set initially using the stage 2 map. Haven't used it so I can't comment yet.
01-12-2021, 02:13 PM | #27 |
223
Rep 304
01-12-2021, 09:02 PM | #29 | |
Rep 199
So if the ECU tune keeps the torque at "reliable" numbers, shouldn't changing where it's delivered not put the car at any added risk?
OEM X6M Build |
01-12-2021, 11:07 PM | #30 | ||
IG: @88jae88
1622
Rep 1,741
IM POOR..
01-13-2021, 02:09 AM | #31 | |||
Rep 122
F85MTuNED1622.00 |
01-15-2021, 01:38 PM | #32 |
223
Rep 304
So quick check in, flashed stage 3 a few days ago. Got some miles on it to relearn adaptations. Highly recommend it. Big bump in low end power delivery, Comfortable smooth shifts driving mildly in D1, fast hard shifts in D2,S2 , ripping fast shifts in D3/S3. Do it.
BadCompany84.50 F85MTuNED1622.00 |
01-15-2021, 02:44 PM | #33 |
Rep 631
KLR X5M What drive mode(s) did you drive in prior to the tune? I am typically in D2. D3 holds gears a little long for my preference, at least in daily driving.
So....is D1 your preferred mode for normal driving and then D2 or D3 when you looking for more spirited driving? I will get the tune as well, just not sure about stage 2 or 3. |
01-15-2021, 02:47 PM | #34 | |
Rep 199
OEM X6M Build |
01-16-2021, 12:57 AM | #35 |
223
Rep 304
01-16-2021, 12:59 AM | #36 | |
223
Rep 304
01-16-2021, 06:37 AM | #37 | |||
Rep 274
Drives: 2015 M3
Femto is a software tool to flash your transmission if you're beyond a stage 2 as the tuner controls the parameters not a generic OTS TCU map. You can learn more about it here. https://fscmap.com/femto/ I cannot comment on XPH as I've never used it so please don't interpret this as a negative towards their products. Their products are designed to cover 99.9% of the tuned vehicles out there. It's when you start pushing significantly more power and torque than stock the transmission will need a custom flash to compliment your DME tune. |
F85MTuNED1622.00 |
01-16-2021, 08:32 AM | #38 |
Rep 90
Has anyone tried launch control mode with stage 2 or 3? Does the car still shift for you during this mode even though you're in manual mode like the factory tune does? I haven't tried it yet but I'm going to later today.
01-16-2021, 09:42 AM | #39 | ||||
IG: @88jae88
1622
Rep 1,741
IM POOR..
01-21-2021, 06:57 AM | #42 | |
Rep 643
01-21-2021, 07:41 AM | #43 | ||
Rep 90
Amatage RJ45 Ethernet LAN Network Adapter for Phone/Pad, Phone Ethernet Adapter, 3.3ft/1m Cable, 10/100Mbps High Speed, System Required iOS 10.0 or Up https://smile.amazon.com/dp/B07NW9HS...UTF8&psc=1
01-21-2021, 03:53 PM | #44 |
Rep 198
Thanks NikNala. Support told me to try putting the phone into airplane mode. I'm going to give that a try. Previously I had turned off Wi-Fi and BT.
