11-27-2014, 11:12 AM | #1 |
Rep 71
Disabling TPMS for winter
Just fitted some 19" wheels with Vredestein winter tyres. My summer 20" are run flat and have the pressure valves fitted but my winter wheels/tyres are non run flat and so I don't have or need the valves. I just plan to carry a puncture repair kit and pump or throw a jack, wrench and one of the 20" rims in the boot if I'm on a long journey. I think it will be quickly apparent if I get a puncture! Anyway just wondered if there is any way of turning the system off completely in the car i-drive system during the winter as now I get a continuous warning that the system cannot read the pressures. I don't really want to spend the money on getting TPMS valves fitted to my winter wheels/tyres as they are not really needed.
Anyone got any ideas? Thanks in advance.
Current: '14 ///M50d (F15) Alpine White|Alcantara/Dakota|Piano Black|20" 468M|Black Kidneys|HK Sound|Reverse Cam|Panoramic Roof|Sun Protect|Sunblinds|Extended Store Previous: '09 ///M3 (E93) DCT|Interlagos|Novillo Palladium Silver|Black Breyton GTS|Falken F452|CF Kidneys|CF Roundels|Individual Audio|EDC|DAB|USB|TV|CA Previous: '07 335i MS (E93) Auto|Le Mans Blue|Black Leather|CF Trim|Duke Dynamics Diffuser|CF Kidneys |
11-27-2014, 12:48 PM | #2 |
Rep 18,715
@rockdoc1971, you will need to code it. I believe it is in the HU_NBT module, I forget what it's called.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
11-27-2014, 12:51 PM | #3 |
Rep 71
Ah, OK thanks R33, bit of a nuisance as I don't know anything about coding or how to go about getting that done.
11-27-2014, 01:13 PM | #4 | |
Rep 3,990
http://f15.bimmerpost.com/forums/sho....php?t=1033991 This is the code, but I'm not sure if more needs to be done other than disabling it: Tire Pressure and Temperature on Vehicle Status/HU_NBT/3001/RDC_DRUCK_TEMP/none
11-27-2014, 02:02 PM | #5 |
Rep 71
Thanks Opasha, looks pretty complex, by the time I get everything and work it out I might as well just get the valves for the wheels fitted!
11-27-2014, 02:33 PM | #6 |
Rep 3,990
No problem, bud. It's really not that difficult. The only part you need to do is "download" the software and buy the enet cable ($20 - your only expense since I don't charge for coding help). From there, I can do the rest. It takes me about 10 minutes to set everything up. Coding that particular code would take 1 minute. Either way, good luck .
11-27-2014, 03:10 PM | #8 | |
Rep 71
11-27-2014, 03:14 PM | #9 |
Rep 71
Thanks Opasha, I would have to source a cable here in the UK, not too difficult on e-bay, then reluctantly install Windows software on my Mac as I don't have access to a Laptop.
Will have a hunt around and see if I can come up with a set of valve sensors in the meantime.
11-27-2014, 04:04 PM | #11 |
Rep 1,067
Why didn't you just buy another set of sensors. $250 for a set from getbmwparts.com. No issues with sensor warnings and you will have the benefit of know when your tires are low.
17 M3 ZCP -- 2017 Range Rover Sport SC --RIP-- 12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500 |
11-27-2014, 06:48 PM | #12 |
Rep 1,417
11-27-2014, 09:31 PM | #13 |
Rep 18,715
You can see it from the type of Valve Stems on the wheels or shoot me the last 7 of your VIN and I'll look it up.
11-28-2014, 12:41 AM | #14 | |
Rep 71
11-28-2014, 04:17 AM | #15 |
Four stripes vehicle commander
159
Rep 206
Just see my thread about similar issue also.
Just choose the right sensors for your car. http://f15.bimmerpost.com/forums/sho....php?t=1061055 I am just dissapointed why this shall be so difficult. Fantastic modern world. Bent |
11-28-2014, 05:46 AM | #16 | |
Rep 3,990
11-28-2014, 07:04 AM | #17 |
159
Rep 206
11-28-2014, 11:52 AM | #18 | |
Rep 251
Since I did get an alert in idrive the last time I had a screw in my tire, this would imply that the Canadian F15s use the tire rotation speed to monitor for pressure drop. This would have the benefit of not needing 2 sets of TPMS for summer and winter wheels. Hmmm...if I added TPMS to my wheels, would the vehicle use those readings instead??? |
11-28-2014, 12:00 PM | #19 | |
Rep 18,715
11-28-2014, 12:28 PM | #20 |
Rep 71
Thanks, had a read through the posts. And yes sometimes these modern things are just too good for their own benefit. Just wish I could hit OK and be done with it and then just hit reset once the wheels with valves are back on in the summer. I don't need reminding every time I start the car that the system is inactive. Ho hum, so long as the wheels have air and are still round I'm happy.
06-06-2020, 06:34 PM | #21 |
Admiral
930
Rep 3,886
Sorry for the thread revival, but does anyone know if this is possible via Bimmercode app? I am not finding the HU_NBT module on Bimmercode as mentioned above...
Help i appreciated!
2020 FORD RAPTOR 2014 F15 X5 | M-SPORT SOLD 2011 SG E90 M3 | 2008 AW E90 M3 | 2004 E46 M3 |
06-06-2020, 08:50 PM | #22 |
Rep 7,480
Help us help you better...what model/model year BMW are you asking about? The car info that is visible to the forum doesnt appear to be an f15/f16 X5/X6....so its hard to point you in the right direction to find the info you seek.
