11-09-2015, 05:43 PM | #67 |
Rep 18,726
All order are shipped and I have couple sets in stock now.
Taran.J I talked to Eibach USA when I was in SEMA, I need to drop my car off for testing before they can bring the spring to the US. I will keep you guys updated on this, I am aiming to be able to take care of this in the next week or two.
11-10-2015, 11:08 AM | #68 |
Rep 1,547
Yep..ACS springs / lowering links for me. The box is down at my PO box in Washington, going to head down tomorrow and grab it.
11-11-2015, 10:51 PM | #71 | |
Rep 18,726
Since you use longer lug bolt, I recommend bumping it up another 5lbs/ft.
11-12-2015, 10:09 AM | #73 |
Rep 1,547
I torqued mine to 103 ft/lbs.
11-13-2015, 03:04 AM | #74 |
Rep 35
I installed the rears last night, looks awesome. The spacer slid right on. I did the fronts tonight, and I had a hard time getting the spacer to sit flush to the brake hat, like it was almost too shallow.
Similar I believe to what Alan experienced with the 12.5 mm spacer Anyone else notice the snug figment ? Btw they look awesome |
11-13-2015, 06:46 AM | #75 | |
Rep 18,726
Did you clean up the hub beforehand?
11-13-2015, 09:36 AM | #76 |
Rep 1,547
^^^ I had to clean up the hub with a wire brush on each corner to get them to seat properly. Once I did that, no issues.
11-13-2015, 12:43 PM | #77 |
Rep 35
The truck has 1700 miles not much to clean.
The rears slid on and made a clap sound The fronts seemed to run out of sliding space 1 mm from making full contact to the hat. I used the oem bolts direct on the spacer to squeeze it closer and still a paper thin space... I figured if I torqued it with the wheel to 102 that it would close the gap. Seems to have worked but I will inspect further tonight. But there seems to be no way to remove the spacer now without a hammer and chisel. |
11-13-2015, 12:49 PM | #78 | |
Rep 7,063
11-13-2015, 12:54 PM | #79 |
Rep 18,726
For xdrive, don't put on the 15mm on the front, just found out it don't fit.
I'll post more after I finish the car I'm working on.
11-13-2015, 12:57 PM | #80 | |
Rep 7,063
11-13-2015, 03:29 PM | #82 |
Rep 18,726
Ok, it seems like the xDrive can't take the 15mm spacer since the hub length itself is 15mm.
One local customer came in to install a spring, when I removed the wheel, I found out the hubcentric part of the spacer broke off from the spacer. After further inspection, then I found out it don't sit flush originally. So far it is confirmed on the xDrive35d. If any of you who bought it from me that have xDrive35i or xDrive50i can confirm that it is the same issue, let me know. Take them off and I will refund you. This customer ended up with 15mm in the rear and I am ordering 5mm for the front. Once I got them done, I will post the picture.
11-13-2015, 09:32 PM | #84 | |
Rep 18,726
11-14-2015, 12:09 AM | #85 | ||
Rep 157
11-14-2015, 06:38 AM | #87 |
Rep 8,823
Makes sense why I couldn't put my H&R 15mm up front. Everyone thought It was installer error lol.
Wonder if it's all brand spacers will have this issue. Alan |
11-16-2015, 12:25 PM | #88 | |
Rep 18,726
Unless they make the hub separate. I saw one before, but I don't remember the brand.
