07-07-2019, 09:46 PM | #1 |
Rep 413
Another downpipe question :)
I think I am going to pull the plug on adding a high flow catted dp on my n55 F16. But before I do that, I wanted to find out a few thing from somebody who had a similar vehicle and mods. My current set up is: mpe, mppk, jb+, drop in afe filter.
1. Is the VRSF the best choice price/quality wise? 2. Their CEL fix will only clear a dp related code or it will mask all the possible CEL? 3. Will I get a bump of 30+ HP/TQ with my current set up? 4. Is it going to be really loud with the mpe? Maybe I should remove the mpe then and put my oem axle back in place? Does mpe really add any power gains? |
07-08-2019, 09:11 AM | #3 |
Rep 231
I don't know how loud it will be since it will be catted but my catless downpipe with the MPE was so loud I had to put my stock muffler on. As far as the vrsf ones, I know people had lots of fitment issues so I went with the ER one and upon tuning I definitely got 30+hp however like I mentioned before it'll be different with the catted downpipe I'm not sure
duercos201.00 r33_RGSport12996.00 |
07-08-2019, 09:30 AM | #4 | |
Rep 178
I have the MPE, ER Catted DP, MPPK, BMS Intake, and JB4.
I dont mind the tone of the exhaust and dp. I think the catted dp helps decrease it a little. I have received a lot of compliments about the tone. Granted my wife and mother cant stand it. There isnt too much drone and at cruising speeds its not too bad. Granted on my longer commutes I do get a lil tired of it and turn up the radio. Going to look into some dynamat in the spare tire well to see if i can cut down a little cabin noise. I went with the catted ER dp hoping it would not throw a CEL. That is not the case. I tried a few methods to see if I could get it to go away permanently, but didnt have luck. I have one last attempt pending install where I have a simulator wired to my 2nd O2 to fool the computer. Once I install it, I will let you know if it works. I can clear the CEL with the JB4 but it comes back on anywhere from 30-100 miles. I have yearly emission inspection in PA so if I cant clear the CEL and get the car back into ready state, I will have to put the oem cat on to pass inspection. As far as power, I cant say specifically on just the DP. I did all my upgrades at the same time but overall pretty happy with the overall power so far. Quote:
07-08-2019, 12:31 PM | #5 | |
Rep 413
07-08-2019, 12:35 PM | #6 | ||
Rep 413
JWK170200.00 |
07-08-2019, 12:38 PM | #7 | ||
Rep 231
duercos201.00 |
07-08-2019, 12:44 PM | #8 | |||
Rep 413
07-08-2019, 01:07 PM | #10 | ||||
Rep 231
07-08-2019, 01:16 PM | #11 | |
Rep 178
I had a BMW Indy shop install the DP initially while I had them doing some other work. I think just the DP install was around $150-200.
After I was still getting the CEL errors, I messed around with it myself and took it out to make sure there wasn't any leaks and installed it with new clamps. Overall, it's not too difficult of a install. Only issue is it is quite crammed in that area so the tight quarters make it a little more awkward and difficult. Quote:
duercos201.00 |
07-08-2019, 11:44 PM | #12 |
Rep 18,727
You don't need to, unless if you need it for custom tune that need to have additional sensor. Like exhaust temp, etc.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
07-09-2019, 09:21 PM | #13 |
Rep 413
Hi Ben which one do you personally recommend VRSF or ER? In terms of performance, more refined sound and ease of fitment on f15/f16? Also which one do you have in stock and what is my group member price? 😊
07-10-2019, 12:59 AM | #14 | |
Rep 674
2. MPE with Catless sounds quite loud and nasty.. I dont know about catted tho. |
duercos201.00 |
07-10-2019, 01:32 AM | #15 | |
Rep 18,727
duercos201.00 |
07-10-2019, 07:05 AM | #16 |
Rep 178
I am running the ER Catted DP I got from Ben with the MPE. I also have the MPPK and JB4 and running open flaps so you get some burble.
Here is a sound clip I took of cold start after the car sat a few hours. About 3/4 way in it cuts over to standard idle to give you an idea of some of the sound difference. https://www.youtube.com/watch?v=8fMiTnq7m8k At cruising speeds the excess sound is minimal. When you punch it pretty hard though it can get a lot louder where some of my passengers find it annoying yet many other people complement the sound. Overall I am happy with the set up. I can't find any of my posted videos that I can link of running it wide open. I'll see if I can find one. |
07-10-2019, 12:36 PM | #17 | ||
Rep 258
07-10-2019, 12:55 PM | #18 |
Rep 18,727
