04-20-2016, 04:21 AM | #2311 |
Rep 56
Another problem... Can not read HU_NBT (?)
I just had the car in for service and they updated all my ECU's I need the new psdzdata files right? Where to download? Last edited by MTornberg; 04-20-2016 at 05:29 AM.. |
04-20-2016, 07:05 AM | #2313 |
Rep 41,172
I replied to your same PM...both of them.
04-20-2016, 07:06 AM | #2314 |
Rep 41,172
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired BDC_BODY => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on BDC_BODY (the ECU itself not the underlying CAFD) => Select CODE.
04-20-2016, 07:25 AM | #2315 |
Rep 56
Did not mean to send two - Sorry.
I misspelled a few things and thought I could correct/delete the old one. How ever, It seems I already use the latest E-sys. Are there any updates and/or batches I should dowload/install? |
04-20-2016, 07:33 AM | #2316 |
Rep 41,172
But what psdzdata version are you running? 58.2?
04-20-2016, 07:37 AM | #2317 |
Rep 56
04-20-2016, 08:05 AM | #2318 | |
Rep 938
04-20-2016, 08:20 AM | #2320 |
Rep 41,172
RTTI is a subscription services, requiring authorized VIN.
04-20-2016, 08:25 AM | #2321 | |
Rep 56
I have activated SLI at BMW. And most connected services. But I'm guessing I need a specific authorization for the RTTI? Only possible to activate at BMW? |
04-21-2016, 01:23 PM | #2322 |
Rep 592
04-21-2016, 04:59 PM | #2323 | |
Rep 2,404
Didn't your ICM get corrupt when you tried to code "sport mode" to always be on? |
04-21-2016, 05:06 PM | #2324 |
Rep 938
No but when I did a cafd update. Seems I have a sensitive car. Another example- I can only change the orange/first ambient group. Any of the other 2 and it corrupts bdcbody.
04-21-2016, 05:45 PM | #2325 |
Rep 592
Sorry to hear that. Make sure to add a Benadryl additive in your gas tank prior to coding. Lol
04-22-2016, 01:21 PM | #2326 |
Rep 1,495
Wanted stop to say a huge thank you to opasha r33_RGSport and shawnsheridan for contributing so much to this thread and community. This thread is a great resource.
Then - E53, E85, E92, E82, F15, F80, G01
Now - F97, Macan S |
04-22-2016, 04:45 PM | #2327 |
Rep 15
Great job with the coding tutorial and FAQ. I have successfully coded many things. But there are a couple things that didn't take into effect.
1) Unlock all doors when engine turned off Unlock when STOP Engine BDC_BODY 3040 VAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK nicht_aktiv aktiv Mine doesn't have the choice for aktiv. Only nicht_aktiv is available in drop down box 2)Turn off dim for (front) DLR when Headlights are on. (DLR Stay 100%) FLE (both) POLI1_Idx F015Wert_SA552_SAE Unknown = Change 3rd byte from 0C to OA Production date post 06/15 FLE (both) POLI2_Idx F015Wert_SA552_SAE Unknown = Change 3rd byte from 0C to OA FLE (both) POLI3_Idx F015Wert_SA552_SAE Unknown = Change 3rd byte from 0C to OA With the DRL 100% setting, my third byte was already set to 0A from factory, yet the DRL rings still dim when the headlights are turned on. I checked for FLE modules and they were all set third byte to 0A. Does anyone else have this problem or have they gotten these two features to work? Thanks Last edited by userix; 04-23-2016 at 04:52 PM.. |
04-22-2016, 06:25 PM | #2328 | |
Rep 592
04-23-2016, 04:15 PM | #2329 | |
Rep 15
MAPPING_PARKL_1_V_L_PWM_1_STANDARD is what I have in my FDL file. I tried changing both of the respective values from 7.2V to 13.7V but my Rings are still dimmed when the main headlight is on. |
04-23-2016, 04:24 PM | #2330 |
Rep 15
The UNLOCK when STOP engine function (BDC_BODY 3040) doesn't work for me.
In the FDL file, VAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK only has the "nicht_aktiv" choice in the drop down box. There is no "aktiv" choice. I tried manually changing the werte value to 01, but when I do it shows UNKNOWN" in the option box. Doors still doesn't unlock when I turn off the engine. Last edited by userix; 04-23-2016 at 04:50 PM.. |
04-23-2016, 04:52 PM | #2331 | |
Rep 592
04-23-2016, 07:08 PM | #2332 | |
Rep 8,364
In newer CAF's, VAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK only has option for nicht_aktiv; whereas earlier version had also had aktiv. Check to see if you have CLI_DEFAULT_UNLOCK_AFTER_END_OF_DRIVING, which can be set to aktiv. As an aside: X5 and X5M have different Launcher selection but same E-sys target. |
