05-02-2022, 04:18 PM | #45 |
Rep 901
All your symptoms have been pointing to low charge or some sort of connection issue. I'll be damned if it didn't.
BimmerNewb7922.00 |
05-04-2022, 07:12 PM | #46 |
Rep 37
So, got my new Aux battery in and it did not resolve my issues. However, I need someone to point me in the right direction. I think I have a relay issue, but haven't found where they are exactly. The CAS and Kombi modules seem like they are not powering up, and then when clearing codes Ista tells me that it can't switch off the ignition automatically. I imagine that is also a relay, but not sure which one or where to look.
05-05-2022, 06:19 PM | #47 |
Rep 1,038
Not sure if you've had a chance to poke around. Have a look at the Workshop tab, you will be able to do searches for wiring diagrams, object functions, connections, etc.
BimmerNewb7922.00 |
05-05-2022, 07:42 PM | #49 | |
Rep 37
05-05-2022, 09:31 PM | #50 |
Rep 1,564
Since you have already checked the ground straps and after looking into this a bit more, with the fault codes present I think you are on the right track into looking into the relays next. Then after that I would check the engine compartment distribution panel. With the short to ground faults, could be something melted here and shorting out.
So first up check your terminal 30 relays, the F85 appears to have two, one front located in the front fuse junction box and the rear located in (or near) the rear fuse panel. If all of that checks out, there is another distribution panel to check in the engine compartment. Pics and more info below. I would also visually check out the power distribution junction located on the main battery. I have seen in the past people tapping these cables to run stereo equipment that can wreak havoc. Look for anything left over from the previous owner that doesn't look factory. Also if you dont have access to BMW TIS, PM me, makes looking all this up much faster then waiting for ISTA to sift through the 10gig of data IMHO |
BimmerNewb7922.00 |
05-14-2022, 11:56 AM | #52 |
Rep 37
So, stupid question, but a ran across a post on a Google search saying that leaving a obd adapter plugged in all the time will hurt the car. I was running the black mhd wifi adapter all the for extra gauges. Could that have been what caused my problem? And, what did it damage if it is the problem?
Also, someone has been into the housing around the BDC. Come to find out the 1st copy of ISTA I got wasn't the fun version. Re-installing a full version now. Last edited by BimmerNewb79; 05-14-2022 at 02:08 PM.. |
05-14-2022, 10:48 PM | #53 |
Rep 901
I've heard that they tend to drain the battery, especially if the vehicle is not driven much. The expensive ones automatically turn off after 10 minutes upon turning off the ignition.
BimmerNewb7922.00 |
05-15-2022, 12:02 AM | #54 |
Rep 7
BimmerNewb79 sorry to hear about your car troubles. Hopefully you get this all sorted out soon!
BimmerNewb7922.00 |
05-16-2022, 07:28 AM | #56 | |
Rep 1,038
I know when installing it gave the option to install the Programming module, but would of been like a 200GB+ Install. Is that what you were missing? |
05-16-2022, 07:33 AM | #57 | |
Rep 37
05-16-2022, 01:04 PM | #58 |
Rep 37
This damn thing was my problem. Apple carplay add-on.
No major fault codes, and the car starts up. Haven't had a chance to try and drive it yet. |
4
05-16-2022, 01:06 PM | #59 |
Rep 1,252
BimmerNewb7922.00 Slickrick2211.00 |
05-16-2022, 07:42 PM | #60 |
Rep 901
05-16-2022, 09:23 PM | #61 |
Rep 7
I was considering buying one of those! I think I will pass on that now. Great you got it figured out.
05-17-2022, 12:32 AM | #62 |
Rep 1,038
Wow, that's a dumb thing to fail and not have the car start.
Well on the upside its not the car. |
BimmerNewb7922.00 |
05-17-2022, 07:15 AM | #63 | |||
Rep 37
Funny thing is, I was taking apart the dash to trace wiring and found it. I don't use it, so I was like, I'll just remove it and de-clutter a bit. Then I got ISTA sorted out and went to hook it up and test the car. Turn the ignition on and everything turned on and no alarms, WTF?!? Lol |
9vapors653.50 |
05-17-2022, 08:07 PM | #65 | |
Rep 1,353
Switching Off Terminal 30B : When the vehicle is locked, the Car Access System receives the central double-locking signal. Once the vehicle is locked, Terminal 30B remains on for approx. one minute and is then switched off by the Car Access System. The tailgate must have already been closed. If the vehicle is not locked or if the tailgate remains open, the delay until Terminal 30B is switched off is approx. 30 minutes. After that, the Car Access System switches Terminal 30B off. In addition, Terminal 30B can be switched off when the vehicle is in parked mode if the battery upper starting capacity limit is reached. During fault diagnosis, the power down command can be used to switch off Terminal 30B under defined conditions for the purposes of measuring quiescent current
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
BimmerNewb7922.00 9vapors653.50 |
05-17-2022, 08:25 PM | #66 | |
Rep 37
