08-15-2022, 07:47 PM | #23 |
Rep 282
Definitely by an extreme amount. That's where most of the heat comes from actually.
08-15-2022, 07:50 PM | #24 | |
Rep 282
08-16-2022, 01:22 AM | #25 |
Rep 225
Awesome im gonna do the same! I've been looking at cerakote ceramic coating I as thinking of maybe using their air cure ceramic coating in the v of the engine after the manifolds are removed..
08-16-2022, 02:40 AM | #26 | |
Rep 1,038
You should be able to get the water down to near low single digit °C. Last edited by Chilled; 08-16-2022 at 02:45 AM.. |
08-16-2022, 05:08 AM | #27 |
Rep 1,038
Just had a moment of realisation, if the water in the charge loops is still been used for the DMEs. How are the DME handling it? Electronics really don't like condensation/frosting.
By default the DME and the Charge coolers share the same loop. |
08-16-2022, 07:53 AM | #28 |
Rep 282
The DMV should be fine as they are designed to take a beating hot or cold. I just spoke with my buddy from BMW and he is lead tech and works on most of the M cars there and he said as long as the DME doesn't literally freeze up it should be fine.
08-16-2022, 08:53 AM | #29 |
223
Rep 304
Its pretty simple in concept. I used them on my CLS55 and CTS-V. You "tee" the liquid and suction lines of the AC system, and run to a secondary Multiplate heat exchanger. this will refrigerate the core. Then you run the IC coolant loop through that. This cools the coolant down to below ambient temps. If designed correctly for efficiency, close to freezing temps. Basically you are making your own winter temps and DA. Highly recommended, and would be far better for making HP than the M5 coolers, and would be less work. Also note that in these setups, less piping and smaller core parts are better. in fact even removing the oem HX from the equation would make it more efficient and cooler.
08-16-2022, 02:08 PM | #30 | |
Rep 282
08-16-2022, 06:28 PM | #31 | ||
Rep 1,038
The way i understand that AC works is that toxic pixy farts go in, cold comes out. So am I understanding it correct that you want to tap of the cold gas and pass that through your own rad(chiller on diagram) unit. Then flow water through it, for the IC loop. Why not take the chiller(on diagram) out and pipe the gass directly to the stock ICs. So instead of water in the ICs, its the gass. Saves on the thermal loss of cooling the water. If you going to do this, I would prob use the Wagner or CSF ones and I would not trust the plastic endcaps. |
08-16-2022, 08:17 PM | #32 |
223
Rep 304
The diagram is just the ac part. The chiller core has 4 ports. 2 for the Ac refrigerant forn high to low expansion, which is the action that produces the cooling effect. The other 2 are for in and out of the cooling loop. Basic its 2 sets of chambers. 1 in which refrigerant flows, and the other for liquid.
You cannot plumb the ac refrigerant to the ic cores directly. They only have 2 chamber, 1 for fluid in the tubes which in turn cools the innner fins and charge air. You would need a third for the refrigerant. Let alone addition complexity of running hoses lines x 2 etc You cannot remove the fluid coolant and pump as the fluid will allow the ic to work as normal when ac is off, and chilled when running on demand. You wouldn't want to be driving with ac on 24x7. These setups are proven on many platforms and are the best option for actually adding power to the l2a ic system. There is no need to upgrade the factory ic core unless you are flowing major air and finding cfm limits on the cores with something like this. |
08-17-2022, 07:49 AM | #33 | |
Rep 17
I was just ironically talking to a friend of mine ab this, AC for intercooling but we hadnt gotten this far lol |
08-18-2022, 12:21 AM | #35 | ||
Rep 1,038
08-31-2022, 07:44 PM | #36 |
Rep 282
Did a little research as well as looking at my own DMEs and the X6M/X5M DMEs aren't water cooled at all. They have the ports for the coolant lines because they use the same model DMEs as the M5 M6, but since they don't sit right above the turbos like in the M5 and M6 they are not water cooled because it isn't needed since they are very far away from the engine inside of complete enclosure on the firewall up against the passenger side fender.
Chilled366.00 |
08-31-2022, 10:00 PM | #37 | |
Rep 464
09-01-2022, 04:16 AM | #38 | |
Rep 1,038
I was having this exact conversation with Qsilver7 if the F85/F86 DMEs were still cooled. The doco on these says no, but it looked like the DME shells had coolant line placements. I didn't check mine to see if there are any actual lines going to them tho. I guess now we know. https://f15.bimmerpost.com/forums/sh...7&postcount=12 |
09-03-2022, 04:03 PM | #39 | |
Rep 2,718
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
Chilled366.00 |
11-21-2023, 06:23 PM | #40 |
Rep 116
Looks like you did this with an F10 cooler? Has anyone tried using one of the aftermarket coolers for the F90? Like Project Gamma's 2 piece system? Looking for something a bit more DIY Friendly.
https://trucranemotorsports.com/prod...0&_ss=e&_v=1.0 |
11-21-2023, 08:41 PM | #41 |
Rep 1,038
From arm-chair research the F90 coolers are a way better fit on these because these have the correct flange to bolt to the plastic plenums.
According to Level (these guys have the fastest F90 in the world), they said the best coolers they found where the stock ones. *Edit* Here is the interview where the go into some details on the F90 CS, and mention the ICs. Timestamp 13.24. Yes it is in Russian, for most part translate does work. I don't necessarily agree with his view/idea that the clutch packs on a gearbox are a wear items like brakes pads. He says they will need to replace them all by about 30k-40k km, but then again they are close to 1300-1400hp and constantly launching it. So my opinion counts for d*ck. Last edited by Chilled; 11-22-2023 at 03:48 AM.. |
11-28-2023, 05:14 PM | #42 |
Rep 282
I just finished swapping to the F90 coolers. The flange isn't the same as the F90 uses a three bolt throttle body and we use a 4 bolt throttle body. But the coupler is the exact same that slips over the throttle body. So no need to worry about flanges. The only thing that would stop you from direct swapping the F90 cooler is the upper radiator hose on the driver side needs a 90° inlet fitting and a 90° 1.5" silicone hose to replace the factory hose. Also, the fan support needs to be trimmed a little on both sides. That F90 runs a 8.5 second full interior quarter mile pass. I'm sure the clutches won't last very long launching with what I believe is 1200 ft lb to the wheels.
11-28-2023, 11:48 PM | #43 |
Rep 1,038
Watched the vid, nice explanations man. On the Trans coolers, you sure its not going to drop the temps too far down?
BTW, since you already spent money on the F90 coolers. Let me help your wallet. Level put out their own end tanked OEMs. https://1evel.ru/product/level-perfo...m5-f90-s63-cr/ |
11-29-2023, 09:02 AM | #44 | |
Rep 282
