12-14-2023, 08:00 AM | #2 |
Rep 806
Drives: BMW X5 XDrive35i
Find an independent service center to do the work, should definitely be some savings going that route.
12-14-2023, 01:31 PM | #3 |
Rep 210
Rather rare for the ball joint itself to develop play prior to bushing failure.
If that is the thrust arm, the quote is high regardless. Under my service contract (thank god) TAs were like $1.6k.
2018 X5 50i [AW / Black]
2016 550i [AW/ Black] 2014 550i [CB / Black] |
12-14-2023, 07:59 PM | #4 |
Rep 480
Are you able to do the work yourself?
Do you want genuine BMW parts? Do you want it done by a BMW dealership? If your answers are no, yes, yes, then… If you ARE able to do it, that’s about $1100 in genuine BMW parts, then add in your labor. Or you can get equivalent parts from other places for much less |
12-14-2023, 09:24 PM | #5 |
Rep 5,002
Buy lemforder parts at any independent service center. Will be half the cost and the same thing as OE BMW parts.
sukhk5272168.00 zero2sixtyZ951.00 |
12-14-2023, 10:47 PM | #6 |
Rep 22
Could this also be referred to as the Thrust arm bushing?
I'm at 60k miles and have been told the thrust arm bushings need replacement. Sorry not trying to thread jack. |
12-15-2023, 10:10 AM | #7 | |
Rep 480
So if your bushings need replacement, you can just do those. Though I would think the ball joints can’t be too far behind, so if it were me I’d just replace the arms. |
12-15-2023, 12:34 PM | #8 |
Rep 2,669
Drives: e92 + f15
Just had these done not too long ago. Local to the area as well. I would confirm the part numbers via RealOEM.com, order the parts from FCPEuro, and bring them to a local independent shop if needed.
