      07-15-2014, 02:43 PM   #1
mattbar1
Drives: 2014 X5 M Sport 50i
Installing dashcam
Folks
I'm installing a Blackvue 550 2 channel dash camera. If you wire it to the battery it will record while the vehicle is off. Any recommendations which fuses I could tap into in the back right compartment? I need a constant battery source and an ignition only battery source.
As always. Thanks.
      07-18-2014, 10:33 AM   #2
originalgoods13
Drives: Chevy Spark
Yes, running it directly to the battery or a live fuse, it will always be on. There should be some tutorials in YouTube on how to find a live fuse you can tap to.
I'd recommend using Power Magic Pro along with your BlackVue Dashcam
      07-18-2014, 03:55 PM   #3
Socal2025
Drives: 2018 540i
I just ordered the BlackVue DR650GW-2CH. It seems that the BlackVue is one of the best options out there.
      07-18-2014, 05:21 PM   #4
mattbar1
Where did you order the 650 from?
      07-18-2014, 05:23 PM   #5
mattbar1
Thanks. I'm using the black magic as well. I plan on searching for fuses in a little bit.
      07-18-2014, 05:44 PM   #6
NPickles
United Kingdom
71
Drives: F15 40D SE Space Grey/Terra
It's a real shame there isn't an under dash 12v socket in the F15 as there is in the current F10/11's.
      07-20-2014, 01:24 PM   #7
Socal2025
Drives: 2018 540i
+1. I was disappointed as well... My 5 series has it and that socket would be perfect for the dashcam.
      07-20-2014, 01:25 PM   #8
Socal2025
Drives: 2018 540i
I ordered mine from blackboxmycar.com. First time ordering anything from them but this site seems pretty good.
      07-20-2014, 01:29 PM   #9
mattbar1
It says preorder. Any idea when it's supposed to ship?
      07-20-2014, 01:35 PM   #10
Socal2025
Drives: 2018 540i
Mine shipped the same day I ordered (July 18). I guess they may have run out of stock. This camera is the dual channel newest and best model they have for around $420. Not bad at all.
They seem very attentive to customer service. I would call them up (they are in Canada) and ask when new stock will become available.
      07-20-2014, 01:39 PM   #11
mattbar1
Great thanks.
      07-29-2014, 05:53 AM   #12
krisdv
///M Power
krisdv's Avatar
Belgium
16
Drives: F90 M5 - G05 X5 45e
Did someone manage to find a fuse that has constant power on?
      07-29-2014, 07:42 AM   #13
mattbar1
Try 161 Red and 107 Yellow on a US spec 50i MSport. See photos.
ALL: the photo is correct. The numbers may be wrong.
The fuse holder is from amazon:
http://www.amazon.com/Littelfuse-FHA...words=fuse+tap
      07-30-2014, 01:07 AM   #14
mikikuki7
mikikuki7's Avatar
Drives: Searching for X6M or M8
Try 141 ignition and 162 battery on a US spec 50i MSport. See photos.
Well...the photos won't post from my iphone. I'll send them later.
Could you please post the pics? LoL... I would wanna install the cam...
So.. What will the can do? Anyone has pics of a currents installed camera? Or a video?
      07-30-2014, 08:19 AM   #15
mattbar1
I edited the post above. Sorry for the delay.
      07-30-2014, 06:46 PM   #16
Socal2025
Drives: 2018 540i
I installed the BackVue 650. What am amazing camera. Works really well with the iphone app and the quality is really good as well.
They sent me the adapter to connect to the battery but I have not done that yet.
      08-07-2014, 12:34 PM   #17
eddysuen
Drives: 2014 F15 30d
How can I find the passenger side fuse box? I cannot see it after unscrew 3 plastic screw at the bottom of glove box.
2014 F15 X5 30d
2012 F10 528i, Toyota Estima
2010 E92 325i, Toyota Estima
2009 Honda Odyssey
2007 Honda Stream
      09-04-2014, 03:55 AM   #18
NPickles
United Kingdom
71
Did you find the passenger side fuse box (I have RHD), like you I thought undo the three thumbscrews under the glovebox and it would be there staring at you but it is not. Where did they hide it?
      09-04-2014, 10:13 AM   #19
Kiwi123
Drives: x5 40d
Will installed wired dashcam affect the BMW warranty?
      09-04-2014, 11:22 AM   #20
NPickles
United Kingdom
71
I wouldn't think so. Only using a piggyback fuse adapter to pickup a live from the fusebox to feed a 12v to 5v USB stepdown transformer. Very little different from using a cigarette lighter adapter but much much neater, especially as there is no hidden low level 12v socket like on other BMW's.
      09-04-2014, 11:58 AM   #21
MattBianco
MattBianco's Avatar
Drives: 2015 X5 35d msport
Dash Cam Hack Wish
For those with surround cameras (driver assist plus in the US), I wish there was a way to:
1) hack into existing cameras, and feed a small DVR recorder
2) or better yet, do the hack and feed the onboard media drive that holds (20GB??) plenty of data.
The cameras are there. The wires are there. The capture and display are there. They data storage is there. This would be more than a code as it would need a software patch, is my guess, but BMW should do it. Is there a way to petition them?
      09-04-2014, 12:13 PM   #22
NPickles
United Kingdom
71
That would be awesome, another reason to get surround cameras, but I reckon the chances of that happening are virtually nil
