      03-12-2016, 11:05 AM   #23
Originally Posted by mateforrest View Post
Please,
i just install the correct switch, and VO code adding 248 to the Body Domain controller or BDC.
The light of the button goes on in orange , but the steering wheel doesnt heated.
could anyone tell me which units are involved with this function ?
Thanks in advance for the help.
Did you switch the steering wheel to a heated version steering wheel?
PM for Everyday DEALS!!
      03-12-2016, 05:33 PM   #24
mateforrest
Spain
Drives: BMW G06 40d
Yes
i have the correct Steering wheel (reference 32306868771) and the correct steering switch for this function.
      03-14-2016, 04:37 AM   #25
mateforrest
Spain
Drives: BMW G06 40d
Yes
any?
      03-14-2016, 04:39 AM   #26
mateforrest
Spain
Drives: BMW G06 40d
Originally Posted by opasha View Post
Ah, @r33 is correct. The non-heated steering wheel is part number 32306868764 while the heated steering wheel is part number 32306868765. You can see that here - scroll down the list. http://www.realoem.com/bmw/showparts...82&hg=32&fg=35.
@TrojanLaw, let me know what prices they give you for the heated steering wheel. Actually here's a list of prices for the heated steering wheel in order of increasing price:
http://www.bmwpartsupply.com/OEMPart...306868765.html
http://www.turnermotorsport.com/p-18...-bmw-part.aspx
http://www.eurocaroemparts.com/store...part61859.html
I believe this is for the steering wheel only. Your airbag can be used on these steering wheels since it is the same US sport airbag. I just took off my steering wheel and I have the cold weather package. I can sell you my sport steering wheel if you like. You have my number. We can discuss this over our coding session if you like. I have kept it in mint condition since I am the only one who drives my vehicle. Hope this helps.
Here's as picture of mine as it was taken off last week (now sitting in bubble wrap) in the same box my CF steering wheel came in:
Proof that I have the cold weather package :
Omar please, could you help me?
what the unit/s you code ?
      01-10-2019, 08:03 PM   #27
mikenice30
Drives: 2014 BMW X5
I need help too
I know this post is really old but now I'm in the need for help. I just bought me a 2014 x5 without heating steering. I did not realize how much I really need it because my X5 E70 had it and never a had second thought about. Please help me did this work for anyone and how hard it was?
      01-10-2019, 08:38 PM   #28
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
So you need to have heated steering wheel first - plenty of them on ebay for about $1k+ and this is a good time to convert to m-sport steering wheel if you don't have it. After you have that you'll need a physical switch/button with control module that plugs on left side of steering column (it;s visible on the picture above your post) - where you have steering telescoping/tilt joystick. Part number comes up if you do a search. Some also say coding will be needed, but that's not hard to do using remote session with any coder who works on BMW.
So all in you are looking at $1.5k at least and some time spent chasing down all needed parts and installing it.
Steering swap is easy. If you'll decide to sell your steering wheel to recuperate some cost - let me know if it's m-sport - I might buy one.
      01-12-2019, 12:53 AM   #29
kry226
While not necessarily apples to apples, I did this retrofit on my 18 M-Sport. It should at least give you a starting point.
https://f15.bimmerpost.com/forums/sh....php?t=1546938
Hey DuSh- I have an F15 M-Sport steering wheel for you!
2018 X5 xDrive35i M-Sport - Traded
2013 X1 xDrive35i - Sold
1986 320i - Sold
DuSh2113.50
      01-12-2019, 12:10 PM   #30
mikenice30
Drives: 2014 BMW X5
Heated Steering wheels
I was able to order the heater switch and my current wheel has a part number of 32306877855. I'm assuming that this is wheels is the one without heat so I need 32306877856 I think. I also came across some posts that said that all they needed was the parts and it work without coding but then I came across people saying it needed coding. What about using a steering wheels with the shift paddles on eBay from Spain, would they work?
      01-12-2019, 12:22 PM   #31
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Different markets have different setup so coding part may or may not be necessary - you'll be able to check it right after you'll install heated steering wheel and switch.
You can use any steering wheel compatible to f15 x5 with paddle shifters or not - it doesn't matter (btw you can also code paddle shifters to work too if you don't have them). What matters when ordering from ebay is that most of steering wheels from Europe come with single stage airbag (unlike in US/Canada where we have dual stage) and that might need coding too to avoid airbag light on dash - just something to consider. If you already have airbag you want to reuse - then you are good.
      01-12-2019, 12:49 PM   #32
mikenice30
Drives: 2014 BMW X5
good to know
thanks
