      07-27-2019, 01:33 PM   #45
CanadianLurker
Drives: 2018 X5 xDrive35d
So, did they upgrade the factory standard battery at some point for a given model year in order to avoid this issue? Or is this still in place regardless of model year?
      09-14-2019, 01:11 PM   #46
EngineerBill
Drives: BMW X5 s35i
Thanks.
      09-14-2019, 05:25 PM   #47
Qsilver7
Qsilver7's Avatar
Originally Posted by BDO View Post
Guys, sorry for being too lazy to RTFM... where are the battery posts for trickle charging positioned?
With the same frame of mind...I'm not going to download a 2016 X6 owners manual to find out...but I do have a pic of a 2016 X6 35i engine bay...and there's a 99% chance that the position of the jump start terminals are in the same location...if not...they'll probably be real close.
The positive terminal is under the red cap...and the negative terminal is usually a hex bolt (sometimes its a straight pin about the thickness of a pencil). See the two locations circled in the pic below.
If you pop your hood open and it looks nothing like this...and you still can't figure it out by looking around the engine bay for something that looks similar (but could possibly be in a slightly different location)...then its time to open your owners manual.
      09-15-2019, 03:38 PM   #48
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
3 months and someone finally answers him. A real gentleman.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      09-16-2019, 02:16 PM   #49
Qsilver7
Qsilver7's Avatar
      12-05-2019, 08:12 AM   #50
EdgyE36
Wisdom Searcher
EdgyE36's Avatar
58
Drives: E39 M5 and E46 M3
Latest
FYI, here's the latest SIB. Provided to me during the debate I had with dealer about giving us a new battery in the 2016 CPO we purchased.
F15 is off the list for every other oil change battery replacement.
BLUE HEAVEN
My cars - 2002 Lemans M5, 2006 Interlagos M3
Kewl X552.50
Clifton221.50
      01-16-2020, 11:16 AM   #51
scootr
scootr's Avatar
Drives: E89 Z4 3.0 6MT
Taking my 2018 diesel in for battery problem related to low power no cranking issues in cold weather. We will see what they say.
      01-16-2020, 01:12 PM   #52
triax37
130
Drives: 2017 F31, 2014 F15, 2002 M3
Since Qsilver7 posted the image above, I thought I would relay a question and recent battery story:
Question: What do you all think about using the engine terminals to test the battery?
Story: I accidentally left my radio on overnight in early December, which drained the battery down and the car would not start. After jumping it, I drove to O'Reilly Auto Parts, where they "tested" the battery using the terminals in QSilver7's image. Their tester said one or more cells were damaged, and it needed replacement. Seeking a 2nd opinion, I went to Autozone and they attached their tester directly to the battery (cargo area), saying that the engine terminals will give false readings. When they did this, the tester said the battery is fine. Since then, I've used a voltmeter to directly test the battery (cargo area), and it reliably reads 12.73-12.74. Below is a link to how I tested the battery and alternator:
https://itstillruns.com/symptoms-dea...y-7362764.html
      01-16-2020, 02:20 PM   #53
Qsilver7
Qsilver7's Avatar
Do you have the 2 battery system? if you do, if you haven't disconnected both batteries from the system, then it is still connected to the auxiliary battery and your "test" may be false if the two batteries are still connected.
If only testing one battery...I can't think of a reason it can't be done directly to the battery's terminals...but ONLY if it is disconnected from the system. (I'm willing to be educated if I'm wrong...but don't just say I'm wrong...tell/explain why. )
And if any charge/charging is going to be done, then it does need to be done at the engine bay terminals so that the IBS (intelligent batttery sensor) is kept "in-the-loop". See the green highlighted text below.
      01-16-2020, 02:38 PM   #54
MK2018
MK2018's Avatar
231
Drives: 2018 X5 xDrive35i
That's good info
I'm happy I have my trickle charger installed permanently in my X5 by dealer and don't have to worry when I have it parked for long period of time
Current
2018 F15 M sport x35i
Past
2017 GMC Sierra Denali
2017 GMC Yukon Denali
2016 GMC Yukon SLT
2015 GMC Sierra All Terrain
      01-16-2020, 05:08 PM   #55
ComasF15
Drives: Silver
I have to say, it shouldn't be this hard. My car says 12.5 at the charging terminals. Sigh.......
      01-16-2020, 06:16 PM   #56
scootr
scootr's Avatar
My battery was reading 12.34 Not starting without a maintainer on it overnight (13.4v) and the dealer replaced it today.... This is a d model with 2 batteries.
Dealer said computer gave no indication of external draw or lights/radio left on. Just battery failure.
They replaced 105 ah battery
Car is only 2 yrs old with low miles.
      01-16-2020, 09:09 PM   #57
triax37
130
Great info - thanks! I do have two batteries - that would explain why the readings at the engine terminals would confuse the battery tester. On your second point, I'm also curious if I need to disconnect the battery to actually test it. Given the programming, computers, etc, is it ok to actually disconnect the battery at home? I have INPA, but not ISTA+ or any of the other systems used to code a battery.
For the record, I am not a diesel - the aux battery is apparently used for my rear seat heaters (and maybe AC?). Given the $250 aux battery cost, not including any labor/coding, I wish I only had one battery! Let my kid(s) freeze! It builds character!!!
Re: trickle charge, I do this at the battery terminals - good to confirm that is correct.
      01-17-2020, 07:01 AM   #58
Sophisticated Redneck
Drives: 2012 BMW X5 50i
Step1: Accept the engineer who designed the charging system for the X5 is an absolute Idiot...all of this hassle for 1 percent boost in mpg
Step2: Purchase a cigarette lighter voltmeter.
Step3: Drive around and notice how your voltage is crazy low when just cruising and the alternator only activates when braking/coasting. This is by design...have to boost mpg by 1 percent...who cares if it costs you a new battery every year?
Step4: Turn on your headlights and fog lights, watch as your voltage jumps to normal levels, turning on your headlights and fogs overrides the BS charging scheme and forces the alternator to stay on, charging your battery in the process (possibly adding performance too, higher voltage to the coils equals stronger spark which would make a difference at high boost levels....take note M drivers)
Step5: Be amazed that your battery is no longer drained on short trips....Yes with the E70 and F15's, you drive with your lights on to charge your battery....Every manufacturer has people who have risen through the ranks by nepotism as their idiocy would have removed them long without it...guess which division they work at in BMW...
      01-17-2020, 07:24 AM   #59
scootr
scootr's Avatar
Interesting ! Having just had the battery replaced at 8k miles I'm interested in keeping this one healthier longer. Is there a way to see the voltage through the iDrive while driving?
      01-17-2020, 07:35 AM   #60
Originally Posted by scootr View Post
Interesting ! Having just had the battery replaced at 8k miles I'm interested in keeping this one healthier longer. Is there no way to see the voltage through the iDrive while driving?
Not that I know of, If you have a OB2 wireless adapter you can do it in free apps like torque. Otherwise this is a nice option: https://www.amazon.com/Adapter-Cigar...9267714&sr=8-4
If you have a really Keen sense of hearing, put your fan to almost it's highest setting....notice how it blows a little harder and sounds a little louder when you brake/coast or when you turn on your lights? That's the boost in voltage from the alternator activating.
      01-17-2020, 07:55 AM   #61
ComasF15
Drives: Silver
Agree.
I wonder if fogs only would work too? I'd hate to shorten the life of $4000 xenon headlights to save a $300 battery.
      01-17-2020, 09:38 AM   #62
CatalinP
Drives: BMW X5 F15 2014 3.0xd
4000$ xenons, what a joke...
      01-17-2020, 10:52 AM   #63
alphaod
alphaod's Avatar
The bulbs are like $100 for two of them.
      01-17-2020, 10:58 AM   #64
Agree.
I have mine torn apart as I am doing a full carbon cleanup and porting and polishing the heads so I can't test right now, but you know what would be interesting is if BMW programmed it for any high-drain accessory to activate the alternator... Like the rear heated seats???
If someone with a voltmeter could test. If that works that would be a great work around. Apologies in advance to all kids/family members that ride in the back during summer
      01-17-2020, 11:24 AM   #65
CatalinP
If in doubt about how any car system works, one can always refer to newtis.info.
Otherwise, of course can also read on the forum about how expensive the xenon bulbs are...
      01-17-2020, 12:00 PM   #66
I got curious and looked up the price, looks like the OE bulbs are now only 184 each and if you go aftermarket, you can get Phillips for 50 each. Rebuild kits for the servo motors are available too for around 60 dollars so it appears the prices for the bulbs have fallen drastically in the past year unless I am missing something.
